The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Jul 2, 2014 | 05:20 AM
  #286
Themistah2001's Avatar
Themistah2001
Fat lip
I went through pics and fitment to see what I like but they seem to be all over the place or if I find what I like they don't post specs.... I pm'd and no response....
So here's my question I want the fatest lip available I can get away with without adding a lot of camber or rubbing.... I don't mind a little stretch on the tire I just don't want to spend alot on tires frequently..... I think I want to go with 20x9 front and 20x10 rear just not too sure on offset... (I'm not dropped yet but I am planning to but not slammed )
Old Jul 2, 2014 | 10:21 AM
  #287
Coupe or Sedan? Do you have the big Akebono brakes, and if not do you plan on upgrading down the road? Do you have a specific wheel in mind?
Old Jul 2, 2014 | 11:22 AM
  #288
Themistah2001
I have a coupe S model I don't plan on upgrading it's my daily driver I was thinking of (DPE CS10 or ST10) or (SSR MS1)
Old Jul 3, 2014 | 11:40 AM
  #289
G37fan09's Avatar
G37fan09
Hi
Anyone with a Sedan G37S on 19 inch Velgen VMB5's. Will like to know tire/wheel specs, if drop on what and issues if any. Already read a review of 20" VMB5 and the guy could'nt be happier. I will like to try to keep some comfort with 19's instead of 20.
It will be great if someone can post pics.
Thanks
Old Jul 3, 2014 | 05:52 PM
  #290
NoLimits_Auto's Avatar
NoLimits_Auto
Originally Posted by G37fan09
Hi
Thanks
It really depends on what you are looking for. Without any stretching or large amounts of camber the ideal setup would be something along these lines:
(Insert whatever diameter wheel that you fancy, 19", 20")
Front:19x9.5 +35 offset
Rear: 19x10.5 +45 offset
Now if you go lower on the wheel widths the offsets can be tinkered with but it all depends on the "look" you are going for.
The Velgen VMB5s 19s only come in 19x9.0" for the fronts and 19x10.5 for the rear. Their offsets for the front are +25 and +35. Rears are +25 and +45.
The VMB5 are great looking wheels. So if you went with the VMBs in 19 you would want 19x9 +35 and 19x10 +45 would be the fitment I went with. Again though this the ideal of safe fitment you could say. If your into the stretched tire look and lots of camber you can change the fitments.
Old Jul 3, 2014 | 06:34 PM
  #291
G37Some's Avatar
G37Some
for the VMB5s you should get 19x9 +25 and 19x10.5 +45
Old Jul 3, 2014 | 10:36 PM
  #292
Neomist's Avatar
Neomist
Patawan
Guys I can't seem to find the offset for the OEM IPL wheels. Does anyone know the IPL offsets I am looking to widen the wheels just inside of the wheel wells and lower about 1 inch lowering in the rear and 1.25 inch in the front. I plan on keeping the IPL rims so I guess my only options is spacers. I have the stagger IPL set. Here is what I have found so far:
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Non-sport
Front & Rear 18x8 +43mm offset
Commonly used after-market offsets:
Front width: 8.5" +30-35mm offset Rear width: 9.5" +30-35mm offset
Old Jul 3, 2014 | 10:55 PM
  #293
Sport
Non-sport
I tried looking them up w/ no luck. Since you have the wheels I'd just pull one of the fronts and one of the rears off the car and see what offset is stamped into the back side of the rim. Then let the rest of us know
Old Jul 7, 2014 | 01:35 AM
  #294
blueslate11xs's Avatar
blueslate11xs
Hey all, just need a quick sanity check. Based on this thread, and many others, i think my offsets should be fine, but I've seen conflicting reports so i want to double check before pulling the trigger.
2011 xS Coupe on Eibach at stock alignment
F: 19x8.5 +25 245/40
R: 19x9.5 +35 275/35
I just want to be sure i won't be rubbing anywhere, and most certainly not poking.
Old Jul 7, 2014 | 03:28 PM
  #295
671slandBlue's Avatar
671slandBlue
Ok, so I haven't been on here in forever...but I hope I can find some help/answers.
I own a: 2008 G37s Coupe
I'm about to purchase some Rohana RC10s. Thinking of 20x10 +25F and 20x11 +20 Rear. And then get an Eibach ProKit drop or Tein HTech drop.
I don't like the 20x9 concave since it's not as concave as the 10s. But I'm going for this look. Found this pic somewhere on the forums, and didn't know who's it was.
If anyone can help me out, I'd hella appreciate it. Just trying to get all the specs rt for what I'm looking for. So if all the specs I've given is good, what size tires should I run. Not really going for hella poke or stretch on this set up.
Old Jul 7, 2014 | 04:08 PM
  #296
Try posting the same post over in the hellaflush thread~that's the stance and aggressive offset that's more common there~
https://www.myg37.com/forums/wheels-...sh-thread.html
Old Jul 7, 2014 | 04:14 PM
  #297
671slandBlue
Will do, thanks!!
Old Jul 7, 2014 | 08:33 PM
  #298
You'll be OK w/ that setup, could even go +30 in front. If you want a slightly bigger tire in the rear (diameter wise) you can go w/ a 235/40/19 front 275/35/19 rear, this will give you a 0.67% larger diameter in back so as your rear tires wear faster you'll eventually be equal front to back. If you go 245/275 your -0.52% will get larger as your rear tires wear faster than the front. Hope that makes sense
Old Jul 7, 2014 | 09:49 PM
  #299
blueslate11xs
Thanks for the feedback. I'll probably stick with the 245 in the front, since the sidewall is over half an inch shorter than stock on the 235.
As far as the offset is concerned, the wheels I'm after only come in +25 and +35. If you think it would be a better look (erring on the side of tuck over poke) I could go with the +35 and 5mm spacer if need be.
I initially planned to run a 19x10 in the rear with the 285s to get the extra height, but this rim is only available in a +25 in the 10" width, and I think that's a bit aggressive.
Old Jul 7, 2014 | 11:16 PM
  #300
Check this thread from post #47 on out, his AWD coupe is on 8.5 +35 &
10 +40, and 245/285 tires, they're 20s but the fit at the fenders will be essentially the same as 19s. I think the F&R fit is about what you're wanting, and running 275s in back w/ a bit less positive offset on a 1/2" narrower rim should net a similar fit. I think I'd opt for the +35 in front, especially is you're not adverse to running a small spacer. Here's the thread
https://www.myg37.com/forums/build-t...x-coupe-4.html
As far as the tires, the 235/40s are only 0.18" smaller in diameter than the 275/35s and that's the critical variance, both 245/275 and 235/275 will work alright, I was just throwing that option at you since it the variance will improve over time and the 245/275 will get worse.
