Help with flex disk driveshaft coupler guibo
Old Aug 24, 2019 | 10:34 AM
  #31
SonicVQ's Avatar
SonicVQ
The guibo's other purpose is to provide a "cusion" to the drive line to reduce short duration, high impact shock. It is very similar to a "cush drive" used on motorcycles.
If a solid metal guibo is used, something in the driveline might break, most likely in the transmission.
Old Aug 24, 2019 | 02:45 PM
  #32
Bravo at's Avatar
Bravo at
What’s a different material that would be more appropriate other than the rubber?
Old Aug 24, 2019 | 03:07 PM
  #33
slartibartfast's Avatar
slartibartfast
Originally Posted by SonicVQ
The guibo's other purpose is to provide a "cushion" to the drive line to reduce short duration, high impact shock. ... If a solid metal guibo is used, something in the driveline might break, most likely in the transmission.
For the 5AT/7AT owners, I don't believe this is of concern. The MT guys definitely need to worry about this.
Old Aug 24, 2019 | 03:09 PM
  #34
slartibartfast
I don't think any other material would work for you manual owners. I suspect urethane would crumble in fairly short order.
Old Aug 24, 2019 | 06:27 PM
  #35
SonicVQ's Avatar
SonicVQ
I am not so sure about that... What about the jolt to the driveline every time the car is put into drive or reverse?
Old Aug 24, 2019 | 11:51 PM
  #36
slartibartfast
The torque converter is a fluid coupling. It cushions the blow. Granted, there may be enough driveline lash with an auto to make this a problem, but I doubt it.
Old Aug 25, 2019 | 09:54 AM
  #37
SonicVQ's Avatar
SonicVQ
Just a thought...
The Driveshaft Shop (https://www.driveshaftshop.com/impor...num-driveshaft) shows what looks like to be a replacement guibo in the bottom right: Maybe they will sell them seperately?
Old Oct 16, 2020 | 07:03 PM
  #38
kRAM's Avatar
kRAM
Bring back an old thread but was there any update to this other than buying a complete driveshaft replacement?
ttv36
38
Nov 27, 2023 09:17 AM
mobe
May 26, 2020 03:52 PM
Kyle Thorpe
Aug 11, 2017 01:01 PM
Phx-G37s
Jul 27, 2016 05:56 AM
nogoer
General Tech Questions
Feb 19, 2016 02:32 PM
