G37 OEM wheel & Tires (Specifications) *For Reference*
Old Jun 5, 2016 | 01:43 AM
  #121
sptl99's Avatar
sptl99
255/40 would only be a bit over 1% taller than the 245/40, the 255/35 will be over 2.5% shorter. If you want to run 255s go w/ the 255/40 for sure.
Would I run into any problems?
Old Jun 5, 2016 | 10:47 AM
  #122
With the 255/40 there won't be any issues other than a slight speedometer error. The 255/35s are getting close to 3% difference and may cause issues w/ some other items like ABS and traction control but that's only what I've read, nothing I've seen firsthand so
The Z guys switch to smaller diameter track tires for track duty and don't report issues, so there's that
If I were in your spot I'd run the 255/40s just to be sure.
Old Jun 5, 2016 | 11:01 AM
  #123
sptl99's Avatar
sptl99
Alright and assuming there wouldnt be any problems with the stock 245/40? Like the speedometer?
Old Jun 5, 2016 | 12:21 PM
  #124
slartibartfast's Avatar
slartibartfast
The speedometer in my S sedan is 7% fast from the factory (I assume yours is too). I went from 245/45-18 to 255/45-18 in the back to gain a bit more rubber and to reduce the error to 5%. Makes the math easier when determining how much over posted limit I go. I can go an indicated 50 in a 45 zone and know I'm only 2 mph over and safe from tickets.
I have not checked the accuracy of the odometer.
Old Sep 3, 2016 | 11:14 AM
  #125
Landshark's Avatar
Landshark
what is the offset for the 19" factory wheels on an xS (AWD) coupe?
first post lists specs for S coupe with different widths and offsets for front and rear, but i think the AWD Sport model's fronts and rears are the same.
8.5" width on both, but not sure if offsets are the same or different front and rear. ???
Old Sep 3, 2016 | 02:37 PM
  #126
Yep, all four are the same +43 offset on the AWD XS coupe.
Old Sep 4, 2016 | 07:53 AM
  #127
Landshark's Avatar
Landshark
thank-you, sir!
i thought i remembered that was the case, but couldn't find that info anywhere.
Old Sep 4, 2016 | 10:51 AM
  #128
thank-you, sir!
Yeah, every AWD in the Infiniti line will have all four wheels/tires the exact same specs from the 17" base X Sedans to your 19" XS.
Old Sep 9, 2016 | 12:31 PM
  #129
symphx's Avatar
symphx
OEM 19" 10 spoke G37 Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lug Nuts~flat shoulder, mag-style w/ washer, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Sedan OEM wheel specs~
G37 Sport and G37x Sport[/U][/B]
Front: 18"x7.5". Cast aluminum-alloy. Bolt pattern 5x114.3 Offset +45
Tires: Bridgestone Potenza RE050A P225/50R18 95W
Rear: 18"x8.5". Cast aluminum-alloy. Bolt pattern 5x114.3 Offset +50
Tires: Bridgestone Potenza RE050A P245/45R18 96W
18" All Season
18x7.5 front/rear. Cast aluminum-alloy, Bolt pattern 5x114.3. Offset +43mm
17" All Season
17x7.5 front/rear. Cast aluminum-alloy, Bolt pattern 5x114.3. Offset +45mm weight 22.2lbs (thanks 4DoorFury)
Spare
17x4T Cast aluminum-alloy, Bolt pattern 5x114.3. Offset +30mm
18x4T Cast aluminum-alloy, Bolt pattern 5x114.3. Offset 0mm
according to this website: 2013 g37s coupe wheels are wrong above:
Infiniti G 2013 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
and are smaller wheels:
225/45ZR19 94W
245/40ZR19
8Jx19 ET45
8.5Jx19 ET50 5x114.3 M12 x 1.25 66.1 2.1
I want to make sure I am fitting the correct wheels, can someone help? In fact tirerack.com just told me 275/35 are too 'short' and not recommended.
Old Sep 9, 2016 | 11:24 PM
  #130
225/45ZR19 94W
245/40ZR19
8Jx19 ET45
The information on our site is correct & up to date. Many run the 275/35/19s on the back 9" wide wheels without problems, and to keep diameters similar a 245/40/19 would be used in front. Ideally a 265/35 is a better mount on that wheel but it's an uncommon size. Our tirerack on-site rep "Neal@Tirerack" recommends that 245/40 & 275/35 combo often for the coupe 19" OEM sets.
Old Sep 10, 2016 | 08:50 AM
  #131
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
245/40 & 275/35 combo all day long, no issues. MANY members using those with good luck. At the time there we not many 245/285 matching tire combos on the market, thus the reason a 275 was next best thing and just happened to work well. Now the options have become more plentiful in both combinations, but many still run the more conservative 275's for touch more clearance and price (in some cases).
Old Sep 10, 2016 | 12:33 PM
  #132
symphx's Avatar
symphx
ok guys, HELP ME DECIDE:
oem size michelin pilot ss or
245/275 (larger) continental extreme dw (still less expensive then oem michelin)
I am an average driver on california roads, I like to take corners a bit fast, nothing else crazy. I have eibach sway/roll bar combo all else stock (and back ceramic brakes).
I dont want to lose speed off the line or screw with my suspension etc.
Old Sep 10, 2016 | 03:06 PM
  #133
slartibartfast
Dude, why are you spamming this forum with your question? Asking it in one thread is sufficient.
Old Sep 10, 2016 | 04:05 PM
  #134
symphx's Avatar
symphx
Sorry. Different threads might get read by different people.
Old Sep 10, 2016 | 07:45 PM
  #135
Good deals at tirerack.com on Hankook Ventus V12 Evos, those should suit you well and have a $100 rebate going on. And please only post one thread per topic, we'll get to you
