New Motordyne Shockwave E370
Old Jul 1, 2012 | 08:30 PM
  #256
MaDMaXX's Avatar
MaDMaXX
Um, i can kind of see where that is, but can you get a shot with the connections shown at both ends? they're the part that will affect this clearance.
Old Jul 1, 2012 | 08:50 PM
  #257
NeverBoneStock's Avatar
NeverBoneStock
Originally Posted by dopetime
Here's the pic of the pass y pipe.
I was going to post mine . But, yours is identical to what I have .. Design issue or welder was having a off day ..
Old Jul 3, 2012 | 12:51 PM
  #258
Sunny's G37's Avatar
Sunny's G37
^^^ guys have you found a fix for this other than temporary wrap fixes? Is it actually a design flaw or install error/adjustment?
I am going to install mine tonight so want to be prepared as to what needs to be adjusted carefully so that I don't have this issue... Man am keeping my fingers crossed and hoping it goes smooth on mine. I will be mating it with stock cats.
Any info is much appreciated people.
Cheers !!!
Old Jul 3, 2012 | 01:48 PM
  #259
dopetime's Avatar
dopetime
It's not an install issue. If it'll affect you there's no permanent fix as of now. According to Tony there's some variability in where the engine sits from Infiniti which is why some of us have the issue and others not. Tony has some flanges that act like spacers that may fix the issue. I haven't received mine yet so I dunno but it did not fix it for another member.
Old Jul 3, 2012 | 02:07 PM
  #260
Sunny's G37
^^^ wow.. Thanks for the reply man. Hope mines sitting the way it apparently should from factory. Lol
I have yet to do the install so I guess I will know tonight or tomorrow night if I have the same issue.
Old Jul 3, 2012 | 02:18 PM
  #261
P Casey's Avatar
P Casey
How many people have this problem?
Old Jul 3, 2012 | 04:08 PM
  #262
NeverBoneStock
Exhaust
I do .. Not fun ....
Old Jul 3, 2012 | 04:39 PM
  #263
Sunny's G37
Completely random question....
The ones who are having this clearance issue, did you guys ever have a warranty work done on the engine or the tranny? Or did you ever get into an accident?
Old Jul 3, 2012 | 08:11 PM
  #264
WARAT's Avatar
WARAT
I don't have the problem and I had my transmission replaced
Old Jul 4, 2012 | 12:52 AM
  #265
datboiroy's Avatar
datboiroy
Does anyone have this exhaust installed with the Autokits diffuser?
Old Jul 4, 2012 | 03:32 AM
  #266
huwee06's Avatar
huwee06
You do Roy, why don't you install the e370 and tell us how it turned out
Old Jul 4, 2012 | 11:30 AM
  #267
datboiroy's Avatar
datboiroy
I did and my tips rub against the diffuser.
Old Jul 4, 2012 | 01:38 PM
  #268
MaDMaXX's Avatar
MaDMaXX
You should be able to rotate the mid pipes to change the tip location.
Old Jul 4, 2012 | 06:02 PM
  #269
NeverBoneStock
Guys with the cross member issue..... The flanges do not work .. I installed mine and instead of resting on the cross member it gives it just a little clearance .. Maybe a 1/4 of a inch .. Header wrap is back on ... This exhaust is awesome but the y- pipe needs to be redesigned for more clearance ...
Old Jul 4, 2012 | 07:51 PM
  #270
Sunny's G37
At the shop right now Getting the exhaust installed... Couple of things
1. The crossmember issue happened in my case as well.. Only fix.. Torch it and put a dent... Clearance is all good now.
2. My canisters have the lettering facing down how it's supposed to be for both.. Maybe he realized and fixed this issue. Cant imagine installing it the wrong way as the hangers match both sides.
3. 5" tips are too big so lowering the whole exhaust a bit so that it doesn't rub against the bumper and melt the **** out of it.
It's too sad that I had to put a dent in the crossmember.. Now my concern is if it jeopardizes the integrity of it? Need some advice...
