Old Nov 25, 2017 | 03:13 PM
  #3991
slartibartfast's Avatar
slartibartfast
Hotchkis indeed supplies Zerk fittings on the brackets.
Old Nov 25, 2017 | 03:30 PM
  #3992
Entcee's Avatar
Entcee
Decisions decisions. Still leaning Eibach lol
Old Nov 26, 2017 | 03:40 PM
  #3993
carguy95's Avatar
carguy95
Let me ask you this - why not Whiteline? I have their diff. bushings on my car, and I love them. I'm definitely going to give their sway bars a try (even though they are the most expensive) in the near future.
Old Nov 26, 2017 | 04:10 PM
  #3994
MaQG37's Avatar
MaQG37
I do not think you will be able to discern the difference in performance between the two. Go for the Hotchkis since it's easier to maintain with the zerk fitting.
Old Nov 26, 2017 | 04:27 PM
  #3995
Entcee's Avatar
Entcee
Mainly because they cost about 33% more. I did consider them though.
I am going Hotchkis mainly because of the zerk fitting. And after a ton of reading opinions, it's likely that I'd use the most stiff setting for the front on the Eibachs, which is similar to the Hotchkis. For the rear, Hotchkis middle setting is similar to the softest on the Eibach. Doubt I'd ever want more stiff than that. Hotchkis has one setting lower so I figure Hotchkis has more usable adjustment.
Old Nov 26, 2017 | 05:56 PM
  #3996
ezbme's Avatar
ezbme
Has anyone installed the Subframe Collars? I want to know if it is worth getting it done. It will add $125 to my order.
Old Nov 27, 2017 | 01:30 PM
  #3997
markyo0o's Avatar
markyo0o
Originally Posted by defektion
This issue happened to me, so what I did was grabbed a pair of small vice grips to bite the nut from behind. I then proceeded to turn the bolt and it eventually came out.
I then replaced it the screws with a kit similar to this
https://www.amazon.com/Stainless-Lic.../dp/B013A0Y8J0
The caps are nice because it blends in with my license plate frame.
Tried this over the break and no luck. How did you manage to grab a hold of the nut when its in a rubber encasement? Only top part of the nut was exposed and I couldn't get enough grip to hold it still.
This is such a dumb problem to have lol. I'm about to sawzall this thing.
Old Nov 27, 2017 | 01:59 PM
  #3998
EcstaticG37XS's Avatar
EcstaticG37XS
Had the transfer case, front, and rear diff fluids changed with Redline.
Also, swapped out the dinky AWD rear sway bar for a 2016 Nismo 370z sway bar. Wow, the car handles so much better, but it has gotten stiffer. I can definitely feel a rougher ride.
Old Nov 27, 2017 | 03:19 PM
  #3999
iCrap's Avatar
iCrap
I had this problem...
If i remember right the plate holder is a peice of black plastic riveted onto the bumper What I did was drill out the rivets, remove that peice completely.... Then i just broke the nuts completely off, and JB welded some new M6 nuts in place, and reattached the black bracket back onto the bumper with screws and nuts.
Old Nov 27, 2017 | 03:29 PM
  #4000
slartibartfast
If you feel ride in the rear is stiffer on bumps that affect both rear wheels, then something is wrong with the installation. Sway bars are only felt on asymmetric bumps.
Old Nov 29, 2017 | 02:52 PM
  #4001
2010sedanS's Avatar
2010sedanS
Added the ebay ***** and think they look much better than the OEM rubber ones. I know carsmo are much better quality but couldn't justify spending over 10x more for them. Happy with my $5 purchase.
Old Nov 29, 2017 | 03:12 PM
  #4002
r2dmax's Avatar
r2dmax
Please send the link!
Old Nov 29, 2017 | 04:27 PM
  #4003
2010sedanS's Avatar
2010sedanS
Check this thread:
https://www.myg37.com/forums/g37-sed...g37-sedan.html
Old Nov 29, 2017 | 05:54 PM
  #4004
slartibartfast
CARSMO or go home. <drop mic>
Old Nov 30, 2017 | 12:29 AM
  #4005
Epiphany's Avatar
Epiphany
Coming from a Canadian, not a chance. They're great ***** and they're made extremely well, but it'd be over $100 to get a set here. I've got the same ***** above for $6. You can't tell me the Carsmo ***** are worth $95+ more.
