Old Sep 11, 2015 | 09:47 AM
  #241
the93owner's Avatar
the93owner
Originally Posted by VA_55
19x10.5 square 235/35 +22
How much camber you need to run to fit those? Fenders pulled?
Old Sep 12, 2015 | 12:58 AM
  #242
Gregor12's Avatar
Gregor12
These are pretty much square. They will be when I put a 5 mm spacer up front
19x10 +45 front
19x10 +40 rear
255/35/19 all around
Eibach springs
*19x10 +40 is a perfect square setup if you're looking to leave enough room not to rub and not to poke out too much*
DO NOT GO HIGHER THAN A +45 in the front if you have a ten inch wide wheel. You will rub on the front spindle or whatever it's called
Old Sep 12, 2015 | 01:25 AM
  #243
VA_55's Avatar
VA_55
Natural camber, no fender mods no and camber kits reqrd.
Old Sep 12, 2015 | 08:23 AM
  #244
Nice fit Gregor, looks like you did your homework That upper section of the steering knuckle can cause problems w/ too much positive offset, glad you pointed that out. It's even worse for 17 or 18" wheels as it has that drastic curve that really gets in the way for smaller diameter sets.
VA55, post more pics when you can, great job w/ those 10.5s.
Old Sep 12, 2015 | 05:11 PM
  #245
Gregor12's Avatar
Gregor12
Thanks man. And yes! The 19s are right in the deepest part of the curve! If I turn the wheel all the way I think it rubs just a little bit. Going to add some spacers and studs in the front.
Phil
Old Sep 19, 2015 | 05:14 PM
  #246
JRW370's Avatar
JRW370
Smile
I'm really liking that look Gregor! What wheels are those and how much are you dropped on the Eibach springs?
Old Sep 19, 2015 | 07:51 PM
  #247
Gregor12's Avatar
Gregor12
The wheels made by klutch! Model km20
And I believe it was something like 1.2 front and 1 rear. Can't remember though
Old Oct 1, 2015 | 02:43 PM
  #248
VaderK52's Avatar
VaderK52
Im looking to buy these wheels. http://www.elementwheels.com/proddet...090verdev39sil
Currently lowered on Tein S Techs on front and Eibach Pro on rear. What offset would make it flush 32mm or 38mm. Im looking to go square setup 245 35 20" tires.
Old Oct 2, 2015 | 01:32 AM
  #249
Gregor12's Avatar
Gregor12
Those will look really clean in my opinion. What do you consider flush? Haha. Also. Check eBay. There's a wheel dealer on there that sells these at a better price.
Old Oct 2, 2015 | 02:58 PM
  #250
VaderK52's Avatar
VaderK52
link it up breh....im lazy Seriously though cause im coming up empty in my search.
Old Oct 20, 2015 | 02:44 PM
  #251
alexnguyen326's Avatar
alexnguyen326
Phil
so there is no rubbing issues? and what about your turning radius is it bad?
Old Oct 22, 2015 | 04:57 AM
  #252
Gregor12's Avatar
Gregor12
No Rubbing issues. Only if I turn all the way to the right. And pull the steering wheel harder. Other than that I have no issues. A 10 inch wide wheel with a +40 is perfect in my opinion
Phil
Old Oct 22, 2015 | 05:01 AM
  #253
Gregor12's Avatar
Gregor12
I searched verde parallax and it popped up with 417 items haha
Old Oct 22, 2015 | 05:06 AM
  #254
Gregor12's Avatar
Gregor12
Ask and you shall receive my child
http://www.ebay.com/ulk/itm/351550932820
Old Oct 30, 2015 | 03:58 PM
  #255
Richard Hui's Avatar
Richard Hui
Awesome my first sticky! Thanks blnewt!
Need one solid data base for squared setups, they can range from mild to aggressive~ coupes, sedans & convertibles, RWD & AWD. Just PLEASE post all wheel & tire specs and if spacers were required, and if you have big brakes please note that also (in case it isn't obvious in the pictures).
Thanks!
All the set ups mentioned in this post have 245/40/19 tires on.
2008 G35x Sedan
-SPC Front and rear camber kit
-BC coilovers
Here are some pix of the 19x8.5 +25 did not have BBK on when i had these wheels but i have read they do clear BBKs
221802_1431848799427_8199700_n by Chinkychoy, on Flickr
225503_1431849119435_1793352_n by Chinkychoy, on Flickr
322631_1515728936378_4961722_o by Chinkychoy, on Flickr
330677_1515728456366_600262_o by Chinkychoy, on Flickr
19x9.5 +35 Clears BBK
561371_1820076784884_1210114315_n by Chinkychoy, on Flickr
552245_1820074824835_119251252_n by Chinkychoy, on Flickr
541527_1820076064866_1765424382_n by Chinkychoy, on Flickr
575956_1820075904862_509707529_n by Chinkychoy, on Flickr
Current set up 19x9.5 +25 Clears BBK
10314494_2419763776684_2341381185400099994_n by Chinkychoy, on Flickr
11133905_2717611302686_5258669668343993363_o by Chinkychoy, on Flickr
10306772_2335447548831_3041534659019836784_n by Chinkychoy, on Flickr
10277806_2335446268799_2158936293845123863_n by Chinkychoy, on Flickr
10245420_2335447388827_3347291005346253983_n by Chinkychoy, on Flickr
*Edit - added BBK info
CC-- love that you have had different setups. Im putting on my coilovers next spring and in the process of buying wheels. I am looking at the Work Kiwami 19x9.5 +38 or the 19x9.5 +25 squared setup with 245/40 tires. Since you have experience with basically both sizes, what would you recommend for a dd/ keeping a good 1.5 inch gap between tire and fender. And for treadwear id like to keep it around the lower end of OEM camber spec (-1.2 to -1.4). I don't have BBK yet, and i know the +38 will not clear without spacers. Opinions? Thanks in advance
also, would like to be as flush as possible without rubbing.
