The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Sep 3, 2018 | 11:03 AM
  #2326
Originally Posted by SupraOfDoom
Correction I meant 19x10's. Still think it would contact?
Would hate to say they won't and they end up being a problem, wide fronts are a bit tricky, and those Gs I linked were running 20s which have a bit more clearance as that bend in the steering knuckle comes more into play as the wheel diameter goes down. If there's any way you can get a test fit that would be ideal.
Old Sep 3, 2018 | 04:20 PM
  #2327
SupraOfDoom's Avatar
SupraOfDoom
I live near TF Works in IL, they have a bunch of wheels there. I already emailed them asking if they can test fitments before pulling the trigger.
Old Sep 10, 2018 | 07:59 PM
  #2328
Nathan Do's Avatar
Nathan Do
Just bought some 265/40/18 to go on my 18x9 +35 in the back. Stock rear fenders, I won't rub right? In pic i'm running 245/45
Old Sep 11, 2018 | 12:54 AM
  #2329
You'll be fine, I run 285/40s on my 18x 9.5 +38s
Old Sep 18, 2018 | 12:13 PM
  #2330
ChrisGomez17's Avatar
ChrisGomez17
Getting a new set of rims soon. 8.5" in the front and 10" in the back. What would be the best tire size for this? Also any recommended summer tires would be helpful. Looking at hankook rn.
Thanks
Old Sep 18, 2018 | 07:28 PM
  #2331
Thanks
Sedan, coupe, RWD or AWD and Sport or non-sport pkg?? Be sure to order correct offsets for your vehicle, this will determine how much tire you can run. Also what diameter are the wheels you're wanting?
Old Sep 18, 2018 | 07:40 PM
  #2332
ChrisGomez17
20 inch rims with 35 Mm offset on a rwd coupe
Old Sep 18, 2018 | 09:05 PM
  #2333
beezy619's Avatar
beezy619
What's the width?
Old Sep 18, 2018 | 09:46 PM
  #2334
ChrisGomez17
10" in the reason 8.5" in the front
Old Sep 18, 2018 | 11:29 PM
  #2335
20x8.5 +35 can run up to a 255/35/20
20x10 +35 can run up to a 285/30/20
If you were to match up sets I'd run either a 245/35F & 275/30R OR 255/35F & 285/30R
Old Sep 19, 2018 | 01:06 PM
  #2336
ChrisGomez17
Thanks. Will I need camber?
Old Sep 19, 2018 | 01:12 PM
  #2337
Bud Simpson's Avatar
Bud Simpson
Question 18x8.5/114.3 +38
I have a 2011 XS COUPE, and im wondering if 18x8.5/114.3 +38 is a big enough rim to clear the big brakes. Has anyone else run this size?
Kal tire can't confrim it and neither could any dealerships in my area.
Old Sep 19, 2018 | 04:59 PM
  #2338
You can run those sets w/ in-spec camber
Old Sep 24, 2018 | 11:23 AM
  #2339
r2dmax's Avatar
r2dmax
I was hoping to go up to 265/35 or 30 if I had to on my 20x8.5 ET35 squared setup. That won't work?
Old Sep 26, 2018 | 11:01 PM
  #2340
SupraOfDoom
Given the 2010 GTR wheels are a tight fit on a sedan, what would the ideal tire size be?
