Getting Ready GTM 2SC
Old Sep 7, 2013 | 04:05 PM
  #61
timp's Avatar
timp
Yah rub it in LOL. Looking like the end of the month before everything is done.
Old Sep 7, 2013 | 04:32 PM
  #62
grabba's Avatar
grabba
timp, I have installed GTM Stage 2 in my M37S this week. I don't drive my car yet, but I will next week.
I read a lot about 7AT issues with FI and I'm afraid about reliability of the transmission. I know I will have to do VB upgrade and install tranmission oil cooler.
I have some questions regarding you experience with driving your car:
Did you up transmission pressure line yourself or you use ECU map from GTM only?
Do you drive always in manual mode or in D mode?
What about high speed? Do you accelerate on high gears?
Thanks,
Robert
Old Sep 8, 2013 | 05:17 AM
  #63
SPDCRZ's Avatar
SPDCRZ
^^ Umm his cars not done yet Robert...
Ya timp, sorry to rub it in, but looking forward to see it when its all done. Let me know so we can all meet up in the group.
Old Sep 8, 2013 | 09:46 AM
  #64
warpeacelove's Avatar
warpeacelove
You can drive in D Mode as long as your cruising, but if you want to push it always have it in Manual Mode then and never Mash on it in 1st gear, and stay out of the High Gears 5,6,7 (Never Boost in those gear) just roll into them from the prior gears.
Old Sep 8, 2013 | 02:57 PM
  #65
timp's Avatar
timp
Thanks,
Robert
Have a look at this link from GTM....
http://www.gtmotorsports.com/Technic...ansmission.pdf
Read it over a few times. It will answer all your questions. Happy driving.
Old Sep 8, 2013 | 03:09 PM
  #66
timp's Avatar
timp
SPDCRZ For sure! I am hoping end of September. Just got back one of the SC as it needed a slight repair to one of the recessed bolts. GTM fixed it up quick and returned it back safe and sound. Good customer service.
Old Oct 16, 2013 | 03:17 PM
  #67
timp's Avatar
timp
UPDATE........ I have not had a lot of time to work on my project and because of a few fitment issues that are unique to the AWD I have been running into a few road blocks. Nothing that can't be fixed and I enjoy the challenge. Here is an example when it came to the P/S line from the pump to the rack. The intake piping does not leave any room for the stock P/S line so I had to make a new one. The picture on the left is a close up of the P/S pump with the line removed and you can see the banjo bolt. Not too much room!! The next picture you can see the comparison on the OEM and the new. I drilled and tapped the new banjo bolt so I could screw in the pressure sensor to keep everything tight. I will post some pictures once installed.
Attached Thumbnails Getting Ready GTM 2SC-ps-fitment-issue.jpg   Getting Ready GTM 2SC-modified-ps-line.jpg
Old Oct 17, 2013 | 08:29 PM
  #68
Vizard_87's Avatar
Vizard_87
Thanks for the updates! I'm subbing to this thread, it's very informative! I will hopefully SC mine next spring.
Old Oct 19, 2013 | 04:15 AM
  #69
SPDCRZ's Avatar
SPDCRZ
Taking your time timp? lol! Still waiting to see this thing one day. Let me know if its running before the end of the month. There is a decent meetup happening last Saturday of the month and it would be good to finally meet up and see your ride!
Old Oct 24, 2013 | 05:21 PM
  #70
timp's Avatar
timp
Sorry going to have to miss that one. I just got back the A/C lines and a few other parts will be posting some pictures soon.
Old Oct 26, 2013 | 09:14 PM
  #71
SPDCRZ's Avatar
SPDCRZ
Nice, well if you can make it tomorrow PM me and I will pass you the address.
Old Nov 5, 2013 | 05:37 PM
  #72
timp's Avatar
timp
Finally got back the modified A/C lines that were needed to go around the driver side intake tubing. Also I got the MAF pipes ceramic coated for durability. Slowly going back together.
Attached Thumbnails Getting Ready GTM 2SC-custom-a-c-and-ceramic-coating.jpg
Old Nov 20, 2013 | 05:59 PM
  #73
timp's Avatar
timp
More progress........ all the coolers mounted and the bumper beam fits like a glove. Next all the piping and S/C oil lines. Stay tuned
Attached Thumbnails Getting Ready GTM 2SC-oil-trans-sc-coolers.jpg   Getting Ready GTM 2SC-intercoolers.jpg
Old Dec 9, 2013 | 02:08 PM
  #74
timp's Avatar
timp
Getting close to finishing the project. As you can see the engine cover does not fit and will need a small amount of adjusting to fit over top the brace between the two superchargers. I will post some pictures after I have trimmed the plastic. Also the OEM windshield washer reservoir will not fit in the original location so I have decided to relocate in the trunk on the drivers side. I will post some more pictures once that is done.
Attached Thumbnails Getting Ready GTM 2SC-20131205_104836.jpg   Getting Ready GTM 2SC-20131205_104816.jpg
Old Dec 9, 2013 | 02:16 PM
  #75
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Sick build, buddy. Why would you hide your engine under a plastic cover? Let it all hang out!
