mods4cars smarttop install on an Infiniti g37 convertible
Mr. Drop it like it's hot
When the operation stops and the roof sags that's when you will be out of alignment.
Just an update, I updated the module and still got the same issues so I disabled the module but didn't uninstall it.
Still getting the same issues so it may not be the module causing the issues but I think the module may be causing the electronics controlling the top to have some issues. Last time I was at the dealership, they told me the top control computer was all wonky when they did a diagnostic on it so they resetted it. Booked another appointment with the dealership with the module disabled and they'll probably just reset the car electronics.
As for the "truck open" issue, I did bring this issue to the dealership before. they found the trunk latch to be loose and just tightened it and it solved the issue. So i'm hoping that's the same problem now. I did give it a shake and it does wiggle a bit with enough force. We'll see what happens after the appointment!
SmartTop Install Video
Hi -
We had a few issues trying to get the SmartTop to work right on a Mercedes CLK350 and thought you could benefit from the struggles we went through. Not sure how it translates to Infiniti, but hopefully you can get some good advice from it:
superjoey
31
Mar 22, 2023 11:56 PM
I'm going to have to mess around with the blinker / top button programing still don't under stand how to work it.
