Official~Best offsets for running FAT tires!
Old May 2, 2013 | 11:58 PM
  #361
Originally Posted by jktinen
can anyone suggest a setup for an 09 x sedan lowered on swifts? I was thinking TSW nuremberg 19s. Want to keep it square but FAT
The fronts will be your limitation, Could probably go 265 all around but even at +45 you'll be really close since the front fender edge isn't rolled flat like the rear lip. Should be OK except under hard compression.
Old May 3, 2013 | 03:36 AM
  #362
jujubii's Avatar
jujubii
could i get some fitment advice please?
my current setup is
F: 19x9 +47 255/40/19
R: 19x10 +30 285/35/19
i have the opportunity i secure another set of the rears (with square setup in mind). essentially, im asking if running 19x10 +30 in the front would cause any serious rubbing issues. my goal is to run 19x10 +30 255/40/19 all around.
the reason, i ask is because i rub in the back a bit when there are 3+ people in the car. most of the bumper tab has been shaven off as well. then again, it may be because im running 285s i'm only dropped, on coils, a tad bit lower than eibachs (for reference i believe somewhere around -1.4front -1r).
Old May 3, 2013 | 08:47 AM
  #363
my current setup is
Just use your current front tire as the reference, you'll be 17mm out from where you are now w/ just the offset. You have another 1/2" (12mm) for the wider wheel, so that's 29mm total that your setup will be closer to the fender. Keep in mind the front fender doesn't have the flat roll that the rear does so there's more area for contact up there. It's going to be a tough fit I think.
Old May 3, 2013 | 12:44 PM
  #364
jujubii's Avatar
jujubii
thanks, exactly what i calculated
my front setup is really tucked in. i have a 10mil spacer and think i could make do at a maximum of 20mm let alone extending it an extra 29.7mm.
i was just hoping that someone could say 'no, jujubii! i run that setup perfectly fine' haha
Old May 6, 2013 | 12:12 PM
  #365
solarg37's Avatar
solarg37
20x9 in front 245s 15mm spacer to clear bbks
20x10.5 in rear with 285s
hankook v12 tires
lowere with tein h techs "mild drop" perfect for daily driving
plenty of space in the rear i was actually going to a 305 set up maybe
Old May 6, 2013 | 12:22 PM
  #366
Robert_K's Avatar
Robert_K
Look great! 305 would give it a nice aggressive look! Might want to consider a 255 or maybe a 265 on the front to offset the 305. Don't want skinnies and fatties. LOL
Old May 6, 2013 | 02:08 PM
  #367
hankook v12 tires
Great looking coupe w/ perfect stance. 305s would be the
Old May 8, 2013 | 05:21 PM
  #368
ttv36's Avatar
ttv36
Race, repair, repeat.
Burned out my stretch tires last night.
Replaced with some more meat.
Old May 8, 2013 | 06:02 PM
  #369
dagon68's Avatar
dagon68
Looking good Tony. Welcome to the Fat club! lol
Old May 8, 2013 | 11:02 PM
  #370
Robert_K's Avatar
Robert_K
Congrats and with age comes wisdom.
Old May 10, 2013 | 04:16 PM
  #371
Robert_K's Avatar
Robert_K
Teaser...
Attached Thumbnails Official~Best offsets for running FAT tires!-foreglines.jpg
Old May 10, 2013 | 09:16 PM
  #372
Robert_K's Avatar
Robert_K
Attached Thumbnails Official~Best offsets for running FAT tires!-photo-2.jpg   Official~Best offsets for running FAT tires!-photo-3.jpg   Official~Best offsets for running FAT tires!-photo-4.jpg
Old May 11, 2013 | 12:38 PM
  #373
Robert_K's Avatar
Robert_K
Old May 25, 2013 | 11:39 PM
  #374
Robert_K's Avatar
Robert_K
Bump!!!
Old May 26, 2013 | 10:48 AM
  #375
dagon68's Avatar
dagon68
Very nice my friend very clean
