Old Aug 18, 2017 | 09:16 AM
  #841
rj_22's Avatar
rj_22
ok, question(s).......I have a staggered set up of vossen cv3r's on the sport coupe right now. I tried the rear 10.5 +45 up front and it didnt clear. Now I want a squared set up. I would love to run 10.5's up front. So what im looking at is:
20x10.5 +22 or +40.
I wouldnt mind running the 275/30 combo too. I saw the other guy in the thread running the 20x10.5 +25 with the 275/30 combo. Maybe its his spoke design thats helping him out.
Any suggestions? Will it work? Should I go more conservative?
Old Aug 18, 2017 | 02:15 PM
  #842
20x10.5 +22 or +40.
Might see if a spacer will help you clear the brakes and still be able to run them without fender problems before trying new wheels, something that gets you in the +30 range so a 15mm on your +45s will work, I'd give that a try first. And if they don't you could run those spacers in back to get the rears more flush.
Old Aug 18, 2017 | 07:19 PM
  #843
rj_22's Avatar
rj_22
Cool. I'll give that a shot. I'll buy some washers and measure out how many I would need to clear the front brakes. Might not need many. But I plan on selling the cv3r's anyway and doing 20x10.5 +35 all around. Do you recommend the 275/30 tire?
Old Aug 18, 2017 | 09:01 PM
  #844
Yeah, on a 10.5 that's about the narrowest tire I'd run and should still look good and provide decent clearance at the fender.
Regarding spacers, the 15mm would be the narrowest you could run as a bolt-on, anything over 5mm to under 15mm would require longer wheel studs which will add a failr amount of labor, that's the main reason I suggested the 15mm, and should give you an offset that you can live with.
Old Aug 19, 2017 | 08:11 AM
  #845
rj_22's Avatar
rj_22
So 15mm all around or just the rear?
Old Aug 19, 2017 | 08:50 AM
  #846
You were saying you wanted to get a square 10.5 setup so you'd need new 10.5s to replace the narrower front wheels. If you end up getting the same 10.5 +45s (assuming those 15mm give you the clearance AND the look you're after) for the fronts you'd want those spacers all around for a uniform look at the fenders.
Another thing to keep in mind, you'd probably need a fair amount of spacing to clear the front upper section of the steering knuckle, so a 15mm spacer should cover both bases, the knuckle and the calipers
Old Aug 19, 2017 | 09:51 AM
  #847
rj_22's Avatar
rj_22
oh no! I think we got mixed up a little. I'm selling the staggered set now. I'm going to buy a new set of 20x10.5 +35 all around.
Will this clear the front knuckle/sport brakes? Still good on tire size (275/30)? Or should I see if I can ull off the 255/35/20? I know I could still space the rear some to give the staggered look also.
Old Aug 19, 2017 | 07:35 PM
  #848
What wheels are you going with this time around? It depends on the spoke design and backspacing regarding caliper clearance. You'll be ok at the steering knuckle w/ the +35 offset.
Old Aug 19, 2017 | 08:26 PM
  #849
rj_22's Avatar
rj_22
I'm gonna go with the aodhan ls007. Basically the same wheel as the avant garde m580. This wheel:
https://www.aspiremotoring.com/produ...atte-gun-metal
Old Aug 19, 2017 | 08:28 PM
  #850
rj_22's Avatar
rj_22
I'm gonna go with the aodhan ls007. Basically the same wheel as the Avant garde m580. This wheel:
Old Aug 19, 2017 | 09:56 PM
  #851
future62's Avatar
future62
I feel like any wheel will clear at 10.5 +35, unless it has some serious deep dish action.
Old Aug 19, 2017 | 10:10 PM
  #852
rj_22's Avatar
rj_22
I'm going with the aodhan ls007. Basically a knockoff of the Avant garde m580.
Old Aug 20, 2017 | 12:16 AM
  #853
It's never a bad idea to confirm BBK clearance w/ the vendor, if they don't know see if you can send them these templates (only need the bigger front one). Even though they should clear, those Akebonos are a very fat caliper vs. the bigger but flatter Brembo 6 pots.
https://www.myg37.com/forums/brakes-...templates.html
Old Aug 20, 2017 | 03:10 PM
  #854
future62's Avatar
future62
What color? That's gonna look pretty sick!
Old Aug 21, 2017 | 09:09 AM
  #855
rj_22's Avatar
rj_22
Probably gunmetal. Or black
