2013 g37x coupe door problems
Old Jul 12, 2023 | 03:49 PM
thechamp01's Avatar
thechamp01
Hello everyone, I am having a issue thats really been bugging me and I was wondering if anyone ran into this issue. So both of the windows and door locks will not work with the main door switch or passenger side door switch, but the doors will lock and unlock with the key fob. The main driver side door switch has been changed and also the driver side door wiring harness has been changed out still nothing works. The driver side door speakers and the mirror switch not working.. I just don't understand what can cause this problem. thanks
Old Jul 12, 2023 | 11:18 PM
mummy2's Avatar
mummy2
Did you check the associated fuses?
Old Jul 12, 2023 | 11:37 PM
thechamp01's Avatar
thechamp01
Yes i did check all the fuses and relays.
Old Jul 12, 2023 | 11:47 PM
mummy2's Avatar
mummy2
Check this out. You never know. https://www.myg37.com/forums/body-in...ndow-fuse.html
Old Jul 13, 2023 | 01:19 AM
thechamp01's Avatar
thechamp01
yeah i even replaced that fuse because i thought mines was bad. i also looked at the cables on the positive side of the battery. I didnt see anything wrong with that either..
Old Jul 17, 2023 | 11:34 PM
thechamp01's Avatar
thechamp01
So i guess i'm down to looking at the bcm because everything that i've checked seems to be working fine.
Old Jul 18, 2023 | 09:34 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Normally I would say, yes, check the BCM. However, as you are having speaker issues as well- and the BCM has absolutely nothing to do with the speakers- points me to a wiring issue. Or even a bad ground connection.
Now you said you replaced the door harness, I assume you replaced everything from the DOOR connection at the flex boot to the door. However, what is the condition of the BODY-side connector at the flex boot? In other words, you changed the "plug" but what shape is the "socket?" There are a ton of pins and blade terminals in that socket that can get easily corroded/ bent/ damaged, etc. Also, what is the condition of the wiring under the driver dash. Any indication of water?
Also, does the ADP system work? Puddle lamp? Outside door switch?
Old Jul 20, 2023 | 11:47 AM
thechamp01's Avatar
thechamp01
When I figured out my problem, I removed the driver side door So I could get a closer look at the terminals from the harness plug. I used a test light and what was lighting up was real dim, pulled out the power probe and found out the terminals that's suppose to be lit wasn't 12volts. All the terminals I checked gave me something different. either no reading or grounded out. That's the reason I thought the BCM was bad because normally the BCM would send a ground signal to different parts. The socket is a long kind of oval shape, the outside door switch works, puddle lamp doesn't adp works.
BillyTheMan
General Tech Questions
Jan 29, 2020 06:52 PM
dougl33
16
Apr 24, 2019 08:12 PM
anderson854
Mar 9, 2018 02:14 PM
Anotherreject
Nov 18, 2016 12:52 PM
CRiME
Nov 16, 2014 01:38 PM
