The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Will this set up in the rear sit flush on either 265/35 or 275/35 tires?
Wheel spec in question: 19x10.5 +15mm OR 19x10.0 +15mm
I will be lowered, but looking to lower just above the tires, nothing crazy.
I don't want them to stick out of the rear fender. Thanks.
+25 on the 10.5 and +20 on the 10" would be better.
Currently have 20x9 +31 on 245/35 and 20x10 +25 on 275/30 wheels
Would i be okay running 20mm spacers up front and 15 in rear? I have front and rear camber kits. Trying to make it more flush since it's sunk in the front and a bit in the rear
Hello, I'm considering these wheels and tires for my stock 2008, Coupe, Journey.
Work VS-XX 20", Color: Lightning Silver Finish (See HenryLee's FS post)
Specs: 20x10 + 17 T-Disk (Big Caliper Disk) 3inch Lip
20x11.5 +19 O-disk (Deep Rim Disk) 5inch Lip
Tires: Front - 255/35/20 and Rear - 285/30/20
My research has been this thread and the tire calculators here and at "rimsntires." I think this set-up might be too aggressive with out fenders pulled, liners/bumpers removed and some suspension mods. What am I missing?
Thanks.
Thanks.
Thanks.
Thanks.
Fronts would be tight too, but much more manageable.
Ok, throwing on 19x9 +35 wheels on the front and 19x10 +42 wheels for the rear on my g37s sedan (swift spring drop) very soon. I'm thinking 245/35 for the front and 275/35 for the rear. Sound good?
The best setup IMO would be 245/40/19 F and 285/35/19 R.
My only problem with the 40 series tire on the front is the looks part of as I'm not a fan of a taller looking tire in the front than the rear. Does it really affect that much being off by less than 1% if I go with the same sidewall height?
The 245/35 is almost an inch shorter than the 245/40 (over 3% difference).
Doesn't seem that much lower (linked below) but looks can be deceiving. I know on my old g when I ran a taller sidewall in the front it was for sure noticeable.
MY350Z.COM Forums - View Single Post - Volk TE37 Thread
