Official~Best offsets for running FAT tires!
Old Jan 15, 2016 | 02:30 AM
  #1051
changbang's Avatar
changbang
Hmm I don't want all that camber and stretch. What would you recommend the most beefy tires I can go with my offset without doing all that work?
Old Jan 15, 2016 | 09:05 AM
  #1052
Originally Posted by mkn23
i have a 2009 g37 sedan with akebonos, would a set of BBS RS-GT 18x8 +18 front & 18x9 +18 rear be too aggressive for the sedan? and what are the limits of pulling/flaring the guards?
ChinkyChoy has run a 9.5 +25 without fender work, so that's one mm difference w/ that back wheel and he runs 245 width tires. Might shoot him a PM and see what he says. I would strongly recommend against doing any pulling of the fenders, the rears are already flat-rolled from the factory so you can roll the front fenders pretty easily.
Pulling fenders looks really bad unless it's done exceptionally well.
Old Jan 15, 2016 | 09:08 AM
  #1053
Not sure if it's possible to have those wheels redrilled, but just going by the offsets you listed without any adapters you should be able to run 255/40 fronts 285/35 rears. But depending on adapter thickness you'd have to shrink those widths down to a max of 255 in back, and even then it may be too much
Old Jan 20, 2016 | 04:38 AM
  #1054
Phx-G37s's Avatar
Phx-G37s
Hey guys...so I have some vossen vf051 in
20x9 235/35 +35. 8mm spacer
20x11 245/35 +38 5mm spacer (so clears rears)
I think.
Don't ask lol....bought the setup for my stocks and minimal cash. So needless to say amazing deal. He was slammed in his Q so had stretch tires.
Question is, I am buying coils so will be dropping soon.(stance,tein flex z, or tanabe comfort R) I want some nice full tires, so tired of being scared on every bump I dented a rim with this 245 on a 11" wheel haha. Not to mention the ride quality is meh.
So what tire size should I shoot for? I was thinking 285/30 or 295/30, or even 305/30 if not too much. The fronts are ok, not so bad, when they wear down a lil more I may throw on some 245-255/35. Will I be ok at those sizes?
I'm dropping just to close gap probably, so about .5-1 rear and 1-1.5 front or so abouts. Currently the wheels are pretty even with fender, but after drop they will tuck a bit right? If so I will have to flush Em up with larger spacer. Which I needed to get nicer real spacers anyway, if not great but we will see.
I know it's kinda hard to tell how much I can fit until it is dropped.
Also, what brand of tire should I go for? Live in Phoenix, so weather is not issue. Looking for comfort over all, with performance next.
May all be temp anyway. I don't like chrome, so either powder coating or maybe sell and update w something concave, but until then I wanna make Em look good as they can. Currently dipped white w glossifier as a test, ton of work w all the rivets but actually looks great.
Sorry...rambling lol !
Old Jan 20, 2016 | 11:48 AM
  #1055
Luckily you seem to have plenty of room, going from a 245 to a 295 will add about an inch to your outer tire width. Just get a 1" sponge,foam or even a paperback book that's about an inch thick and lay it against your tire so you can get a good visual. If the tires are in decent shape (and you like them) I'd run the 245s in front and go up to at least a 285/30 and even wider if you have the room.
Old Jan 21, 2016 | 03:36 AM
  #1056
evil-G-nius's Avatar
evil-G-nius
Those are 20's!? They look super small! I would have guessed 18's to tell you the truth. I agre though, you have a ton of room to go wider
Old Jan 21, 2016 | 02:12 PM
  #1057
Phx-G37s's Avatar
Phx-G37s
Just picked up some 370z sport forged rays 19 as well. Now I have an alt lightweight set.
Old Feb 1, 2016 | 11:34 AM
  #1058
ANMVQ's Avatar
ANMVQ
Can I fit a 245/45/19 tire on a 19x10.5 rim, stretch?
Old Feb 1, 2016 | 09:46 PM
  #1059
255s are a common stretch on a 10.5, 245s would be pushing it IMO but I'm sure it's been done. I wouldn't feel good about pushing the car too hard w/ that fit for sure.
Old Feb 2, 2016 | 08:19 AM
  #1060
ANMVQ's Avatar
ANMVQ
Thanx man I was thinking the same thing :/
Old Feb 19, 2016 | 10:19 AM
  #1061
tigerlui's Avatar
tigerlui
Hi there, i have a question here. I have a '10 G37S Sedan, lowered on Tein-S springs.
Currently, i am sitting on STR607 20x9 (+30)F/ 20x10.5R (+45) , with 245/30/20 and 275/30/20 and they fit fine.
I am looking into a set of used wheels. They are 20x10 +20 square set, with 255/35/20 tires mounted on. Will the rear fit?
Old Feb 19, 2016 | 11:51 AM
  #1062
StreetShotz's Avatar
StreetShotz
Well after going through page after page I'm still not sure what will fit.
08 G37S Coupe
Wanting to run 20" wheels, as wide as I can get with a flush, no crazy camber, no rubbing or cutting, no fender rolling. Just bolt on and go.
The car is used for track days and auto-x in the summer months so proper alignment is a must.
Can anyone shed some light on this?
For the front I have seen talk of 20x9.5 and 20x10 fitting without any work needed but unsure of offset. The rear I seem to see a lot of 20x10.5 and 20x11 in a +35 fitting but again not 100% sure.
Any help would be great or if asked before a link back to that post as I cant find anything that answers this 100% for me.
Old Feb 19, 2016 | 12:08 PM
  #1063
StreetShotz
From what I can gather a 20x9.5 +40 up front and a 20x10.5 +45 in the rear.
For tires a 245/30R20 and a 295/30R20 for the rear.
Opinions, experiences?
Old Feb 19, 2016 | 02:13 PM
  #1064
No time now but will get back tonight, we'll get you the perfect fit!
Old Feb 19, 2016 | 02:57 PM
  #1065
4DRZ's Avatar
4DRZ
From your experiences, what is the most negative camber you can run front and rear without having to worry about cupping the tires? I run Tein Basis and will probably be running 245/275 19 RE-71R or something similar for mostly street, but a handful of track days. It looks like I might need rear adjustable camber arms is there is way more negative camber in the back right now on the snow tires.
