Old Dec 3, 2020 | 09:50 PM
  #8266
backman_66's Avatar
backman_66
Originally Posted by RobC7
That looks really sharp and should look even better with a mild drop. Very functional setup!
Question regarding Nismo springs. Why are you planning on doing pre 2016 springs, what is the benefit? Do you have any pictures of anyone running the Nismo springs? Any idea how different the spring rates are?
The pre 2015 springs are stiffer than the newer Nismo springs and since the G is heavier than the Z, it would be better to use the stiffer springs when comparing it to my stock sport suspension. From what I researched, I have just seen comments saying it should be about a .5" drop compared to the sport suspension. As for the spring rates, here's a link with some numbers.. not sure how accurate it is. https://www.myg37.com/forums/brakes-...o-springs.html
Another reason to get these springs is so I don't have to worry about swapping my LCAs or anything since it's just a mild drop. And the price is pretty good on used nismo springs.
EDIT: Correction, it's pre-2015 nismo springs, my bad! The pre-2015 are red colored and 2015+ are black.
Old Dec 3, 2020 | 11:35 PM
  #8267
JSolo's Avatar
JSolo
Just say no!!!!!
@backman_66 Looks awfully familiar . I sure miss that car some days. Hope its treating you well.
Old Dec 4, 2020 | 12:06 AM
  #8268
backman_66's Avatar
backman_66
Yep its an awesome car!
Old Dec 4, 2020 | 09:00 AM
  #8269
rotarymike's Avatar
rotarymike
Moderator in Moderation
Those are VERY tight on the calipers
I'm considering the NISMO springs too, but... buying used springs probably not. I mean, the reason I want to replace my sport springs is that they're worn down a bit, right? So buying someone else's worn out springs seems no bueno. I need to see how much new ones are from Nissan - I doubt they're as expensive as coilovers.
Old Dec 4, 2020 | 09:10 AM
  #8270
backman_66's Avatar
backman_66
Lol yeah, it's pretty tight! It looks like a few mm which I think is the bare minimum amount of space needed to be safe. I'll just monitor it though and if I see any rub marks then I'll have to get some 3mm spacers or something.. not a big deal.
I'm not sure if you can just order nismo springs from the dealership... it probably has to be ordered as a shock and spring set. I don't mind getting used springs if they're under 50k miles.
Old Dec 4, 2020 | 10:17 AM
  #8271
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by backman_66
...I'm not sure if you can just order nismo springs from the dealership... it probably has to be ordered as a shock and spring set.
Yes, you can buy just the springs- they do not come as a "pre-installed" set with the shock. I looked into this a while back when I was looking into options for my Coupe. For the pre-2015, "RED" Nismo springs:
Fronts: Nissan p/n: 54010-6GA1A
Rears: Nissan p/n: 55020-1EA0B
Been a minute since I looked into this option, but if I remember the fronts were running about $165/ea. while the rears ran about $250/ea.
As I always recommend, VERIFY BEFORE YOU BUY! Nissan (& Infiniti) are notorious for changing things up with parts/part numbers.
Old Dec 4, 2020 | 10:20 AM
  #8272
backman_66's Avatar
backman_66
Wow that's expensive just for springs from the dealership!
Old Dec 4, 2020 | 10:27 AM
  #8273
ILM-NC G37S
That's called the "NISMO Tax."
Just like the "GT-R Tax" and the "Infiniti Tax" lol.
¯\_(ツ)_/¯
I'm sure those prices went up since I last checked. On the other hand, finding a set of NISMO springs- at least 6 years old- with low mileage and in good condition...
Old Dec 4, 2020 | 10:29 AM
  #8274
rotarymike's Avatar
rotarymike
And that right there kiddos is why this list is so helpful.
ILM, what are you using for parts lookup?
Old Dec 4, 2020 | 10:53 AM
  #8275
ILM-NC G37S
For the NISMO springs I honestly do not remember. I was looking into this project some time last year, but got side-tracked with the heated wheel/paddle shifter swap project...
Typically, for OEM parts, I use:
jp-carparts.com This is my main go-to. They're in Japan, but have the best online catalog parts diagrams. Once I find the part classification code (first 5 digits) then I cross-reference with either:
discountinfinitiparts.com (best prices- usually)
parts.infinitiusa.com (last resort)
If you know exactly what you are looking for, any online parts catalog/supplier will suffice...
Key is to ALWAYS verify BEFORE you buy.
Old Dec 4, 2020 | 06:36 PM
  #8276
rotarymike's Avatar
rotarymike
Oddly enough, there was a full set from a 2014 Nismo Z w/ 41k miles on eBay for less than one rear spring right as we were discussing this. Guess I'll try used after all.
Topic-relevant content - yesterday I installed the rear Hotchkis bar, which required removing the FI mufflers. Still looking good. Checked wheels to see if I had different rears (coupe v convertible) and checked hubs relative to bodywork to see if that was an issue (chasing the quirky alignment). Patched a rear tire that had collected a screw. Today I cleaned and started painting the rear calipers - cheap caliper paint and painting on the car, so not expecting grand results, but... I did the fronts this way about a year ago and they still look really good.
Pics on my build page, but nothing really exciting.
I'll have a stock set of Sport bars to sell shortly - I don't see the point of holding on to them.
Old Dec 4, 2020 | 06:44 PM
  #8277
backman_66's Avatar
backman_66
I just purchased a used set of nismo springs so I can report my results after I get them put on.
Old Dec 4, 2020 | 07:17 PM
  #8278
RobC7's Avatar
RobC7
Patiently waiting for results!
Old Dec 4, 2020 | 08:08 PM
  #8279
PNW_IPL's Avatar
PNW_IPL
Boring yall need to post more pics!
anyway. New seats for me!
Old Dec 5, 2020 | 09:11 PM
  #8280
tsuintx's Avatar
tsuintx
Thought about cleaning the engine bay of my latest acquisition I bought yesterday (2011 G37 Sedan). PO kept the car in great shape and maintained it well, but the engine bay was filthy.
Pulled out a rag and Purple Power and got to it, but didn’t get too far. Was wiping down the coolant expansion tank and without using too much force my finger broke through the plastc. LOL! That stuff was very brittle all over, actually. Was able,to pick up a replacement from local dealer (Grubbs in Grapevine, TX) for 85 bucks, so not a biggie.
Easy swap and the car is good to go again.
