Sedan Chat Thread
Old Oct 11, 2014 | 04:13 PM
  #4291
nishfish871's Avatar
nishfish871
Originally Posted by alxmlr789
Happy Friday guys! Just got everything set up, and aligned. Took some patience and lots of adjustment but here she is finished:
Looks great!!!
Old Oct 11, 2014 | 08:49 PM
  #4292
alxmlr789, G is looking sweet!
Looks like you dropped it pretty low on your BCs, how did your alignment turn out?
That's about the same drop I had before I got my coilovers, loved the look but my Y-pipe braids turned into shredded cornrows
Thanks for the pic
Old Oct 11, 2014 | 10:33 PM
  #4293
Mik3G37S's Avatar
Mik3G37S
Alxmlr789 well that is fast car modding if you ask me. Looks very nice!
I will be getting my differential fluid replaced and I wanted to ask you guys for the exact part number for Motul differential fluid and where can I order it from, also a brake pad change is coming up and I'm thinking to go with Hawk HPS pads, any pros and cons and what's the best place to get them for the best price?
Old Oct 12, 2014 | 12:35 AM
  #4294
Choman's Avatar
Choman
Mike - your search feature is your best option...
Old Oct 12, 2014 | 02:29 AM
  #4295
Mik3G37S's Avatar
Mik3G37S
Yeah bla bla I was just waiting for it. I was on my phone on the app and it is a PITA to search for anything, thought it wouldn't harm anyone to ask since it is a chat thread anyway
Old Oct 12, 2014 | 08:41 AM
  #4296
Lego_Maniac's Avatar
Lego_Maniac
I've used HPS pads on 3 different cars. They have good initial bite and fade resistance, but they are dusty. If you track your car, you should probably get something more aggressive.
I'm running the nismo r-spec pads and they have similar characteristics--good initial bite and fade resistance, low noise, work good cold and dust more than stock.
Dont forget to bleed your brake fluid
Old Oct 12, 2014 | 08:58 AM
  #4297
Kevin, does the clutch pedal feel any different now that you have the Z1 CSC installed?
Old Oct 12, 2014 | 09:39 AM
  #4298
warped ideas's Avatar
warped ideas
A quarter past stripped
I also use the NISMO R-Spec pads with my Akebonos. They work well for me as a DD without tracking my car. If I remember correctly they cost roughly $100 for the fronts and rears. They do dust up a bit more than the OE pads but It's not an issue really.
Old Oct 12, 2014 | 10:41 AM
  #4299
Lego_Maniac
I got them when I ordered my car. The dealer initially quoted me 99.99 front 89.99 rear and said he would do them for $100 + install. When they came in they told me they misquoted the price and it was really like $500 but they would honor the price.
At $500 I'd pass, at $200 they are a good value. Car & Driver put them on a 370z and shaved a car length off the 70-0 brake test.
In other news, I'm at Costco getting PSS mounted and balanced
Old Oct 12, 2014 | 10:46 AM
  #4300
alxmlr789's Avatar
alxmlr789
Thanks for the pic
Alignment turned out pretty good. it was SO jacked up from the coilover/SPC rear install that the height got adjusted during the alignment.
Now that i'm spec, i've gotta raise the passenger side, so i'l be getting it aligned again after i make some adjustments. I've gotta switch up tire sizes in the front, going from a 225/35/20 to a 245/35/20 to be safe. The roads here are not great and there is just not enough protection with the 225's. Love the stretched look but on a daily driver it's just not sustainable.
Old Oct 12, 2014 | 11:25 AM
  #4301
I don't think I ever knew about this OEM upgrade.
When it's time for pads, I was going to go with Hawk HPS. What do you think... HPS vs. R-Spec?
Old Oct 12, 2014 | 11:35 AM
  #4302
At 6k miles per year you should be due around 2020
Old Oct 12, 2014 | 11:52 AM
  #4303
I've got almost 21K on the OEM pads right now, so I figure in two more years, three tops. But yeah, pad and rotor replacements for my BBK are way off in the distance. Along with that will be painting the calipers. Made that decision this summer after looking hard at the mod.
Old Oct 12, 2014 | 12:05 PM
  #4304
I was way off So only 2017
Definitely looking forward to your caliper project, it'll be another Rochester FTW!
Old Oct 12, 2014 | 12:36 PM
  #4305
Thanks, Brad. I suspect 2016 to 2017, but you got the right idea.
I was never really excited about caliper painting (notwithstanding the amazing work that JPSBLACKG37 does), until I saw tonyHTX's pictures of the Akebono setup in Acura Rio Pearl Yellow. That really grabbed my by the short hairs and got my attention. I did some local research on shops, cost and different approaches to the project. And then I put the whole idea back on the shelf, realizing that 3+ year old, OEM rotors would compromise the look.
And as much as I like that Rio Pearl Yellow, I'm also very much considering a bronze color, instead. Neither yellow nor gold nor orange... bronze.
