Help Engine swap
Old Apr 24, 2025 | 01:25 PM
Cambrony's Avatar
Cambrony
Engine swap
I have a 2010 g37x AWD sedan that needs an engine, checking compatibility issues before sourcing parts.
I found a 2012 engine for it, will I need to get anything besides the engine if using this engine such as ecm, bcm, or wiring harness?
Will an engine from a other 2010 be a direct swap?
Whatever makes the swap easiest is what I'm looking for.
Old Apr 24, 2025 | 01:52 PM
projectpanda13's Avatar
projectpanda13
If you are only swapping the engine, the 2012, or any year VHR, will pretty much be a direct swap. If its from a G37 or 370z, all accessories can be used. If from a Q50 then you have to reuse the the powersteering pump from the G.
I have a 2015 engine in my 2010 G37.
You can reuse your engine harness and ecu. I believe the 2010 has a different upstream o2 sensor plug so before to reuse the o2 sensor off the 2010 engine or buy the correct one for new.
Old Apr 25, 2025 | 11:42 AM
Cambrony's Avatar
Cambrony
The engine will be from another 37x Awd sedan.
Im buying the engine from a junkyard so trying to reuse everything I have on the car or trying to get everything else i could possibly need while I'm there.
AV37
Feb 25, 2025 03:41 PM
AV37
Aug 27, 2024 10:17 AM
AV37
Mar 12, 2024 01:31 AM
Slo_G
Mar 8, 2024 10:51 AM
roylan
May 27, 2021 06:18 PM
