The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Sep 20, 2016 | 03:59 PM
  #1621
VenomGT9's Avatar
VenomGT9
or 245/40
Old Sep 20, 2016 | 09:23 PM
  #1622
You could run 225/45, 235/45 or 245/40 on those 8" 19s, the 235/40 would have a bit taller sidewall and the 245s would be a very slight pinch fit. Check around w/ tire pricing, you may have one size that's much better priced than the others. For most tire brand models that range of sizes is in their recommended range for the 8" width 19.
Old Sep 21, 2016 | 09:46 AM
  #1623
Mattyem's Avatar
Mattyem
Thanks for all the answers!! You guys are awesome....
Old Sep 21, 2016 | 09:08 PM
  #1624
TGMcCoy's Avatar
TGMcCoy
Been doing some research for a friend's g37 coupe s. I have a G35 coupe and know that g37 have less clearance than I do here goes:
Front Spec will be 19x9.5 +30 (2.5" lip / 7" barrel)
Rear spec will be 19x10.5 +32 (3.5" lip / 7" barrel) or 19x11 +26 (4" lip / 7" barrel).
Would like to go an extra 1/2" lip on the front, making it 19x10 +24
Just curious which setup could be achieved from only natural camber from coilovers and stretched tires... not planning on running any negative camber..
Thanks
Old Sep 22, 2016 | 10:09 AM
  #1625
Mattyem's Avatar
Mattyem
I know you guys mentioned a lot of numbers but this is one you didn't mention so I'm wondering if they will work with my 2010 g37xs sedan lowered on swifts
The tires are 245/45/19 with my 19x8 35 offset.
The OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo462.jpgThe OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo260.jpg
Old Sep 22, 2016 | 10:14 AM
  #1626
VenomGT9's Avatar
VenomGT9
Thanks
Why don't you want neg camber? These cars need camber to uphold to handling dynamics it was designed around. You could run either of those set ups with a coil drop, probably looking at a 245/35 front and 255/35 rear.
Attachment 123867Attachment 123868
245/40
Old Sep 22, 2016 | 10:17 AM
  #1627
Mattyem's Avatar
Mattyem
Originally Posted by VenomGT9
245/40
You sure? I would hate to pass up this good of a deal if it can be done.
Old Sep 22, 2016 | 02:26 PM
  #1628
Be about an inch taller, and over 3% from your OEM diameter. Guys have done it, not sure if any long term issues would arise though???
Old Sep 22, 2016 | 02:34 PM
  #1629
Mattyem's Avatar
Mattyem
I think I'll play it safe and go with these. Can't believe how cheap she's selling them for?! No patches or holes...
The OFFICIAL "I have a wheel offset / tire fitment question!" thread-photo423.jpg
Old Sep 22, 2016 | 02:37 PM
  #1630
VenomGT9's Avatar
VenomGT9
Good deal, jump on it...or her, whichever works
Old Sep 22, 2016 | 02:41 PM
  #1631
Mattyem's Avatar
Mattyem
I'll work my magic the ladies like the younger men right?
Old Sep 23, 2016 | 05:53 PM
  #1632
Boo-yah's Avatar
Boo-yah
Moved started a thread
Old Sep 24, 2016 | 09:06 AM
  #1633
dmill86's Avatar
dmill86
Hey all,
I am planning on purchasing a 2008 G37s coupe soon and I was hoping you guys could help me figure out what I would need in terms of tire size and wheel offsets. I'm a total noob so please bare with me. I plan on lowering the car 1-2" and would like to achieve as flush of a fitment as possible *without* the use of spacers. my plan is to go with a staggered setup. I'm open to suggestions but was thinking maybe 20x9 in the front and 20x10.5 in the rear? (whatever works best for flush fitment) what wheel size/offset should I go with to achieve a "flush" fitment? (no wheel gap and close to fender) I want to go with 20" wheels without stretching the tire but also don't want too high of a sidewall. I'll be dropping the car just enough to eliminate the wheel gap and to have the fender flush with the top of the tire. what wheel offsets/tire size should I go with to achieve this? and is it possible to achieve this fitment without fender pulling or shaving? any suggestions are greatly appreciated. Thanks
Old Sep 24, 2016 | 09:52 AM
  #1634
Originally Posted by dmill86
Hey all,
9+25 running 245/35/20 front 10.5 +35 275/30/20 or a 10.5 +40 285/30/20. This would be running in-spec camber, if you don't mind a bit more camber you could run 5mm less positive offset or another 10mm wider tires. Look into coilovers if you want to fine tune your height, the Tein Basis Z coilovers are under $500 so I'd give those a look.
Old Sep 24, 2016 | 12:14 PM
  #1635
dmill86's Avatar
dmill86
Thanks for the speedy reply blnewt!
I'm not a big fan of the camber look to be honest. So I'd like to try and avoid it if possible. I would prefer if the wheels ran flat straight up and down. so if I went with 20x9 +25 offset with 245/35/20 tires Font and 10.5 +35 offset with 275/30/20 tires Rear would that give me a flush fitment without having to do any camber? and yes, I would be going with coilovers. was actually considering BC racing coils. Think tein basis Z are better in your opinion? Its only going to be driven in the city and only in the summer/fall months. Thanks again for your help.
