View Poll Results: What brand of oil do you use in your G coupe/sedan?
Motul (300v or 8100)
56
4.06%
German Castrol
44
3.19%
Amsoil
46
3.33%
Redline
49
3.55%
Royal Purple
79
5.72%
Mobil 1 Synthetic
653
47.28%
Pennzoil Platinum
133
9.63%
Valvoline SynPower
31
2.24%
Eneos Synthetic
22
1.59%
Quaker State
0.72%
Lucas Oils (synthetic)
0.43%
Schaeffer Synthetic Oil
0.29%
Nissan Ester Oil
171
12.38%
Conventional 5w30 "dino oil"
77
5.58%
Voters: 1381. You may not vote on this poll
The DEFINITIVE oil thread
Old Mar 8, 2012 | 09:45 PM
  #451
Steveo47's Avatar
Steveo47
Originally Posted by Coprolite
There is no need to get any ester related oil for a 2012. The ticking is related to a limited number of the original 3.7 with vvel back in '08 or so. Go with whatever 0w30 or 5w30 API certified oil that makes your day. Be sure to change at least every 6 months or 7500 to maintain warranty. Factory fill is Nissan Oil with Ester additives fwiw.
I will be using Pennzoil Ultra 5w30 API SN at the end of the month.
not true, my 2010 g37x had said tick as well
Old Mar 18, 2012 | 02:35 AM
  #452
FlState's Avatar
FlState
In the beginning of this thread, I saw people putting that they got the pen ultra 5-30 for $22-25 dollars, when I search around its no cheaper that $55! Has oil prices risen this much?! Is there any good websites were I can get a good deal? Thanks!
Old Mar 18, 2012 | 03:33 AM
  #453
About $28 for the 5 qt. jug everyday at Walmart.
Old Mar 19, 2012 | 12:06 AM
  #454
litesleeper's Avatar
litesleeper
quick question,
thinking about switching to M1 synthetic (I'm at 20k right now), what monthly interval would my oil changes then be? I know its 7500 for the mileage interval, but I don't drive much and I fall under the "schedule 1" category for primary driving condition (extremely short stop/go commute to work everyday), so would it be like every 5 or 6 months for the interval?
thanks!
Old Mar 19, 2012 | 12:16 AM
  #455
Coprolite's Avatar
Coprolite
Did you ever record it? I was simply referring to the timeframe covered by the TSB.
Old Mar 19, 2012 | 12:57 PM
  #456
FlState's Avatar
FlState
Thanks BlackBetty, I'll go check at Walmart.
Old Mar 20, 2012 | 08:42 PM
  #457
joesg37xs's Avatar
joesg37xs
1st oil change! Help!
Proud owner of a 2012 G37xS coupe. Just hit 3000 miles and want to change out the oil. I'd like to run a full synthetic but I have no idea which to run. I've read on here Redline 5w-30 is a great choice, and the dealer said they use Mobil 1 5w-30 for customers that want a full synthetic. The guys at advance auto parts insist Amsoil, royal purple, and Mobil 1 are the best oils (typical) but I know this engine is harsh on oil and with all the hype on Nissans ester oil and the valve ticking caused by extended intervals with readily available synthetics I'm confused beyond belief. Is Redline worth it? My dad keeps telling me to use Mobil 1 and change every 6000 but I need a second opinion. Please Help!
Old Mar 20, 2012 | 10:40 PM
  #458
Tonewheel's Avatar
Tonewheel
Congrats on the new ride. I have the exact same car...picked it up three weeks ago.
It's my 4th Infiniti; (2) I30s and an M35x. The Infinitis, and every other car I've owned back to 1980, have seen M1 run through their engines. I've always run the original oil for 2,000 miles, then change to M1.
Listen to your Dad. 6,000 miles is a good interval. And despite the fact that this thread is all about oil brands, don't get too hung up on it. If you change your oil...any oil...regularly, you'll never had an oil-related engine problem. This I know from 40 years of car ownership and many different cars.
Old Mar 21, 2012 | 08:30 AM
  #459
joesg37xs's Avatar
joesg37xs
Thank you very much sir for the advice. I'm going with M1!
Old Mar 21, 2012 | 08:31 AM
  #460
Chris11LE's Avatar
Chris11LE
I used to use Mobil1 exclusively but then came the whole "is it REALLY full synthetic?" debates.
Right now I use either Valvoline Full Synth or Pennzoil Ultra. Read somewhere they are 2 of only a few that actually state it meets the ester oil "requirement" from Nissan. My car is a 2011 and doesnt require the ester but if I can get an oil that meets the requirement Ill do it anyway. I get the tick at startup (I think everyone does) but after the car is running for 15 seconds or so it silences itself.
During warranty Id at least try to stick with 5W-30, Im pretty sure thats something the dealer COULD figure out if you needed engine work under warranty. For Mobil1, I keep hearing that 0W-40 is their best product right now, but with the 40 weight its just gonna run the oil temp up high which ends up putting the car into limp home mode faster. Maybe not a big deal in everyday driving (might be an issue in stop and go), but just something to think about.
Old Mar 21, 2012 | 10:56 AM
  #461
g37jtech's Avatar
g37jtech
I'm a big fan of Mobil 1
Old Mar 21, 2012 | 11:02 PM
  #462
Coprolite's Avatar
Coprolite
Only the Nissan Ester oil "meets the requirements" to be used for the VVEL tick, which is actually more of a thumping. The startup sound when cold is a different engine timing and A/F mixture designed to warm up the cats quickly and lower emissions. The two sounds are quite different.
Old Apr 3, 2012 | 05:04 PM
  #463
g37 IPL's Avatar
g37 IPL
Mobil 1 synthetic 5 w 30..love it,feels alot better!!!!
Old Apr 22, 2012 | 03:16 PM
  #464
G37SBS's Avatar
G37SBS
Mobil 1 extended performance
I just switch to Mobil 1 extended performance 5w-30 with mobile 1 filter and i just want to know how often should i change the oil? every 3k like before or 5k? The bottle says every 15,000 miles but i don't believe it.
Thanks
Old Apr 22, 2012 | 03:23 PM
  #465
hobbs's Avatar
hobbs
Originally Posted by G37SBS
I just switch to Mobil 1 extended performance 5w-30 with mobile 1 filter and i just want to know when should i change the oil again? every 3k like before or 5k?
Thanks
Just received a UOA from Blackstone Labs from my 15,000 mile oil change with 5,400 mles on the oil. Blackstone said OK to run until 7,500 miles next time.
