Old Dec 1, 2024 | 04:14 PM
  #10066
socketz67's Avatar
socketz67
Community Builder
You don't have to lift up the cowling against the windshield, that's not where it goes.
Take off the battery area lid. Then remove the 5 push-clips that hold the area together and lift the plastic trim out of the way. If you're facing the battery from the front of the car, this bracket goes at about 4:00. There are two holes one over the other on the curvy sheet metal, that's where this bracket clips into place. There another one on the brake side, if you're looking for an example and that one is still there. With the bracket in place, one of those five push clips has a place to go, and gives just enough structural integrity so the whole thing stays in place without flopping around.
@socketz67 Does this help?
Thanks. I will try to check later today after I hang some Xmas lights. Thanksgiving was late this year, so Christmas has snuck up on me.
Old Dec 5, 2024 | 08:15 PM
  #10067
FrogmanKouki's Avatar
FrogmanKouki
Cyber Monday Order has arrived...
  • Morimoto Fog lights
  • Morimoto XB bulbs
  • Z1 LED license plate lights
  • Z1 High Capacity Diff cover
  • Z1 Diff Bushings
  • Z1 Diff Bushing Removal tool
  • Z1 Subframe collars
  • Z1 Billet Sway Bar Mounts
  • Z1 Rear Sway Bar Endlinks
  • Voodoo13 Front Sway Bar Endlinks
  • Motul gear oil
  • Eneos motor oil and OEM oil filter
  • Z1 drain plug
  • Z1 oil funnel
  • Z1 phone mount
    Now to be honest not all parts were ordered on cyber Monday, some were purchased over the summer. Still a decent amount of parts to put on when the weather permits.
Old Dec 5, 2024 | 08:16 PM
  #10068
Krzysztof47's Avatar
Krzysztof47
  • Morimoto XB bulbs
  • Z1 Diff Bushings
  • Motul gear oil
  • Z1 drain plug
  • Z1 oil funnel
  • Z1 phone mount
Quite the haul haha.
You will like the XB fog lights, I have had them for a couple years and they have a really cool lens.
Old Dec 5, 2024 | 08:35 PM
  #10069
thescreensavers's Avatar
thescreensavers
I too ordered a few items for Black Friday . Since I've decided to keep the G 2-3 more years decided to splurge a little. Tried to buy an OEM front lip but damn they are crazy expensive.
  • New Headlights Lens's
  • Klearz Clear headlight side marker
  • Android Auto/Carplay Unit (I'll do a small write up if all goes well)
  • Black Front Grill
  • Paint correction (Rupes Yellow with Sonnax Perfect Finish)
  • Ceramic Coat
Going to be busy this winter break
Old Dec 6, 2024 | 09:48 AM
  #10070
socketz67's Avatar
socketz67
Community Builder
https://www.morimotohid.com/infiniti...ts-morimoto-mm
How easy were they to install? Looks like you opted out of the yellow protective film. Agree that the lens looks really cool/modern.
Old Dec 6, 2024 | 10:09 AM
  #10071
I've had Morimoto fogs for 10 years now. They continue to work, and they still look great.
Yellow tint is a pretty common thing with fogs, I'm not sure if for looks or function or both. I've got amber tint over mine.
/testimonial
Old Dec 6, 2024 | 10:54 AM
  #10072
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Rochester;[url=tel:4336459
4336459[/url]]Yellow tint is a pretty common thing with fogs, I'm not sure if for looks or function or both.
Technically, more function than fashion. The yellow, "warmer" light (3000-4500K) penetrates better in adverse conditions (rain, snow, fog) whereas the brighter "cooler" (6500K+) light output becomes more reflective in said conditions.
Then there are those who think they look "cool" (pun intended).
Old Dec 6, 2024 | 10:58 AM
  #10073
Entcee's Avatar
Entcee
I have yellow fogs. I have them for looks during the day (I leave them off day and night). However, a couple weeks ago we had some heavy fog and I was glad I had them. They really pierced through and allowed me to see the road better.
Old Dec 6, 2024 | 11:35 AM
  #10074
FrogmanKouki
I choose the yellow film for the fog lights in attempt to help with contrast plus I really like the "JDM" look it gives - my 1995 S14 had yellow fogs from the factory. Unfortunately a set of Diode Dynamics SS3 fogs are too big for the factory fog position. However, they are excellent on my truck...Yes that picture is just the fogs on my truck, almost don't need the low beams.
Old Dec 6, 2024 | 12:27 PM
  #10075
socketz67's Avatar
socketz67
Community Builder
good feedback. I’m always looking for subtle ways to modernize the car. I was in dense fog yesterday with my sons CRV during rush hour and that was not pleasant. The automatic headlights work against you in that weather.
Old Dec 6, 2024 | 09:13 PM
  #10076
STownSaint's Avatar
STownSaint
Ordered some OEM JDM tails from overseas.
Familiar with the slight mismatch between the tail light lens and the reverse light lens. So expecting the difference to be observable in-person, but I’m also kinda thinking that buying the full set together has a sliver of promise that things match?
If they don’t, I’ll be able to live with it
Old Dec 7, 2024 | 06:17 PM
  #10077
Krzysztof47
I just like the look of white light. Morimoto put a correctly shaped lens to project the light well.
They just screw in behind the bumper, had my shop put them on. I believe you just need to remove the splash shield underneath and then the wheel well plastics to get to them.
Old Dec 7, 2024 | 08:02 PM
  #10078
It's a relatively easy install, but up on a lift would make it sooo much easier.
Old Dec 7, 2024 | 09:54 PM
  #10079
mummy2's Avatar
mummy2
The drivers side you can just go through the fender liner with plenty of space. At least for the IPL, the passenger side I needed to get on the ground and reach underneath through the fender liner to get access with an electric rachet because the windshield washer tank is in the way. Had to unscrew a few screws to pull the bumper back to have enough room. Already have the bulb installed when installing the lamp.
Old Dec 8, 2024 | 09:44 AM
  #10080
socketz67's Avatar
socketz67
Community Builder
/testimonial
What material did you use for the amber tint?
Morimotos have plastic lenses vs glass correct?
