Old Mar 2, 2019 | 02:17 AM
  #6361
llebcire's Avatar
llebcire
Originally Posted by rjbecker26
It’s only been 1 week since I bought my 2nd G, and I’ve already done a bunch for her.
- GT-R Start Button
- GT-R Map Lights
- Wrapped the Badly Worn Steering Wheel
- All new Interior LED’s, Trunk LED and License Plate LED’s from Diode Dynamics
- New Interior Aluminum Trim on the Drivers Side Front Door
- Replaced the Drivers Side Mirror
- Q60S Shift **** and Boot
You appear to have the same stone wheat interior as me? If so where did you get the wrap and how well does it match? Didn't realize you could swap the shifter may need to look into that as well.
Thanks!
Eric
Old Mar 2, 2019 | 08:28 AM
  #6362
RMB5190's Avatar
RMB5190
Ugh, I gotta get Ryne to make me a steering wheel.
Old Mar 2, 2019 | 10:07 AM
  #6363
rjbecker26's Avatar
rjbecker26
Thanks!
Eric
I actually have the black interior. The sun is just shining directly on the wheel, causing it to look like the stone interior.
Old Mar 2, 2019 | 05:18 PM
  #6364
rjbecker26's Avatar
rjbecker26
It’s really not a hard job to do on your own. It only really took me about 4 hours to wrap it myself, not including the time it took to remove and reinstall when I was done.
I honestly had fun doing it.
Old Mar 2, 2019 | 08:50 PM
  #6365
fillup's Avatar
fillup
link to the one you bought?
Old Mar 4, 2019 | 04:07 PM
  #6366
-ZS-Carpenter's Avatar
-ZS-Carpenter
Got high flow cats and the XYZ installed. Demon bolt was way harder than the Z but everything came apart.
ZdayZ prep has begun. Brakes, a Y back exhaust, fresh powder on the wheels and a tune are up next
Old Mar 4, 2019 | 11:11 PM
  #6367
vq37_'s Avatar
vq37_
Diode dynamics tail as turn and GTR start button
Installed both today, extremely easy to install.
Old Mar 5, 2019 | 05:12 PM
  #6368
-ZS-Carpenter
Remote start installed, I disabled the horn after taking the video. 6/10 install just because of the 3 wire that need spliced and soldered. Took me 5 hour or so, wish I'd done it sooner.
Old Mar 5, 2019 | 06:24 PM
  #6369
iCrap's Avatar
iCrap
Which one did you install? I did the Fortin and it was just 1 wire that had to be spliced.
Old Mar 5, 2019 | 06:43 PM
  #6370
mvx's Avatar
mvx
- GT-R Start Button
- GT-R Map Lights
Nice! Was the Q60S shift ****/boot a direct fit? Also, isn't it a bit taller than the OEM one? I am considering in doing the same.
Old Mar 5, 2019 | 06:57 PM
  #6371
-ZS-Carpenter
It was the Fortin evo-nist1, had 1 on the starter button, one by the fuse box for the parking lights and 1 at the BCM in the passenger kick panel for the door pin.
https://cdn02.fortin.ca/en/download/24031/24031.pdf
all 3 are on page 4
Old Mar 5, 2019 | 06:59 PM
  #6372
rjbecker26's Avatar
rjbecker26
The **** was a direct fit, but the boot needed to be fit to the existing frame.
The boot itself comes on a frame that fits the Q60, so the leather needs to be removed from the Q60 boot and fit to the G37 frame. It wasn’t terribly hard to do.
I don’t see any height difference, to be honest. I absolutely love the new ****. My post further up in the chain has pictures comparing the **** heights.
Old Mar 5, 2019 | 07:23 PM
  #6373
iCrap's Avatar
iCrap
all 3 are on page 4
Ah yeah I didn't do the other two, just the starter one. I didn't understand the point of the door pin one. Once the starter times out the door still stays locked regardless.
Old Mar 8, 2019 | 11:40 PM
  #6374
PNW_IPL's Avatar
PNW_IPL
Installed the rear akebono. Need an angle grinder to finish the dust shield. Too much for my knock off dremel to handle. Once i started i had to make it work. Need to bleed the system. Front rotors arent here until next week
Old Mar 9, 2019 | 03:30 AM
  #6375
qmantran's Avatar
qmantran
I won these in a raffle. Just installed them today. You can't tell from the picture or video but it's a red & amber switchback ring.
parking mode = rings are red LEDs
turn signal = rings blink bright amber
brakes = uses the factory led dots
Parking mode red rings
Turn signal bright amber
My factory taillights with GTR overlay cutout.
