Old Mar 21, 2019 | 11:27 AM
  #1066
skrolz's Avatar
skrolz
Originally Posted by TwistedIllusion
You should be fine with that setup, only reason my rears rub is I have a 5mm spacer on +35's on the rear Without the spacer they would be fine. I only run the spacer for more flush look.
I took that into consideration with the comparison pics above (i have the offset at 30, not 35). My setup at +25 will stick out 5mm MORE than yours with the spacer. I'm planning on running smaller tires (245/255), so I hope I'm ok.
Old Mar 21, 2019 | 08:48 PM
  #1067
PNW_IPL's Avatar
PNW_IPL
And im done.
18x9.5 +28 front 275/40
18x9.5 +38 rear 275/40
Old Mar 22, 2019 | 08:37 AM
  #1068
zaz's Avatar
zaz
Originally Posted by PNW_IPL
And im done.
Curious, why a more aggressive offset in the front than the rears? To clear the calipers?
Old Mar 22, 2019 | 10:09 AM
  #1069
PNW_IPL's Avatar
PNW_IPL
correct. Effective is 28 with the 10mm spacer to clear akebonos.
Old Mar 25, 2019 | 01:25 AM
  #1070
Gqaceone's Avatar
Gqaceone
Originally Posted by Gregor12
what springs did u use to drop it?
Old Apr 3, 2019 | 10:25 AM
  #1071
skrolz's Avatar
skrolz
I posted here about a week ago and got the "OK" from blnewt on the following setup:
2013 G37xS coupe w/ Eibach Pro Kit springs (very lightly daily driven)
20x9.5
+25
255/35/20
I've received the wheels and am about to pull the trigger on the tires. Before I do so, are 245/35/20 or 255/30/20 viable options as well? I'm really paranoid about rubbing, and I was wondering if picking up smaller tires would be a better option. 255/30/20 would mess with my speedo reading, but if that's the only issue, I don't mind it at all (if it messes with the computer and/or causes other problems, then I'm concerned). Alternatively, is 245/35/20 too much of a stretch for 9.5?
255/35/20 are the optimal option in my book. If I can confirm that these won't rub, they will get copped. Otherwise, I'm wondering if one of these other options would work.
I appreciate all the help!
p.s. I search and skimmed through multiple wheel threads and could not find anyone with a 20x9.5+25 square setup to confirm; I looked. Maybe my search skills suck...
Old Apr 3, 2019 | 04:15 PM
  #1072
You can run a 245 on a 9.5, but no issues running 255/35 (I'd run them over a 255/30 for closer to OEM diameter).
Here's a G37x coupe running 20x10.5 +25 on 275/30s you'll have about 13mm more room at the fenders than him.
https://www.myg37.com/forums/brakes-...ml#post3891573
Old Apr 30, 2019 | 09:23 PM
  #1073
skrolz's Avatar
skrolz
Dropping a confirmation and a huge thanks to blnewt for advising. Just put these on a few hours ago. Extremely happy
Konig Oversteers (Opal)
20 x 9.5 +25, 255/35, squared
Eibach Pro Kit lowering springs
(no spacers, no fender work, clears Akebonos)
Old Apr 30, 2019 | 09:29 PM
  #1074
TwistedIllusion's Avatar
TwistedIllusion
Congrats on the wheels, nice looking setup and great fitment
Old Apr 30, 2019 | 09:31 PM
  #1075
Shane D's Avatar
Shane D
Beautiful wheels AND car
Those wheels look really good. Bet they're nice and light too. Or as light as 20's get.
Shane D
Old Apr 30, 2019 | 10:48 PM
  #1076
Nice to see that setup up & running Skrolz, I like those logo center caps too, nice touch! Glad you're happy
Old Jun 3, 2019 | 10:07 PM
  #1077
EXTREMEFUN1300's Avatar
EXTREMEFUN1300
2013 X
Q50 19x8-1/2 PVD black chrome wheels
Toyo Proxys 4+ 255/40-19 all around
Stock springs / ride height
No issues whatsoever
Old Jun 6, 2019 | 10:32 PM
  #1078
Tytruth's Avatar
Tytruth
Would i be able to run 19x9.5 +20 on a 2011 non sport sedan or is that too aggresive? If i could, what size tires should i get? The wheels are rohanna rc10 btw
Old Jun 7, 2019 | 08:24 AM
  #1079
Too aggressive, a 9.5 +35 is flush.
Old Jun 7, 2019 | 09:09 AM
  #1080
Tytruth's Avatar
Tytruth
Damnn, thats disappointing to hear. I really liked these wheels & a good price too. Thanks for the info i guess i'll look else where.
