G37 OEM wheel & Tires (Specifications) *For Reference*
#61
hey whats up everyone...i have a question! you guys know more then me so..
theres this guy whos selling one set of staggered wheels MRR the size are: 245/35/r20 rim size is 20x8 1/2......rears are 275/30/r20 rim size is 20x10 inch you think will fit on the g37 is a coupe
#63
OEM 19" 10 spoke G37 Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Wheel offset calculator
Front:
Rear:
#67
OEM 19" V spoke G37 Sport wheels (2011+) & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26 lbs. Bolt pattern 114.3 x 5 Offset +43
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 26.6 lbs. Bolt pattern 114.3 x 5. Offset +45
Front:
Rear:
I updated the quoted with observed weights, subtracting new tire weight. Tires currently have just under 10k miles. Here are my observed weights:
FL 53.4 FR 53
BL 56.8 BR 56.6
There is a plug in one rear tire.
#68
hey everyone im new to the G forums. About a week ago I bought a 2008 G37s with 48000 miles for 21,000. I would up load pics but I dont know how.
I am looking at a set of rims. Im understanding stock the rear are 19x9 and the front are 19x8.5
I found a set of stance rims, the rear are 19x9.5, the front are 19x8.5 off sets of 35 on front and back. Im wondering if the rear with that size and offset are going to fit clean also the offset on the front seems different.
#69
Does anyone know if i can fit these rims on my car? Every website says the bolt pattern doesn't fit but i saw a G37 with these rims. Someone please help im such a noob.
MANDRUS® ROTEC Wheels - Matte Black Rims
#72
Here's some templates for fitment testing~
http://www.conceptzperformance.com/i...nttemplate.pdf
http://www.conceptzperformance.com/i...artemplate.pdf
#75
225/45 19" and 245/40 19" don't have the same circumference. Is that not creating problems with four wheel drive?
Thanks!
