G37 7speed transmission reprogram
Old Mar 22, 2016 | 02:43 PM
  #2491
Requin6's Avatar
Requin6
Originally Posted by Cwhouar
Does anyone know how long this reflash takes to perform?
Had this done along with the analog clock replacement in roughly an hour at the Infiniti dealer.
Old Apr 23, 2016 | 08:29 PM
  #2492
shakspereg37x's Avatar
shakspereg37x
I have a 2012 G37x auto 47k miles on her. Anyone experiencing a clunk or "like hitting a pothole for a split second" or, one guy described it perfectly as, "if for a split second the car hits a brick wall". Also, a "thud" feel happens. But both descriptions accompany a split sec loss of power at the same moment. So im not sure it can be suspension related. It is so fast its really hard to explain. I noticed it 2 times while my girl was driving this morning, once accelerating and once decelerating. I experienced it again the a bit later today but hours later after I started her up and about 5 minutes in, I was accelerating. All times while at stop into an accel. and a low speed decel.
I was driving it the night before in manual mode pretty happily I will say (fast and not really furious, I live in NYC.) I hadnt done that before. Ive had the car for a couple of months and no real shifting issues. Pretty happy. Im just worried about this all of this sudden. Any one?
Im posting here because it sounds close to what im experiencing other than the jolt feeling for a split second. Very hard to explain. Any thoughts before I create my own thread would help!
Thanks!
Old Apr 24, 2016 | 06:35 PM
  #2493
Vicious37x's Avatar
Vicious37x
The transmission and throttle response learns and adapts to driving style.IF you're in nyc then you must experience a lot of traffic.Driving the car slow in stop and go traffic slows down throttle response making it sometimes slow and unpredictable when you need. Only temporary remedy is to go hard on the gas pedal after you reset the cpu. I went to multiple dealers reflashed the ECUplenty of times and even the technicians have the same issues with their infinitis. The thud you described could just be transmission hard shifting. The tranny is not at all smooth and sometimes it will shift hard.
Old Jun 7, 2016 | 01:33 PM
  #2494
sho423's Avatar
sho423
Does a 2013 need this reprogramming?
Old Jun 7, 2016 | 01:44 PM
  #2495
Ricio1991's Avatar
Ricio1991
I don't think so they should already come updated
Old Jun 7, 2016 | 02:25 PM
  #2496
ColumbiaSkinny's Avatar
ColumbiaSkinny
I have a 2013 7AT and it shifts/acts perfectly fine. Yours should be good....
Old Jun 7, 2016 | 03:28 PM
  #2497
solidsilver's Avatar
solidsilver
Same here.
Old Jun 9, 2016 | 12:44 AM
  #2498
sho423's Avatar
sho423
I don't think its smooth. It has its days where it shifts hard.
Old Jun 9, 2016 | 02:19 AM
  #2499
My 2010x coupe 7AT shifts hard from 3rd to 4th gear and I was always worried it was my trans. about to go till I did some research and realized it's a common Infiniti issue unfortunately. And if I'm on a slight hill and put it into reverse I feel it jerks way to hard but once again something normal. My only complaint about these cars for sure.
Old Jun 24, 2016 | 01:45 PM
  #2500
kdawg8526's Avatar
kdawg8526
just had one of my buddies at dealership do the latest update thinking it would make it shift faster or something but now 3rd to 2ng gear down shift is really jerky. anybody else have this issue on latest update
Old Jun 24, 2016 | 07:07 PM
  #2501
Kb Cool's Avatar
Kb Cool
I had the 027 update done on my '10 and it still was never perfect. For some reason the transmission in my '13 is much better. Maybe they did something different other than software in the 2013 models? Or it's hit and miss? IDK
Old Jun 26, 2016 | 11:14 AM
  #2502
ryanwhite74115's Avatar
ryanwhite74115
Originally Posted by solidsilver
Same here.
I have a 2013 and just brought it into the dealership noting a little bit of transmission gear hunting. Apparently there was a code on the transmission module for manual mode only and there was a software update. Improved the shifting logic IMO by 25%. I am elated that it was updated.
Old Jun 27, 2016 | 12:14 PM
  #2503
mjnoles1's Avatar
mjnoles1
How were you driving when the transmission did the gear hunting? It seems when I am in DS mode and I am slowing down to a stop my transmission makes the sound like I am slowing down in too high a gear, though I am not using the manual mode gear shifter or paddle shifters on steering wheel. I am just using automatic in the DS mode.
Old Jun 27, 2016 | 02:10 PM
  #2504
ryanwhite74115
I was normally in DS (automatic) mode. I mean, regular D mode is lazy and for economy purposes...it's always slow there. DS would 80% of the time be spot on and do the gear shifting or holding or downshifting great...but a few times it would go wonky on me. This update (unknown what version) fixed it. Free update since under 60k.
Old Jun 27, 2016 | 02:43 PM
  #2505
mjnoles1's Avatar
mjnoles1
Is what I was describing, what you experienced and the reason you got the update?
What I was experiencing was in DS automatic mode, and when slowing down the car made the revving sound, as if I was in too low a gear to slow down to the speed I was going. Is this what you experienced?
