Sedan Chat Thread
Old Oct 29, 2014 | 08:25 PM
  #4621
AroundTheG37's Avatar
AroundTheG37
What are we measuring again?
Old Oct 29, 2014 | 09:53 PM
  #4622
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
How would that match up to the standard size cats?
You'd have to double check with Lance, but I'm sure it would work with some finagling.
Old Oct 30, 2014 | 12:35 AM
  #4623
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Here you go...
Chris - can you grab a large caliper and measure the OD of the neck of the FI exhaust, please? It's probably either 2", 2.25" or 2.5".
Old Oct 30, 2014 | 09:30 AM
  #4624
RexHavoc's Avatar
RexHavoc
The OD of the neck coming out of the muffler is 2.465
The OD of the neck of the tip is 2.5
That help?
Old Oct 30, 2014 | 09:40 AM
  #4625
PM'd Lance for info. Let's see what he says.
That help?
Thanks, yes, that's the info I was looking for. Kind of surprised that it's 2.5", but there it is and now I know.
The easiest thing to do with new welded tips is to go *over* the cut stub of the original neck and weld the new piece directly to the can. A more difficult approach would be to try and weld two equal diameter pieces together. IDK what you would do if the replacement tip had a smaller neck diameter than the original.
Thanks again, Chris.
Old Oct 30, 2014 | 02:26 PM
  #4626
twin_snails's Avatar
twin_snails
Hey John, I completely forgot to take measurements last night but it looks like you've got the measurements you need. I'll take mine anyway just to see how they line up. I'll get info on the fitment of the tips in relation to the bumper cutouts if you're still looking to swap them at some point.
Congrats on your decision to go with FI! The quality and fitment is top notch.
Old Oct 30, 2014 | 07:22 PM
  #4627
RexHavoc's Avatar
RexHavoc
the 2.5 is the OD of the tip, I would "think" another 2.5 OD tip would slide over then neck of the muffler. Mind you I'm wrong more than im right.
Old Oct 31, 2014 | 05:00 PM
  #4628
Mik3G37S's Avatar
Mik3G37S
Anybody said anything about an F Type?
Old Oct 31, 2014 | 09:30 PM
  #4629
Confirmation from 1CleanG (Lance) that FI will build a 2.5" cat-back to match up to the 2.25" pipe on the standard FI RHFC. The added diameter is an added cost, but reasonable.
Who wants to answer the question: why 2.5" over 2.25"? I'm thinking 2.5", but with the 18" resonator. Matched with the RHFC, I suspect that would result in a very deep, very modulated exhaust. However, I don't really know, because that's just a dumbazz opinion based on nothing except some small experience and a lot of hearsay.
Opinions?
Old Oct 31, 2014 | 10:04 PM
  #4630
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Confirmation from 1CleanG (Lance) that FI will build a 2.5" cat-back to match up to the 2.25" pipe on the standard FI RHFC. The added diameter is an added cost, but reasonable. Who wants to answer the question: why 2.5" over 2.25"? I'm thinking 2.5", but with the 18" resonator. Matched with the RHFC, I suspect that would result in a very deep, very modulated exhaust. However, I don't really know, because that's just a dumbazz opinion based on nothing except some small experience and a lot of hearsay. Opinions?
I'd go with 18" resonators. Worst case scenario you can swap that section out for 12's if it wasn't loud enough. Glad Lance will work with you.
Old Nov 1, 2014 | 12:38 AM
  #4631
nishfish871's Avatar
nishfish871
I don't have any cat mods but the 18" is quiet, a lot quieter in person than the video I posted a while back. Its sounds a lot louder in-cabin than outside.
Old Nov 1, 2014 | 09:28 AM
  #4632
G37Xtreme's Avatar
G37Xtreme
Originally Posted by Dough1397
This! I debated going with Costco for my new set of winters, however they were $100 more. Definitely a great option for what you get. I'd get my set rebalanced yearly if it was included!
Discount Tire has a similar offer, with the exception of nitrogen. In fact, they balance them everything they rotate.
Old Nov 1, 2014 | 09:33 AM
  #4633
G37Xtreme's Avatar
G37Xtreme
Originally Posted by GAWD
Nope, unfortunately the car only learns & knows 4 TMPS signatures at a time and doesn't retain old memory. So winter/summer sets require the relearn. Whats further aggravating is the car knows exactly which is the LF, LR, RF, and RR, yet only pops a dummy light on the dash when one or more tire needs attention. Could chalk it up as novelty, but the Dodge Charge SRT (and many others) will tell you on the dash what the tire pressure is on each corner.
My 2012 Maxima would tell me the actual tire pressure for each tire. It didn't know where each tire was, but I engraved 1-4 on my valve stems to keep track of them.
Old Nov 1, 2014 | 10:00 AM
  #4634
It was a full year ago when I drove Choman's tuned 6MT with a full FI setup cats to tips. Wish I could have bottled up that moment so I could uncork it now.
I distinctly remember commenting to him that it could be louder. Certainly resonators and mufflers each affect the exhaust, but the resonators aren't so much about noise as they are modulation... it's the mufflers that reduce overall noise.
Old Nov 1, 2014 | 01:31 PM
  #4635
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
With a high in the upper 30s and a low in the low 20s I'm really wishing the G came with heated a steering wheel...
