My RB Project, going all in!
Old Nov 17, 2014 | 12:39 AM
  #661
alfredo24pr's Avatar
alfredo24pr
Originally Posted by G37Sam
Thank you sir, I kept two FI mufflers for that purpose. You can definitely tell a difference between it and a VQ in person though. I'm organizing a drag night in January, will get a few runs in
Awesome. I will be testing out my mods at the drag strip by that time as well.
Old Nov 17, 2014 | 06:20 AM
  #662
mikey_mike's Avatar
mikey_mike
Yeah I think that's what my shop is doing as we speak. He's putting a 2bar guarantee too haha
lol, i hope he's gonna test it to give you that kind of guarantee!
isn't it true that the pressure before the throttle body is higher than after it and that a gauge showing the pressure of the manifold (boost/vac) is going to show a lower pressure because of this? ask him if his 2 bar guarantee is before the throttle body lol
Old Nov 17, 2014 | 07:45 AM
  #663
PongSanity's Avatar
PongSanity
Originally Posted by mikey_mike
That's probably not the best idea because you're reducing the total smooth surface area for the coupler to grab. If you keep the pipe smooth and spray something sticky on the pipe and coupler (like hairspray) it will hold better but really the best solution is to tack weld some raised spots on the end of the hard pipe for the clamp to butt up against so it cant slide. Or even better a bead roller. Here's a google image search showing a few different solutions and even tools to do the job: https://www.myg37.com/forums/**************/5G22o1
The vice grips is one i've heard many people using in the past to make their own pipe beads.
I feel you. We changed the charge pipe shortly after to a bigger size with the pipe beads already on there. Was just trying something to keep the pipe from blowing off lol. It kinda worked because it didn't blow off again.
Old Nov 17, 2014 | 02:31 PM
  #664
mikey_mike's Avatar
mikey_mike
I had a similar problem lol. Kept blowing my charge pipe off at 15-18 psi because someone had cut it to make it longer by inserting a coupler at the cuts.
I was on my way to the local airport one day to get avgas (dumb idea but i was younger then) and I blew the coupler off and I freaked out haha. I had no idea what happened.
Anyway I cleaned the pipe REAL good and hair sprayed it to make it stick for the time being.
What did your friend drive?
Old Nov 17, 2014 | 04:50 PM
  #665
PongSanity's Avatar
PongSanity
Honda civic currently boosted at 480 whp. .. we welded all the elbows and mid pipes together to eliminate the need of all the couplers and lower the chances of pipes blowing off. Only places not welded are the intercooler, turbo and throttle body. Vtec power ftw!
Old Nov 18, 2014 | 05:13 AM
  #666
mikey_mike's Avatar
mikey_mike
lol hondas
Old Nov 25, 2014 | 04:12 PM
  #667
G37Sam's Avatar
G37Sam
So I've been raping the car a little ever since I got the high boost tune done. Notice a little coolant leak and the exhaust sounding a little funnier.
Sent her in for a check and surprise, the water pump has taken a dump. There was also a crack in the turbo manifold.
Lesson learnt, never cut corners. I bought a replica turbo manifold locally for $220 because I didn't want to spend $1500 on a decent crack-proof manifold. Two manifolds later, it definitely proved it cannot withstand the heat. The used water pump I had in was a gift from a friend who wanted to support my swap. Going with a Nismo N1 waterpump now. What doesn't kill you only makes you stronger eh!
Old Nov 25, 2014 | 06:50 PM
  #668
PongSanity's Avatar
PongSanity
As a wise honda man told me. .. "spend once. ... cry once"
Old Nov 26, 2014 | 12:50 AM
  #669
G37Sam's Avatar
G37Sam
"Wise honda man" is an oxymoron broooo hahaha
Old Dec 13, 2014 | 03:10 PM
  #670
G37Sam's Avatar
G37Sam
Christmas is here early!
RB26 N1 waterpump:
Figured I'd throw in some adjustable cam gear goodness from Tomei while the timing belt is off
And another beauty that will be wasted hidden in the engine bay, lifetime warranty against cracking
Old Dec 22, 2014 | 01:07 AM
  #671
G37Sam's Avatar
G37Sam
And here's what an RB does to cheap Manifolds and Gaskets
Old Dec 22, 2014 | 05:00 AM
  #672
dtea54's Avatar
dtea54
Sex ! Holy f
Old Dec 24, 2014 | 02:10 AM
  #673
G37Sam's Avatar
G37Sam
And of course, the manifold is too big for the G37 engine bay. Going to have a look to see what'll need to be modified otherwise that piece of art will be sold to one lucky son of a gun.
Old Jan 8, 2015 | 05:25 AM
  #674
G37Sam's Avatar
G37Sam
Custom Manifold in the making!! Lets hope this will be my last one.
Old Jan 10, 2015 | 01:22 AM
  #675
Presto's Avatar
Presto
Last 2 months of cooler weather, get this car back on the road Sam
