Official~Best offsets for running FAT tires!
Old Jul 11, 2012 | 01:58 PM
  #91
GotAir523's Avatar
GotAir523
Originally Posted by Alpha Ice
I had them on my old coupe and I wasn't really a fan. I'm guessing you haven't had them long since you haven't had any complaints about how loud they get, but like the 452's they will get pretty loud later on. They have a great tire life but I wanted something a bit stickier. They do have an excellent tread pattern and good wet handling surprisingly
yea, i've only had them on for about a week, but i can definitely hear they are louder, thats for sure. as of now, they are definitely stickier that the stocks which i like. the tread pattern looks incredible though lol
Old Jul 13, 2012 | 03:30 PM
  #92
myk1013's Avatar
myk1013
Here's a pic of mine....
Old pic, same set up...
Phantom Edition GT30's with Eibach PK drop.
20x9.5 255/35
20x10.5 285/30
Yokohama S.Drives
*planning on going 295/30 or maybe even a 305/25 when new tires are needed.
Old Jul 14, 2012 | 12:02 AM
  #93
WARAT's Avatar
WARAT
what are your offsets myk?
Old Jul 14, 2012 | 04:58 AM
  #94
Robert_K's Avatar
Robert_K
+1! Look great and share offsets.
Old Jul 14, 2012 | 11:56 AM
  #95
myk1013's Avatar
myk1013
I have pretty weak offsets.... +35 front / +37 rear
I can probably put 15mm up front and 10mm in the rear spacers to be happier with the look but I'm already rubbing in the back.
Old Jul 14, 2012 | 12:02 PM
  #96
Robert_K's Avatar
Robert_K
Well in the future if you get coilovers and some camber arms I'd said go with;
Front: 5mm spacer and 265
Rear: 295/305
That would look mean!
Old Jul 14, 2012 | 01:04 PM
  #97
myk1013's Avatar
myk1013
Rear: 295/305
Do you think I can get away with grinding off the bumper bracket and going with 305/25/20 in the rear with my current drop?
Old Jul 14, 2012 | 01:19 PM
  #98
Robert_K's Avatar
Robert_K
OK I'm not an "expert" and new to the G37. But I'll give my insight/thoughts. 1) I'm not one for cutting/grinding. If I had to I would take it to a body shop. 2) This site if your friend; Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old Jul 14, 2012 | 01:21 PM
  #99
soolman32's Avatar
soolman32
I'll post my old setup. The current one isn't really "Fat" per say
Wheels: XIX X17
Wheel Specs:
F 20 x 8.5 with 35 offset, 2.5" lip
R 20 x 10 with 45 offset, 3.5" lip
Tires specs:
F 255/35/20
R 285/30/20
Old Jul 16, 2012 | 11:47 AM
  #100
mystikal's Avatar
mystikal
Before
After:
Tires
245-35-20
275-30-20
20x9 offset 32
20x10.5 offset 42
11 g37x on Eibach pro springs
Old Jul 19, 2012 | 11:59 AM
  #101
Vini's Avatar
Vini
Originally Posted by mystikal
Before
After:
Tires
245-35-20
275-30-20
20x9 offset 32
20x10.5 offset 42
Looking good man...
Old Jul 20, 2012 | 12:20 AM
  #102
SoulSeeker's Avatar
SoulSeeker
Nice Wheels
Old Jul 24, 2012 | 01:36 PM
  #103
mystikal's Avatar
mystikal
Thanks GUYSSSS...NOOO RUBBING lol
Old Jul 25, 2012 | 09:08 PM
  #104
Fentress24's Avatar
Fentress24
MYK I am not sure how close you are to the fender, but you can completely cut off the rear bumper bracket and use a pop rivet or some people just use 3M double sided tape to hold it in place. I used a pop rivet to hold the bumper and fender together and it holds tighter than the stock bracket and I could adjust it to how I liked. Fits better now than stock and I have much more clearance. Next time I have the wheels off the car I can take a picture.
BTW a dremel with a metal cutter blade makes quick and easy work of the bumper bracket.
Old Jul 25, 2012 | 09:47 PM
  #105
soolman32's Avatar
soolman32
Could you take a picture of how that looks? thanks.
