What did you do to your coupe today?
Old Sep 16, 2023 | 11:17 AM
  #2086
ILM-NC G37S's Avatar
ILM-NC G37S
Everything you need to know is in these two threads:
Heater Hose DIY#1 and,
Heater Hose DIY#2
Just search for "heater hose g37" and you'll get a ton of info and pics.
Old Sep 16, 2023 | 02:35 PM
  #2087
snek's Avatar
snek
Heater Hose DIY#2
thanks!!
Old Oct 22, 2023 | 06:44 PM
  #2088
BxG3?'s Avatar
BxG3?
Swapped out the clock for the all important oil pressure gauge. Write up coming soon!
Old Oct 22, 2023 | 09:03 PM
  #2089
liquidfluidity's Avatar
liquidfluidity
can't wait! Always wondered why this gauge was never included....Thanks!
Old Oct 22, 2023 | 09:37 PM
  #2090
Broken_2008_G37's Avatar
Broken_2008_G37
https://www.tiktok.com/t/ZT8kS7nqD/
I installed the hard wiring kit for my fuel pump
Old Oct 28, 2023 | 11:26 AM
  #2091
CorvetteMongo's Avatar
CorvetteMongo
Engine Cover
Tried to dress up the engine cover. Had a heck of a time getting paint to lay down. Painted it the first time, then spent over 2 hours removing the paint cause 90% of it bubbled...and it was clean and prepped when I started spraying
. 2nd time didn't lay very good either but for now I'm going to call it good enough.
Old Nov 4, 2023 | 11:58 PM
  #2092
DB0037's Avatar
DB0037
Apologies for the long post.
Over the past month, installed a new exhaust system onto my RHD Japan imported Nissan Skyline 370GT Type SP.
Parts I went with:
  • Greddy Evo GT Catback
    • Only exhaust from a reputable brand compatible with a 4WAS module stuck to the back of the diff.
  • AAM Resonated HFC
    • They advertise that the HFC come with a J-bend O2 sensor bung to prevent CEL but mine didn't come with one? Didn't get a CEL so it doesn't really matter but it's a heads up for anyone who's looking to buy.
  • DC Sports Polished SS Headers
    • One of the only shorty headers that did not cost $2k+ and was quoted to fit RHD 370Z.
    • It did not fit a RHD G37 so one of the pipes was modified to clear the steering column bolt.
  • New O2 & Air/Fuel sensors
    • Both left side sensors were seized
    • Huge shoutout to Dalton and Nick from CZP for their customer service and advice.
Sound clip: https://drive.google.com/file/d/1yKg...usp=drive_link
Some photos of the installation process:
AAM RHFC
Steering column bolt hits the header, steering wheel was turnable but had alot of resistance.
Heated and moulded out of the way.
Old Nov 18, 2023 | 01:05 PM
  #2093
CorvetteMongo
Stillen Generation 3
I got the Stillen Generation 3 Cold Air Intakes on.
All Done
All Done
Stillen Going On Left Side, Stock On The Right
Stock Setup
Old Nov 18, 2023 | 02:24 PM
  #2094
No apologies necessary. That exhaust is beautiful. ​​​​​​​
Old Nov 18, 2023 | 07:31 PM
  #2095
Epiphany's Avatar
Epiphany
All Done
All Done
Stock Setup
Definitely not to my taste for the engine cover, but you should get the left stripper image flipped horizontally so she's facing the other side of the engine bay.
Old Nov 23, 2023 | 12:06 PM
  #2096
AdamBritt's Avatar
AdamBritt
On today's 'Tales from my DA PO': They cut the firewall grommet to run power for a subwoofer. I think I've tracked down my leak to right here so my question for everyone is should I be concerned about water coming to this spot during rains and what kind of goop should I seal it with? I know I should go all the way with the sunroof drains but pulling the trim apart and inspecting them they looked fine. I didn't tear apart any further to get to the engine bay side of the drain yet.
Old Nov 23, 2023 | 06:32 PM
  #2097
wrkls_'s Avatar
wrkls_
Stayed up installing these last night. First time installing any of these parts. Just want to say thanks to those of you who have helped answer questions, concerns, and given constructive criticism. It’s much appreciated. Slowly but surely she’s coming along.
Old Dec 6, 2023 | 01:14 AM
  #2098
wrkls_'s Avatar
wrkls_
Installed Z1 rear sway bar Whiteline end links and SPL rear camber arms.
Old Jan 15, 2024 | 07:40 PM
  #2099
vqbreezy's Avatar
vqbreezy
how to?
Swapped to a 2018 Q60 steering wheel (w/ airbag).
99.9% perfect fitment- little rubbing between 2 plastic trim pieces.
eBay. $200.
this is definitely a must, looks super clean, do you think you'd be able to do a how to or just an install to see whats different?
i drive a 2012 manual 6 speed coupe so im not in need of the paddle shifters, was thinking of either going oem q60 wheel or maybe an aftermarket carbon fiber wheel,
either way i still want to see if this is compatible and if so how would the heated steering wheel version work?
thanks!
  #2100
vqbreezy's Avatar
vqbreezy
how to?
eBay. $200.
thanks!
