G37 7speed transmission reprogram
Old Aug 25, 2011 | 08:56 PM
  #661
Foon's Avatar
Foon
I'm planning on buying a g37 in the near future. Would you guys recommend getting a 5AT over the 7AT?
Old Aug 25, 2011 | 09:21 PM
  #662
Boomer-Bob's Avatar
Boomer-Bob
G37's only have 7AT's or 6MT.
Old Aug 26, 2011 | 12:29 PM
  #663
TinsleyC's Avatar
TinsleyC
Loarmistead: can you confirm which tsb was asked to your car? Does it say TSB10-075 on your work ticket?
Old Aug 30, 2011 | 09:00 PM
  #664
loarmistead's Avatar
loarmistead
I think it did. I don't have the ticket with me, but I'll check it tomorrow and report back.
Old Aug 31, 2011 | 11:31 PM
  #665
TinsleyC's Avatar
TinsleyC
I had mine done last week, honestly can't see/feel much difference. Almost seems like performance is down a bit but I don't see how that's possible.
It does seem to hold the gear just slightly more when accelerating normally, which is good.
I was hoping the engine braking while coasting from 50 MPH would lessen but it's about the same as it was before.
Will try DS mode tomorrow to see how that behaves...
Old Sep 1, 2011 | 08:26 AM
  #666
harp00n's Avatar
harp00n
it is true for sedans
'08 G37 coupe had 5AT or 6MT
Old Sep 1, 2011 | 11:22 AM
  #667
sniper27's Avatar
sniper27
the perception of performance loss is due to the tranny being more "tamed" now. the reflash mellows it out and it may seem like it is not as aggressive as before. this results in the smoother gear changes. that's what the dealer told me at least.
Old Sep 3, 2011 | 11:59 PM
  #668
loarmistead
My smoother ride is still holding steady. I got stuck in rush hour traffic yesterday, and the car didn't lag up, hesitate and engine brake me to death in the stop and go traffic. Hell yes.
As for the TSB on the invoice... I don't think it says. It has a line item indicating that TSB wok was done, but it didn't have the number of the TSB in this thread next to it. It had a number containing 0s and a 9. I typed it into Google and the TSB for the squealing brakes came up... but nothing about the transmission. So I'm not sure if they typed in the wrong number or if that number on the receipt is a system number unrelated to which TSB they performed.
Old Sep 5, 2011 | 06:53 PM
  #669
milogalt's Avatar
milogalt
Close to 12K miles on my 2011 G37 Sedan (bought in Oct 2010)...went for my (second?) service, and mentioned about harsh downshift (bump from 2nd to 1st) in transmission...service sheet showed ECU reset was done and ITB 10-075 performed/applied...
Have to say there is a distinct positive difference in the 'smoothness' of the transmission...dont think I have seen a lag or any other problem in any other aspect of the transmission (its just been 150-odd miles since, though)...
Thanks to everyone on this thread for contributing detailed and helpful inputs...much happier driving my car now...
Regards
Anant
Old Sep 6, 2011 | 01:12 AM
  #670
taek's Avatar
taek
after ECU reset and ITB10075 on my 09 g37 w/ 20,000miles, it feels much smoother, it feels like it is a different
Old Sep 6, 2011 | 10:57 AM
  #671
dseltz's Avatar
dseltz
My dealer said that the ECU update would make my car less responsive and that Infiniti was working on another update. He suggested I wait a month. Has anyone heard that?
Dave
Old Sep 6, 2011 | 04:30 PM
  #672
Almatti's Avatar
Almatti
dseltz, when I brought my 2010 G37X in for a consumers Affairs complaint (the story is well documented in here), the District Manager (DM), who confirmed in the test drive with me that the quirkiness / lagging exists in the 7AT, indicated that "Infiniti is looking at another possible update - Fix, but can't promise that"....
Old Sep 14, 2011 | 04:31 PM
  #673
dvuong85's Avatar
dvuong85
I just purchased a new 2011 G37s a little over two weeks ago and have just under 1K miles on it. I too have noticed some jerking at lower speeds and some lag when I gas it, especially when I am at a full stop or trying to merge onto the freeway. Occasionally, I'll see the RPM jump just slightly. I just called the dealer today and mentioned this to them. They said that this is normal behavior for new cars, up to 2K miles due to the adaptive learning of the driver's habits. If after 2K miles or at my oil change I'm still having these issues, they'll take a look at it.
Are the blowing smoke up my *** to avoid dealing with the issue or is this normal?
Old Sep 14, 2011 | 07:32 PM
  #674
sneakers's Avatar
sneakers
What you experiencing is "normal" in a bad way as this happens to quite a few of us. I have 2009 G37Sx sedan and I am the lucky few that had the TSB updated and it did minimize the harsh shifting greatly (dont even notice it now). The TSB does not address the "lag" (someone correct if I am wrong). However, maybe a hypertech? See my review on it. Knowing what I know now, I personally would not apply the update.
https://www.myg37.com/forums/engine-...got-it-32.html
Old Sep 14, 2011 | 08:33 PM
  #675
cy7878's Avatar
cy7878
My 2011 G37 is okay with down shift when it's going straight. The problem I have is when I am making a low speed (20-30 mph) right turn, the down shifting won't happen for up to 2 seconds with the gas half way pressed. when it does downshift, I often will see the ETC light blinking. I wonder if the down shift lag is really the engine cutting power because it's sensing tire slipping.
I'm getting better tires next week (Pilot Super Sports) and I'll see if that helps.
