Old Jul 27, 2015 | 09:03 PM
  #181
dbeachy1's Avatar
dbeachy1
Just installed my new TSW Nurburgring 19x9 +30mm wheels w/Michelin MXM4 245/40-VR19 tires:
Still looking into a 1" drop via coilovers, but gotta find some that are quiet.
Old Jul 27, 2015 | 09:29 PM
  #182
jman09's Avatar
jman09
curious what made you go with the Michelin MXM4's?
Old Jul 27, 2015 | 11:24 PM
  #183
dbeachy1's Avatar
dbeachy1
I drive it year-round, so I wanted tires with good cold-weather grip, ride comfort, and low noise, so after a lot of research I went with the Michelin MXM4s (this is actually my second set). I don't drive it in heavy snow (I have a Ford Explorer for that), but based on previous experience I don't like driving with summer tires in really cold temperatures -- they get hard as a rock. If I lived in a warmer climate I'd have gone with Michelin Pilot Super Sports.
Old Jul 28, 2015 | 08:48 AM
  #184
And you won't have to buy another set for a long time too
New wheels look very nice
Old Jul 28, 2015 | 09:44 AM
  #185
i heart ricers's Avatar
i heart ricers
x9 +30 is best for stock height
Old Jul 28, 2015 | 05:10 PM
  #186
slawek65's Avatar
slawek65
2011 G37x coupe on Swift springs. I just want to be 100% sure if I can run 19x9.5 +35 offset ( square ) with out any problems. Thanks.
Old Jul 28, 2015 | 07:58 PM
  #187
Gregor12's Avatar
Gregor12
alright guys im about to pick up some wheels tomorrow!!! 19x10 +40 on a 2012 rwd g37 sedan?? Im worried they might poke to much. what do you guys think?? will i need a fender roll and do you think i Can run them with out having to streatvh something like a 245 on a 10 inch wheel?? thanks
Phil
Old Jul 28, 2015 | 08:21 PM
  #188
Phil
Check page 1 of this thread, MylilG and Tbulsara are running 10.5 +35s on 275s and making them fit. If you run a 255 on those wheels you should be OK, are you lowered? FWIW rear fenders are already rolled and the fronts are about 45 degree semi-rolled, so you could flat roll the fronts for more room if needed.
Old Jul 28, 2015 | 10:18 PM
  #189
slawek65's Avatar
slawek65
blnewt, can You help with my question? thanks
Old Jul 28, 2015 | 10:58 PM
  #190
Check Lt8che's coupe on this post in the same thread
https://www.myg37.com/forums/brakes-...ml#post3815735
He's running 9.5 +30 on 265s, they're 18s but will still be the same fit at the fender. If you want to be extra safe for clearance you could run 255/40/19s all around or go w/ a similar fit to Lt8che and run 265/35/19s all around.
And here is his latest setup
https://www.myg37.com/forums/brakes-...ml#post3911521
He's running 9.5 +35 and 275s all around.
As you can see you'll have the room, just need to select a tire that will get you the exact fit you're after.
Old Jul 28, 2015 | 11:16 PM
  #191
slawek65's Avatar
slawek65
Thank You Sir.
Old Jul 28, 2015 | 11:22 PM
  #192
Gregor12's Avatar
Gregor12
I did look at their setups but theyre on coilovers and im on eibach prokit springs. i forgot to mention that lol also i beleive both of them have the X version. is the spacing and specs different from the rwd vehicle?
Old Jul 28, 2015 | 11:30 PM
  #193
The fit at the fender will be the same regardless of AWD or RWD. Being dropped lower on coils will tuck the wheels a bit but in your case you've got much more room to work with than the two Gs I mentioned. You've got 5mm more offset and 6mm more for your narrower rim, so 11mm in from their setups. The wheel edges themselves may poke just a bit but if you run those 255 width tires they'll clear the fender lips.
If you don't want any poke then a +45 would be better.
Old Jul 29, 2015 | 09:29 AM
  #194
Gregor12's Avatar
Gregor12
Thanks man thats exactly what i was thinking. but i wanted to make sure i was doing my calculations right. also thanks for the help on the tire sizes. ill be sure to post up pics whenever i get my wheels on!! thanks
Phil
Old Jul 30, 2015 | 01:13 AM
  #195
SurreyG's Avatar
SurreyG
Quick question and Help !!!!!
I have a G37XS lowred on Swift Springs. I was looking to purchase some wheels off a coworker they are
19x10 + 20 255/40/19
19x 8.5 +15 235/40/19
I know they aren't squared up but would they fit? Fender issues? Would just the rims be okay if I squared them up with 245/40/19 all around?
Thanks.
