SEDAN | Official Aggressive Offsets & FAT Tires
Old Feb 22, 2017 | 11:24 AM
  #151
Unfortunately the sedan has about 15mm less at the fenders, most sedan guys run +35 in front on a 9 to 9.5width and a +40 to +45 in back on a 10 to 10.5" width to get flush w/ in spec camber. There's ways to get those to work but the end result won't be a great way to roll on a daily basis
Old Feb 22, 2017 | 12:34 PM
  #152
Fritz's Avatar
Fritz
Thank for the info Blnewt! I didnt realize how much work it would take to get the wheels to fit on the sedan I might go ahead and sell the wheels and purchase another set of wheels. want to go as aggressive but practical as possible so might look into
20x9.5 +35
20x10.5 +30 or +35 ( trying to get a nice concave look)
Old Feb 22, 2017 | 01:44 PM
  #153
20x9.5 +35
Those would be much easier on your life
If you don't want to camber much then you'd probably have to run a 265 in back.
Old Feb 25, 2017 | 04:54 PM
  #154
IracknBack's Avatar
IracknBack
20x9.5 +35
You will need fender work or to have a ride height that doesn't allow the rear to touch on compression. Or minimum rolled fender with a little camber.
Front specs are right on though. Interested to see how it looks.
Old Feb 26, 2017 | 10:06 PM
  #155
Fritz's Avatar
Fritz
Thanks for the advice fellas! I ended up picking up a new set of wheels todayfrom another G37 owner who wanted a different look. (wheels were like new)
Went with
20x9 +32
20x10.5 +45
Really wish the rear was closer to +35 more of an aggressive look but they fit the sedan and tuck in with the airride without any problems at all.
Replacing rear tires that are currently 275/30/20...May push it up to 285/30/20 in the rear. Fronts are currently 245/35/20
Old Feb 26, 2017 | 10:59 PM
  #156
Nice^^^^Should be one thing less to worry about There's been a few that have ran 295/30s on 10.5+45s.
Old Feb 26, 2017 | 11:01 PM
  #157
Fritz's Avatar
Fritz
Good to know!! I appreciate all the knowledge and tips!
I will be doing my research soon on camber kits and toe bolts soon so I can take the car to the shop for a proper alignment!
Old Feb 27, 2017 | 08:17 AM
  #158
Here's one sedan w/ the 295s & your wheel specs
https://www.myg37.com/forums/g37-sed...rwd-sedan.html
Old Feb 28, 2017 | 02:45 PM
  #159
NZTY_VQ's Avatar
NZTY_VQ
Wheel fitment
hello alot of nice setups here! sedans look so good with fat tires! i have a question to ask the fitment gurus, anybody running 19x9.5 front and 19x10.5 rear with a +22 offset all around? can sedans work with these specs?
Old Feb 28, 2017 | 04:08 PM
  #160
Not without excess camber and stretched tires. Those width wheels should have +35 front +45 rear (give or take a few mm) if you want to run wider tires with your camber in spec or close to it.
Old Mar 20, 2017 | 03:13 PM
  #161
ToXIc's Avatar
ToXIc
anyone rocking a Fat tire setup on 18s?
Old Mar 20, 2017 | 05:37 PM
  #162
When my rear tires are done I'll be running 285s back there, almost makes me want to do some burnouts just to speed it up
There's a few coupes that have been shod w/ 285s on 18s but can't dig up pics right now.
Old Mar 21, 2017 | 09:22 AM
  #163
ToXIc's Avatar
ToXIc
lol burn baby burn lmao
Old Mar 21, 2017 | 05:43 PM
  #164
2GoRNot2G's Avatar
2GoRNot2G
Here's my set-up.
Wheels: Volk GT30's
F: 20"x9.5" +30mm (+35mm - 5mm)
R: 20"x10.5" +25mm (+37mm - 12mm)
Tires: Toyo T1 Sport
F: 255/30R20 (soon to be 275's)
R: 305/25R20
Camber for all four corners between -1.5° and -1.7°
Notes: Wheel specs includes spacers. And rear fenders have been widened by almost 1-1/2" per side.
Old May 17, 2017 | 01:22 PM
  #165
Ok, I was part of the square club but had to get back to fat, went from 245/45/18s all around to 285/40/18s in back all on 18x9.5 +38s
