View Poll Results: What brand of oil do you use in your G coupe/sedan?
Motul (300v or 8100)
56
4.06%
German Castrol
44
3.19%
Amsoil
46
3.33%
Redline
49
3.55%
Royal Purple
79
5.72%
Mobil 1 Synthetic
653
47.28%
Pennzoil Platinum
133
9.63%
Valvoline SynPower
31
2.24%
Eneos Synthetic
22
1.59%
Quaker State
0.72%
Lucas Oils (synthetic)
0.43%
Schaeffer Synthetic Oil
0.29%
Nissan Ester Oil
171
12.38%
Conventional 5w30 "dino oil"
77
5.58%
Voters: 1381. You may not vote on this poll
The DEFINITIVE oil thread
Old Jun 27, 2012 | 03:24 PM
  #481
MPdesign's Avatar
MPdesign
Question
The dealer just changed my oil and they used Mobile Clean 5W30.
This is an ordinary oil and they did not try to upsell me to a synthetic.
Do you guys have any recommendations/comments about that?
Old Jun 27, 2012 | 03:31 PM
  #482
Here's an interesting bit of info for someone changing their G's oil for the first time: there are no less than 16 M6x20 hex-head bolts holding the lower pan under the engine, and 3 push-tab clips.
Sixteen!!!
I'm thinking of replacing them all with SS or Ti, so they don't turn into hunks of rust over the next few years.
Old Oct 19, 2012 | 05:39 PM
  #483
Rocketman37's Avatar
Rocketman37
Purchased 2012 G37 Sedan on June 29,2012.Just had my 1st oil change,3900 miles,at dealer,who used dino oil.They recommended staying with dino oil for the first two oil changes to make sure the rings set properly?????(not sure they know what they are talking about since there a lot of new cars that come with a Syn. fill). They then say after the first two oil changes with dino oil,one can then go to Semi-syn or Syn. So my plan is to follow their instructions on the two dino fills and then go to syn. I will change oil myself from this point on. I will use dino for this 2nd change in 3K and then in another 3K go to Syn.,most likely Pennzoil 5W30 Syn.and then will change every 5K. I will use Wix filters. I have used this combination on previous vehicles without any issues. Why change now! Go with what has worked for you!!!!!! There are probably no wrong answers to oil and oil changes, as long as one uses a good quality oil and changes the oil at reasonable intervals.
Old Oct 19, 2012 | 05:49 PM
  #484
The seems to be a common recommendation: first two w/dino, then switch to synthetic.
Since that's the path you're going down anyway, just roll with it.
Old Oct 22, 2012 | 01:09 PM
  #485
Coprolite's Avatar
Coprolite
Rochester, I just saw your post from June. You do realize that not all the screws need to be removed to change the oil?
Old Oct 22, 2012 | 01:30 PM
  #486
LOL! After the fact I did, yes. But really, removing the entire panel isn't horrible.
Old Dec 21, 2012 | 09:25 AM
  #487
Zack342's Avatar
Zack342
Any concerns with running german castor oil 0W30 on a manual car with 11k?
Old Dec 21, 2012 | 10:50 AM
  #488
I'd have enormous concerns running any brand of castor oil in your car, from Germany or anywhere else.
But I'm guessing you meant Castrol. And I'm curious why you'd want to run 0w30. Any particular reason for not wanting to use 5w30?
Old Jan 24, 2013 | 04:28 PM
  #489
n33raj's Avatar
n33raj
Which Engine Oil to Use for 2012 G37
I have a 2012 g37x. Which engine oil should I use or which is recommended. Thanks
Old Jan 24, 2013 | 04:34 PM
  #490
5W-30
For brands, or dino vs. synthetic, read up and make your own choices:
https://www.myg37.com/forums/general...il-thread.html
Old Jan 24, 2013 | 04:39 PM
  #491
pauliewalnutzz's Avatar
pauliewalnutzz
Olive oil.
Old Jan 24, 2013 | 04:56 PM
  #492
rlo's Avatar
rlo
Originally Posted by pauliewalnutzz
Olive oil.
Expensive oil change.
Old Jan 24, 2013 | 05:33 PM
  #493
Rad_Slinger's Avatar
Rad_Slinger
actually....probably be cheaper than the penzoil ultra i use.
Old Jan 24, 2013 | 06:30 PM
  #494
00Max00's Avatar
00Max00
Come on guys, OP is seeking help. Yes, you should be fine as long as it is 5w-30 SM required by warranty, but I prefer M1 EP.
Old Jan 24, 2013 | 06:32 PM
  #495
00Max00's Avatar
00Max00
Some extra virgins are considerably more expensive.
