Old Feb 11, 2016 | 07:00 PM
  #376
Originally Posted by evil-G-nius
Makes a little sense. So essentially the wheel I want wont sit flush with the hub. The spacers will move the wheel out but fit flush with the hub. I still need the adapter to have THAT fit flush with the back of the wheel. So it sounds like it would be: spacer>adapter>wheel.
Did I get it? LoL
We've got a bingo! There may be a way to get a custom hubcentric spacer w/ the Infiniti bore where the spacer meets the hub and where the hubcentric outer part of the spacer would fit a certain aftermarket wheel bore. Not sure if possible but might contact Charles@B2Autodesigns and see what he says, they have their own quality spacers and may be able to do custom setup.
Old Feb 12, 2016 | 05:48 PM
  #377
evil-G-nius's Avatar
evil-G-nius
Cool thanks!
Old Feb 19, 2016 | 04:31 PM
  #378
jee-sedan's Avatar
jee-sedan
perfect!
Cool!
My new setup:
STR 607 19x8.5 +30
Continental Extreme Contact DWS 06 245/40/19
The only thing I notice going from 18" to 19" is that I hear the expansion joints in the street a lot more as I drive over them. Other than that I really like my setup.
Attached Thumbnails HELP~All squared setups please post here!-new-wheels-small.jpg
Old Feb 19, 2016 | 07:00 PM
  #379
Originally Posted by jee-sedan
Cool!
My new setup:
STR 607 19x8.5 +30
Looks pretty good for not being lowered, wheels look proper on that sedan too, decent choice there
Old Feb 19, 2016 | 07:35 PM
  #380
jee-sedan's Avatar
jee-sedan
Thanks! I didn't want anything extreme, just a tasteful update for a nice daily driver.
New wheel day is so much fun!!! lol
Old Feb 20, 2016 | 08:52 PM
  #381
californiadre's Avatar
californiadre
Hey Guys,
I have a Q60 RWD. I'm interested in getting the RPF1s in 18" square setup. What would you guys suggest for width, offset, and tires? For tires I'm kinda sold on Potenza RE71Rs.
These are the sizes they had on their website:
As far as lowering it, I'm gonna use this car for the canyons a lot so I don't wanna be slammed, I'm thinking Koni shocks/ Swift springs? Any insight on this would help too!
Thanks!
Old Feb 21, 2016 | 12:30 AM
  #382
Originally Posted by californiadre
Hey Guys,
Thanks!
Depending on how much tire you want to run you could go w/9+35/9.5+38/10+38, the tire sizes in those RE71Rs are quite limited, there's only one size (the 245/45/18) that's close to OEM diameter. If that's not a concern then running the 255/40 and 275/35 would be options, but the 275/35 is about an inch shorter.
Do you have the big Akebono Sport brakes? If so you'd have to confirm clearance, I believe they will clear but always confirm when ordering.
The Hankook Ventus RS-3 Version 2 comes in a 265/40 which would be a great choice on those 9.5 & 10" widths
Nitto NT05 is available in the ideal 275/40 which is almost exactly the same as the 245/45 diameter which is very close to OEM diameter, it ='s a max performance summer not an extreme performance summer. Several guys on the site w/ SC motors use them.
FWIW, here's Lt8ches coupe on 18x9.5 +30 running 265s, this would be almost the same fender fit as running 9.5 +38 on 275s but you'd have about 2mm more wiggle room He's on an Eibach spring drop.
https://www.myg37.com/forums/brakes-...ml#post3815735
Old Feb 22, 2016 | 02:14 AM
  #383
californiadre
Thanks for the info! I think I'm gonna go with 18x9.5 +38 with the RS-3s in 265/40.
I don't have the Akebono brakes but I plan on getting them later.
Do you think I would need to roll my fenders if I'm dropped on swift springs?
EDIT:
I just checked TireRacks site. They have the RS-3s in 265/35, they also have RE-71Rs and RE-11s in the same sizes. If a 265/35 would fit I would rather buy the RE-11s. Please let me know. Thanks!
Old Feb 22, 2016 | 08:49 AM
  #384
EDIT:
That link above on Lt8ches coupe shows that you'd have plenty of clearance since he's running the same width wheels and same width tires but on 8mm more aggressive offset. No fender work would be required, if there would be any rubbing it would be on the rear fender bracket but w/ that extra 8mm in your pocket you'll be ok.
As far as the 265/35, that's 1.38" smaller in diameter or about 5.5% different than OEM diameter. There's guys on the Z boards that run smaller tires on the track to get the stiffer sidewalls and give themselves better launches since it essentially changes your final drive ratio, but I wouldn't recommend such a drastic change for daily driving.
Might check the Bridgestone site or contact Neal@Tirerack and see if they happen to make either of those tires or possibly another brand that you like in the 265/40 size.
Old Feb 22, 2016 | 02:31 PM
  #385
TannerG's Avatar
TannerG
Cool!
My new setup:
STR 607 19x8.5 +30
I like your set up. I plan on having something similar to this. How do you like those wheels?
Old Feb 22, 2016 | 07:51 PM
  #386
G37xsfun's Avatar
G37xsfun
STR 610 19x10 40 offset
Yokohama Advan 255/40
Fender to ground 26.2
-1 front camber
-2 rear camber
Old Feb 22, 2016 | 08:20 PM
  #387
the93owner's Avatar
the93owner
^ looks great! Did you have to roll your front fenders?
Old Feb 22, 2016 | 08:29 PM
  #388
G37xsfun's Avatar
G37xsfun
No fender work but we will see now it works this low. Drove it a lot today with no rubbing!
Old Feb 22, 2016 | 09:33 PM
  #389
Those STRs have a nice concavity to them, looking like a good fit, little snug up front, might have to flat roll the front fenders at that height, but that's a simple fix.
No center caps??
Old Feb 26, 2016 | 06:32 PM
  #390
guy from norcal's Avatar
guy from norcal
Varrstoen 19x9.5 +40 all around. 5mm spacer up front for +35
tires are 245/40 front 275/35 back
