Sedan Chat Thread
Old Aug 11, 2016 | 07:14 PM
  #10906
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by MetsFan
Does it bother anyone else that the steering wheels track control is different from the dash track controls? I guess I should stick to just using one, but it annoys me that on the wheel, up advances the track and on the dash, down advances the track.
What year is your car? My 2008 controls exactly the same from the console controls as it does from the steering wheel controls. Down on both advances the track (moves down the list on the screen) and Up on both reverses back on track (moves up the list on the screen).
Old Aug 11, 2016 | 07:21 PM
  #10907
2GoRNot2G's Avatar
2GoRNot2G
I've read that you want half the nut thickness of bolt protruding past the top of the nut. I wouldn't feel safe with the bolt not protruding at all.
Hmmm. I've never heard this approach applied to lug-nut applications even after 8 years of selling wheels and tires.
I'm not saying this approach would be wrong for all applications, as you definitely want more thread contact on race cars, track cars, and other high torque applications. But to follow this rule of thumb using closed cap style lug-nuts like the OEM Infiniti lug-nuts would be impossible... If the stud was long enough to protrude most open end lug-nuts then it would surely bottom out in a closed end lug-nut well before being fully seated/tightened.
Old Aug 11, 2016 | 07:32 PM
  #10908
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by Gregor12
Good to know! I'll check it out and see. Thank you for the info. I'll probably go ahead and order studs just to be safe
Feel free to send me a PM if you want any advice on what rear studs to get. If you go too long in the rear then the studs won't fit without completely disassembling the rear axle/hub assembly. I actually had to return the ARP studs (shown in the above picture) that I purchased for the rear, as they were WAY too long (about 66mm not including the round tip if I recall correctly) and I didn't feel like cutting down 10 brand new studs. I ended up using stud sets from Ichiba (both front and rear) since they offer 40mm, 45mm, and 50mm extended studs for our applications.
Old Aug 11, 2016 | 08:49 PM
  #10909
SonicVQ's Avatar
SonicVQ
I find wheel spacers an interesting topic...
For some, having the wheel flush with the fender is more important than a factory designed (aka stable) scrub radius and spring/shock motion ratio.
Old Aug 11, 2016 | 09:02 PM
  #10910
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Custom splitter finally done nothing too agressive, just enough to make the non s bumper look more sporty.
Old Aug 11, 2016 | 09:05 PM
  #10911
TechnikSLR's Avatar
TechnikSLR
looks good!
Old Aug 11, 2016 | 10:10 PM
  #10912
Nice job Hex!
Old Aug 11, 2016 | 10:41 PM
  #10913
dmudd's Avatar
dmudd
Anybody who's wanted to keep there stock air box's ever cut out the four inches hole and put in maybe a 6 inch aero port?
https://www.amazon.com/Precision-Por.../dp/B001001KIA
Old Aug 11, 2016 | 10:51 PM
  #10914
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Few more pics with a better camera.
Old Aug 11, 2016 | 11:32 PM
  #10915
slartibartfast's Avatar
slartibartfast
It's an engineering rule-of-thumb I picked up working at a chemical plant. Not applicable to castle nuts.
Old Aug 12, 2016 | 12:06 AM
  #10916
Djfarhan's Avatar
Djfarhan
took it to the dealership for routine maintenance check and then got it back like this:
Old Aug 12, 2016 | 07:09 AM
  #10917
ColumbiaSkinny's Avatar
ColumbiaSkinny
Loving that splitter hexotic. Turned out great. Really adds a nice touch to the non S front...
Old Aug 12, 2016 | 11:11 AM
  #10918
MetsFan's Avatar
MetsFan
I have a 2013. It's strange that they would have changed it. Anybody else notice the same?
Old Aug 12, 2016 | 11:18 AM
  #10919
ctyke's Avatar
ctyke
Dammit I thought I had all the mods I wanted planned out (relatively few), but I want that splitter. And so it goes...
Old Aug 12, 2016 | 12:41 PM
  #10920
2GoRNot2G's Avatar
2GoRNot2G
Wow! That custom splitter turned out great, Hex! Did you cut and mold that yourself or is this one that's adapted from a different application?
