The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Jul 21, 2014 | 03:14 PM
  #316
Mulatto's Avatar
Mulatto
On my 2012 S Coupe, will a 20x9F +35 and 20x10R +40 setup work or not? A wheel I've always liked is finally available in silver but this is the only offset I see available.
Old Jul 21, 2014 | 05:16 PM
  #317
Those will work but you'll need spacers to bring them closer to flush and clear the big front calipers, probably 10-15 mm spacers, especially if you want to run wider tires in back like 275s or 285s.
Old Jul 21, 2014 | 07:59 PM
  #318
Mulatto's Avatar
Mulatto
So I would need spacers on all four corners?
Old Jul 21, 2014 | 08:42 PM
  #319
It depends, if the wheel backspacing and spoke design is adequate to clear the big brakes you won't "need" spacers. You'd probably want them though, even if they clear the brakes without them the wheels will be sunken in quite a bit on a coupe. Those offsets would be real flush on a sedan.
Old Jul 22, 2014 | 04:23 PM
  #320
Ainoy Xayarath's Avatar
Ainoy Xayarath
Will this set up work on a 07 G35x Sedan, all fours would be 19x9.5 +45 offset 245/40/19 tires. On stock suspension and maybe plan to lower on swift springs in the future. thanks!
Old Jul 22, 2014 | 07:40 PM
  #321
Yes, that will work fine. Fronts will be out close to the fenders since you won't be dropped but will be OK.
Old Jul 22, 2014 | 11:28 PM
  #322
Ainoy Xayarath
Will it stick out in front or be inside the fender really close?
Old Jul 22, 2014 | 11:31 PM
  #323
The 245 tires will be slightly stretched on the 9.5" rims so they'll tuck into the fender under compression but may be right at the fender edge at stock (non-compressed) height.
Old Jul 23, 2014 | 03:19 PM
  #324
Ainoy Xayarath
thanks for the info, if I can sell my current wheels I plan to go with that set-up.
for sale : 19" MSW Wheels | eBay
Old Jul 28, 2014 | 01:23 PM
  #325
Mulatto's Avatar
Mulatto
Ok, how about, for my '12 S Coupe, a 20x10 setup with +25 offset? (Also available in +45 offset). If I go staggered setup, the 20x9 wheel is available in +22,32,42 offsets.
How would those work for me? Thanks for the help!
Old Jul 28, 2014 | 08:50 PM
  #326
G37Some's Avatar
G37Some
245mm ties shouldnt stretch on 9.5" wheel. 245m to inches is 9.65 inchs. should fit perfect.
Old Jul 28, 2014 | 10:40 PM
  #327
245/40/19s are recommended for 8 to 9.5" rims so it's still a standard mount on the verge of being stretched
Old Jul 28, 2014 | 10:45 PM
  #328
Staggered is a bit easier to pull off, you could go 9" +32 in front on 245/35/20
and the 10" +25 in back on 275/30/20s. The front 10" +25 is pretty aggressive, it's been done but may have issues w/ clearance.
Hopefully you've got a drop or are planning on it, will look a bit off at standard height.
Old Jul 29, 2014 | 12:07 PM
  #329
Mulatto's Avatar
Mulatto
I already have the Eibach springs i plan to put on at the same time I buy wheels.
Old Jul 29, 2014 | 11:53 PM
  #330
RedlineAZ's Avatar
RedlineAZ
Hey guys, I have a 2010 G37 sport sedan,
20X9 +32mm with 245/35ZR20 fronts and 20X10 +35mm with 275/30ZR20 rears with the car lowered on an Eibach pro kit. Will this setup be nice and flush on my 2010 sport sedan? Any rubbing issues?
