G37 OEM wheel & Tires (Specifications) *For Reference*
Old Apr 22, 2018 | 01:47 PM
  #181
Bizzenn's Avatar
Bizzenn
Here's my question. I have 2014 Q60/G37 Journey with the 18's. I'd like to go with 19'' wheels but I'm not sure what the range of offsets I can use without using spacers. Also, the wheels I'm finding are 19X8.5 and 9.5 but no 9''. I could go with 19X8.5 all around with 245's or stagger them, meaning i'd need to go with the 9.5's in the rear. Would I need to go with a 255 in the rear minimum and would the stock offsets change due to the width of the new wheel? Thank you.
Old Apr 22, 2018 | 06:07 PM
  #182
I'd run 9.5s all around, I run them on my sedan and you have a wider range of tire choices that have more width to them. I'd look for a 9.5 in the +25 to +30 offset and look to run a 265 or 275/35 all around.
Old Apr 29, 2018 | 10:58 AM
  #183
STownSaint's Avatar
STownSaint
All Infiniti G37s and Q50/60 use the same center cap size, also the maxima & 370z also share the same size (and I believe the Altima does as well).
Errrr don't think this is true (at least anymore)
Recently tried buying black centercaps from Redsport wheels and they were much too large to fit into G37 wheels.
Old Apr 29, 2018 | 04:54 PM
  #184
Thanks STown, they do appear to be larger by 1/4" or more based on this pic
Old May 2, 2018 | 11:45 PM
  #185
takemorepills's Avatar
takemorepills
Read through this entire thread. Couldn't find what I was looking for.
I have a 2014 Q60 AWD coupe with 18x8 (I think 8) wheels. I need to replace 2 curbed wheels. I found what I thought were the exact same wheels on ebay, but they said "convertible only". After much research, which mostly was dead ends, I kind-of gather that the convertible uses the exact same wheel design as my AWD coupe, but the convertible uses 18x8 front and 18x8.5 rear. I am GUESSING that my AWD coupe uses same wheels as the fronts of a convertible, but I can't find any info anywhere. The Nissan/Infiniti P/N suggests convertible fronts are different than AWD coupe wheels, but the specs I saw online show they are probably interchangeable.
So, are AWD coupe 18's the same as convertible front 18's?? I'm worried the offsets may be different, hence the different P/N's
Old May 3, 2018 | 12:00 AM
  #186
Do you have the part #s handy? Vert wheels usually have higher rear offsets, like a +30 vs. the coupe/sedan offsets in the +43 to +45 range. Won't be a problem for fit but you'd want them mounted in back, and then probably want spacers in front to even things out.
Old May 3, 2018 | 12:15 AM
  #187
takemorepills
The vert wheels (fronts) are supposedly 43 offset. I emailed the seller, but he was unsure. I am trying to get a pair of reman wheels
This one doesn't mention offset: https://www.ebay.com/itm/OEM-Reman-1...19.m1438.l2649
But the x-ref number is 73753
This one says for coupe, is same x-ref 73753, but states is for coupes and offset is 43: https://www.ebay.com/itm/OEM-Recondi...19.m1438.l2649
Old May 3, 2018 | 01:03 AM
  #188
slartibartfast's Avatar
slartibartfast
Offset is cast into the wheel, usually in the back side of one of the spokes. Both my sedan and coupe wheels have this feature.
Old May 3, 2018 | 07:17 AM
  #189
Bizzenn's Avatar
Bizzenn
Can I run a 245/40/19 on an 8.5 width wheel?
Old May 3, 2018 | 08:35 AM
  #190
I'm not sure about the vert 18" sets, since they aren't a staggered setup like the 19", it's possible the offsets are the same front & rear but ???.
Like Slartibart mentioned, the offset is stamped inside the spoke area, seller should be able to confirm this easily if they have product in stock.
Old May 3, 2018 | 08:36 AM
  #191
Yes, you definitely can use that size, it's about the most common tire used around here on 19x8.5" width wheels.
Old May 3, 2018 | 01:46 PM
  #192
Bizzenn's Avatar
Bizzenn
Wonderful thanks
Old May 3, 2018 | 02:00 PM
  #193
Bizzenn's Avatar
Bizzenn
This is probably a stupid question but 245,’s wouldn’t create any clearance issues with turns would it? I would assume it could go even wider in the front.
Old May 3, 2018 | 05:08 PM
  #194
slartibartfast
No issue with clearance, Clarence.
Old May 3, 2018 | 05:44 PM
  #195
Bizzenn's Avatar
Bizzenn
Awesome👍🏻 Thank you
