The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Oct 24, 2017 | 12:07 AM
  #2086
Originally Posted by KiNG_G37s
To be honest I’m probably gonna get heat for it but my eyes are set on a set of ESR Wheels sr07 in Black chrome 18x9.5 +22 front 18x10 +22 rear
Should fit pretty good in front, rear will poke a bit but should tuck ok w/ 275s.
Be sure to confirm BBK clearance w/ the vendor or send them these templates
https://www.myg37.com/forums/brakes-...templates.html
Old Oct 24, 2017 | 12:10 AM
  #2087
KiNG_G37s's Avatar
KiNG_G37s
I think they had a +35 offset for rear would that be better
Old Oct 24, 2017 | 01:33 AM
  #2088
If they clear the BBK you'd be able to run a lot more tire, probably up to a 295 width if you want.
Old Oct 24, 2017 | 01:56 AM
  #2089
KiNG_G37s's Avatar
KiNG_G37s
That’s the goal kinda bmw looking
Old Oct 25, 2017 | 07:15 PM
  #2090
Purist's Avatar
Purist
can someone confirm that a 18x10 +39/+40 in the front will clear the suspension? not really worried about clearing bbk or rubbing..
closest i've been able to find is someone running 20x10 +30 or 19x10 +30
Old Oct 26, 2017 | 12:22 AM
  #2091
My 18x9.5 +38s have about 10mm clearance IIRC, and this member ran 18x9.5 +45 and it barely cleared, so you will be just about like his fit at the steering knuckle running 10" +39s. Of course some wheels may be even wider by a mm or 2 in that area so
Here's pics of those SSR GTV03 wheels 18x9.5 +45
https://www.myg37.com/forums/build-t...ml#post3885056
And his specs
https://www.myg37.com/forums/build-t...d-journey.html
Old Oct 26, 2017 | 03:06 AM
  #2092
Purist's Avatar
Purist
And his specs
according to the wheel calc
18x10 +40 will be 1.4mm closer than the 18x9.5+45
and 8.4mm closer than +38
are those clearances too sketchy against the knuckle? i didn't want to run spacers since i was already going to be square x10 +40 all around on my rwd coupe. or would a 5mm or something in the front be alright too if needed?
Old Oct 26, 2017 | 11:48 AM
  #2093
Scarab Armor's Avatar
Scarab Armor
Here's my 9.5 +38 looking down the side~
This is PERFECT!!!
Old Oct 26, 2017 | 12:50 PM
  #2094
Scarab Armor
This looks like the best place to post my question. My girlfriend is looking to change the wheels on her car, but she doesn't want an overly aggressive setup. She's wants to have a flushed look with the new wheels & tire combo. She drives a 2011 G37S coupe & she is looking to purchase a set of Niche Staccato wheels in either 20x9 +35 or 20x10 +40. She's going with a square setup and wants more width without having any poke. As previously stated, she wants the wheels & tires to be flush. Any suggestions &/or recommendations for wheel and tire sizes?
Attached Thumbnails The OFFICIAL "I have a wheel offset / tire fitment question!" thread-staccato.png
Old Oct 26, 2017 | 02:14 PM
  #2095
bPChaos's Avatar
bPChaos
I've been thinking about the same setup. I think the x10+39 with a 5mm spacer will be close, but should fit. But I'm not sure.
The problem with the high offset wide 18s is that it hits the knuckle before it has a chance to curve away. The same width and offset 19inch won't have that problem.
If you do managed to get this on your car before I do, please let us know how much clearance you have. I'm thinking something like an 18x10 +30 to +34 should be the safest.
Old Oct 26, 2017 | 02:57 PM
  #2096
The fact that that 18x9.5 +45 DOES clear (at least that specific SSR wheel) with the width of that wrench would give the green light for that 10"+39 clearing, but again, different wheels will have slightly different widths in that area so a little more in that area and you would need a small 3mm spacer to give you a safe distance there. The was a member in one of the threads about 6 months ago, maybe slightly longer that was running 10+40 all around and didn't have clearance issues. I'll see if I can find it.
If you aren't opposed to running that small 3mm spacer you should be good to go, but then it depends how much tire you want to run as the fender clearance then come in to play
Old Oct 30, 2017 | 04:08 PM
  #2097
Purist's Avatar
Purist
thanks for all the input. i agree 18x10 +30 would make my life easier but i found a good set in +40 so i might be picking them up this weekend. if i do get them i'm going to get a 3mm spacer for the front as well just in case.
i'm hoping i can run around -2.5 front and -2 deg rear on this set up with 255/40 and 295/35
Old Oct 30, 2017 | 04:52 PM
  #2098
steven92's Avatar
steven92
Hello all,
I am very inexperienced with tire and wheel fitments and need assistance. I have a G37X coupe. I would like to run a square setup. I am currently lowered on BC coilovers with rear adjustable camber arms. That being said:
What do I have to achieve to obtain this fitment, as in the attached picture? Where the lip of the rim slightly protrudes out to line up with the fender and the tire is tucked in. I realize I will need my fenders rolled.
I am thinking of running 19 x 9.5" with a +22 offset? 245/35/19 tires?
ES2 ? Varrstoen Performance Wheels
Old Oct 31, 2017 | 12:13 AM
  #2099
This post got skipped over, my bad
Those offsets are conservative for a coupe, and having an S model you'll need to confirm brake clearance with the vendor. Since those are the only width/offsets available you could run the 20x10 +40 all around on 275/35/20 tires but will probably need a spacer to clear the brakes and possibly clear the steering knuckle on the inside.
Are those the only wheels she likes?
Old Oct 31, 2017 | 12:29 AM
  #2100
Originally Posted by steven92
Hello all,
Here's some 20x10 +25 (not sure the tire size though), so the wheels you posted would be in 6mm for the narrower width and 3mm out for the offset, so a net 3mm in from this set at the fender edge.
https://www.myg37.com/forums/brakes-...ml#post4147104
