Interior cleaning newbie
Old Jun 4, 2010 | 12:34 AM
Sytrash's Avatar
Sytrash
Good stuff! Thanks. So, do u know that Vinylex contains DMS silicone? If yes, could u forward me the info?
Old Jun 4, 2010 | 10:10 AM
Dan1's Avatar
Dan1
I emailed them. Vinylex is water based and does not contain any petroleum products.
Old Jun 4, 2010 | 09:58 PM
Sytrash's Avatar
Sytrash
So, does it mean that it's at least ok to use then? We don't have to "so call avoid" all silicone products, it's the specific petroleum kind that we should avoid. Dose that change your mind of Vinylex?
Old Jun 5, 2010 | 10:52 AM
Dan1's Avatar
Dan1
I'd still recommend 1z cockpit premium and 1z rubber/ vinyl because they both work great. Obviously I've never used Vinylex before. But it seems safe.
Old Jun 5, 2010 | 08:21 PM
Sytrash's Avatar
Sytrash
Dan,
Enjoyed the discussion w u. Made me go look up stuffs.
On a diff subject, I am currently using one of those super absorbing sheet, from Armorall I think, to do the initial drying after wash. Is that bad?
Sy
Old Jun 5, 2010 | 08:30 PM
Dan1's Avatar
Dan1
If its the type of sheet/ towel Im thinking of, than yes. You want to use a high quality microfiber towel. However, when the car is properly sealed or waxed, using the correct soap, and the flooding method, then all you need to dry is a electric blower- whether it is a leaf blower or shop vac.
I vary rarely pull out my MF drying towels.
Old Jun 5, 2010 | 09:11 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Originally Posted by Sytrash
Dan,
Sy
Definitely DON'T use that. It has no way of pulling the contaminants away from the paint so all you do is mar the paint. Sheet the water after washing and you can dry the entire car with 1 MF waffle towel. (or use a blower as ^^suggested)
Old Jun 7, 2010 | 06:05 PM
Sytrash's Avatar
Sytrash
Maybe I wasn't doing it right, I tried water sheeting first. I wasn't that dry, so the next time I changed to one of those sheet...I guess I will try water sheeting again...
Old Jun 7, 2010 | 06:51 PM
Dan1's Avatar
Dan1
This is how you do the flooding method, YouTube - Wet Obsession Wax Drying
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
Irishcurtis
Sep 30, 2015 11:39 AM
