The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Nov 17, 2014 | 11:20 PM
  #451
ross7778's Avatar
ross7778
I have a 2012 G37x Sedan. Can I put 30mm offset rims on this or will they rub? I'm looking at some G35 7 spoke 18" rims.
Old Nov 18, 2014 | 12:25 AM
  #452
Your OEM rims will be either 17x7.5" +45 or 18x7.5" +43
The G35s are 18x8 +30 so you'll be out 6mm for the wider rim and another 13 to 15mm out for the offset for a net of 19 to 21 mm extension. You'll also be running a wider tire (I assume), so another 5mm for a 235 or 10mm for a 245 width tire. So if you want to go out an inch to inch & a quarter from where you are now than it'll work.
Old Nov 18, 2014 | 12:52 AM
  #453
OBG37S's Avatar
OBG37S
Anybody know if a 20x10 +25 would clear front akebono brakes on G37S coupe? I wouldn't mind a mild poke.
Old Nov 18, 2014 | 08:17 AM
  #454
Depends on the particular wheel design, most should easily clear but going strictly by offset isn't 100% definitive. What wheels are you wanting?
Here's a template that you can use if you have the wheels in hand or can send to the vendor for confirmation
http://infinitig37.com/tech-images/akebonotemplate.pdf
Old Nov 18, 2014 | 06:56 PM
  #455
OBG37S's Avatar
OBG37S
I'm ordering AG M580 in the specs listed. That is a very handy schematic. Definitely plan on putting it to use
Old Nov 19, 2014 | 12:12 AM
  #456
Nice wheels, shoot some pics our way when you get them on
Old Nov 19, 2014 | 09:29 PM
  #457
OBG37S's Avatar
OBG37S
Will do!! Should be here in a month!
Old Nov 20, 2014 | 05:04 PM
  #458
slawek65's Avatar
slawek65
2011 g37x coupe OEM suspension. Can I run square set up with 19x9.5 wheels with 275/35 tires. What offset will work with these wheels? +35 +45 ??? Can this be done? Thank You.
Old Nov 20, 2014 | 05:22 PM
  #459
Check Lt8che coupe here~
Running 9.5 +30s on 265s, so a +35 w/ 275s will work, to be real certain a +40 would give a few mm wiggle room.
https://www.myg37.com/forums/brakes-...ml#post3815735
Old Nov 20, 2014 | 05:34 PM
  #460
slawek65's Avatar
slawek65
Lt8che wheels are 18". Will this make big difference for 19". Tx
Old Nov 20, 2014 | 09:57 PM
  #461
No, the tires will be similar diameter so the fit at the fender will be the same.
Old Nov 26, 2014 | 07:57 PM
  #462
VQCrew's Avatar
VQCrew
whats the lowest offset I can run on 9.5s all around to be more or less flush.
Old Nov 26, 2014 | 09:38 PM
  #463
Coupe or Sedan?
Old Nov 27, 2014 | 02:16 AM
  #464
dtea54's Avatar
dtea54
Need some input guys having troubles deciding on width and offsets of a step lip rim. Size will be 19 tires preferably be a square set of 265. Realistically i would like to have 10.5 square but never worked with step lip app with bbk so not sure what will clear .
Old Nov 27, 2014 | 09:46 AM
  #465
How aggressive are you wanting the lip to be? Probably be a BBK issue if you go real wide in front. You could go staggered lips, just enough in front to clear and go real aggressive in back. Do you have a certain wheel picked out?
Here's a template that you can send to the vendor for confirmation.
9.5 +30 running 265s square is a confirmed coupe fit, a few sedans running 10.5s +35 to +38 on up to 275s square so there should be some room to go up on your coupe.
