The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Jan 27, 2016 | 08:52 PM
  #1081
Yeah, if you could locate another pair of fronts that would be ideal, those rear offsets are about 20mm too aggressive.
Old Jan 27, 2016 | 09:54 PM
  #1082
Broski28's Avatar
Broski28
That's what my fear was. Oh well, I appreciate the help!
Maybe ill test fit them and snag some pics for anyone that would want to go that route, with all 19x9.5 that is
Old Jan 27, 2016 | 11:26 PM
  #1083
Yeah, you'd have to run a lot of negative camber and a stretched 255 width tire to keep them inside the fender lip. Those deep concave rears do look badas$ though.
Old Jan 30, 2016 | 01:28 AM
  #1084
Baby Jumpman's Avatar
Baby Jumpman
19x9.5 +40 19x10.5 +43 on a g35x sedan what tire sizes should be ran? Wheels have 235 fronts 275 rears currently installed, will update sidewall size when I find out.
Old Jan 30, 2016 | 08:44 AM
  #1085
235/40 & 275/35 will work well, you'll be 0.67% larger in back, and that's preferred since the rears wear faster, this will bring you closer to zero% over time
If you do a test fit w/ the new wheels/tires and you have 5mm more you can go out in back (which you should) you can run 245/40 285/35 combo, this will be even better w/ a 0.51% larger rear.
Old Jan 30, 2016 | 11:29 AM
  #1086
Baby Jumpman
Thank you sir.
Old Feb 2, 2016 | 11:53 AM
  #1087
ocie's Avatar
ocie
According to blnewt, I need to run 245/40 all the way around on my coupe 19 wheels that'll be put on my xS sedan.
Any recommendation on summer tires that are around $200 each (or less)?
Old Feb 2, 2016 | 12:07 PM
  #1088
These Nitto NT555 G2 just came out a couple weeks ago, I have thhe first generation of NT555s and they're pretty good, the G2s are supposed to be much better. They have limited sizes right now, the one that would work and give you a little more tire for your X would be the 255/40/19, this would work well on your coupe 19s and your AWD.
NT555 G2 Summer Ultra High Performance Tire
These T1 Sports are a good choice too
https://www.treaddepot.com/#!product...Fitment/252110
Old Feb 2, 2016 | 12:17 PM
  #1089
ocie's Avatar
ocie
Thanks! Those G2s are showing as low as $124
Not the same specs, but I'm sure I can find something around that price after some searching.
Old Feb 2, 2016 | 03:23 PM
  #1090
Good Luck, 19s are quite a bit more expensive than 18s and even 20" tires.
The following tires are all good performers and are in your price point, of these I'd lean toward the Bridgestones~
The S0-4s get great reviews
Bridgestone Potenza S-04 Pole Position
Contis
Continental ExtremeContact DW
BFGs
BFGoodrich g-Force Sport COMP-2
Old Feb 4, 2016 | 10:43 PM
  #1091
Anh Vo's Avatar
Anh Vo
hi guys. i have 08 g37s coupe. im looking for this set up
SSR GTV02 - Yokohama AD08R
18x8.5x22 - 245/40R18
18x9.5x22 - 265/35R18
my question is will this set up clear big brake kit and will it tug out the fender. if not then what offset you recomend.
Old Feb 5, 2016 | 12:31 AM
  #1092
Do you have the stock wheels & tire sizes now? If so use this calculator to get an idea
I'd run the 8.5+22 front 9.5 +35 rear, both will clear your BBK and you could run a 245/45/18 front 275/40/18 rear without any issues.
Old Feb 5, 2016 | 06:43 AM
  #1093
Willyr33's Avatar
Willyr33
Who has got these?
Hi
I have a 2012 G37S coupe
I'm going to go for a set of Work Wheels, the VS-XX or VS-MS 9.5 Fr and 10.5 rears
What offset will sit flush all round and clear the big front brakes, I'd like a reasonable lip on the rear 3"- 4" but no poke, well not too much
I'm going to be on coilovers and drop it 1"- 2"?
Has anyone got these wheels with this set up
Appreciate any info
Cheers
Old Feb 5, 2016 | 08:54 AM
  #1094
Originally Posted by Willyr33
Hi
Appreciate any info
Cheers
Contact Evasive or Ravspec for that info, those wheels have many options so it's best to talk w/ the vendor
Here's Evasive
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: 19"
Old Feb 6, 2016 | 01:11 AM
  #1095
Nick's G's Avatar
Nick's G
I recently got rotiforms that are 19x10 +40 all around. Im planning to run 265/35/19 all around and I was wondering if I would have any clearance issues?
