Old May 24, 2017 | 09:12 AM
  #2971
mdigiorgio35's Avatar
mdigiorgio35
the tail as turn mod is the easiest manual labor for maximum results
Old May 24, 2017 | 09:40 AM
  #2972
Originally Posted by Bota36
Installed the Turn as Tail module, cleaned the engine, detailed the exterior and polished my headlights. I'm fricken beat up. Spent about 2 hours on the headlights. Good news is they look new.
It certainly does look good in those pics.
Haven't seen you around the forum in a long time. Been in a coma?
Old May 24, 2017 | 10:08 AM
  #2973
King 0din's Avatar
King 0din
ooooooo.. I'll do this next also!
Old May 24, 2017 | 10:22 AM
  #2974
Nico-derm's Avatar
Nico-derm
It's a two beer minimum. One before the job cause they're delicious, one quickly after as you admire your work and put your screw driver away.
EDIT: I had a third in the middle because I like beer, also installed CARSMO ***** and modded GTR Start button in the same 20min
Old May 24, 2017 | 10:28 AM
  #2975
Originally Posted by Nico-derm
It's a 2 beer minimum. 1 before the job cause they're delicious and one quickly after as you admire your work and put your screw driver away.
Here's a Tail-as-turn tip: use some indoor/outdoor mounting tape to adhere the unit to the trunk frame behind the liner.
The new turn signal behavior is a solid improvement, supporting a contemporary design, but it's kind of anti-climatic. The moments when you can actually see the turn signal in action are really rare... like when there's a storefront window at the proper angle to notice what's going on.
Old May 24, 2017 | 10:30 AM
  #2976
Nico-derm's Avatar
Nico-derm
I used the mounting tape, Gorilla clear.... the screw driver was used to remove the cargo net clips.
Did you ever figure out what the yellow wire was for lol?
Old May 24, 2017 | 10:32 AM
  #2977
Entcee's Avatar
Entcee
+1 I used 2 heat sink pads on the outside ends of the resistor and indoor/outdoor tape in the middle and mounted it to the trunk frame.... just to help dissipate heat
Old May 24, 2017 | 10:53 AM
  #2978
Wow. Now that's thorough. Hats off to you, Entcee.
No I didn't. Forgot all about that. Any idea?
Old May 24, 2017 | 11:48 AM
  #2979
Nico-derm's Avatar
Nico-derm
I watched an online video... he just left it hang. I'm surprised that DD never responded when you asked the question, they were active in that thread if I remember correctly?
Old May 24, 2017 | 12:18 PM
  #2980
UserNamee's Avatar
UserNamee
I installed the driver's side rear tail light. I searched all around for an OEM tail light at a budget friendly price and was able to find it at https://www.infinitipartsdeal.com/pa...555-jk60b.html. It was an easy install too.
Old May 24, 2017 | 01:21 PM
  #2981
Nico-derm's Avatar
Nico-derm
You should have checked the classifieds... ZM is selling a "Near New" set for $120
https://www.myg37.com/forums/private...il-lights.html
Old May 24, 2017 | 01:26 PM
  #2982
I bumped that question this morning. Here's the response:
Originally Posted by Diode Dynamics
The yellow wire is unused on the G35/G37's. For some vehicle-specific applications, it allows you to use the factory turn signals as additional backup lights, but the lenses are red on the G's, so that's not compatible.
Thanks!
Nick C.
Really should have that in the instructions. Maybe they did?
Old May 24, 2017 | 02:15 PM
  #2983
2GoRNot2G's Avatar
2GoRNot2G
That's odd. I used the yellow wire when I installed mine. Although I do have LED's for my factory turn signals and have those flashing along with LED rings, so maybe that's why I used it... It's been so long since I installed it that I can't actually remember what I did.
Will pull the trunk liner and take a pic when I get a chance so I can figure out what I did. LOL
Old May 24, 2017 | 03:48 PM
  #2984
King 0din's Avatar
King 0din
Sedan owners, I have something really awesome to show you, it's one of a kind and as far as I can see no one has it! If anyone can guess what is, well, it won't be a surprise than.
Old May 24, 2017 | 04:10 PM
  #2985
slartibartfast's Avatar
slartibartfast
^^You mounted a wing on your hood.
