has anyone changed thier own driveshaft carrier bearing?
Old Jan 25, 2016 | 05:22 PM
nogoer's Avatar
nogoer
Im int he middle of replacing mine as its vibrating like a son of a and im stuck trying to get the actual bearing off the driveshaft. It's pressed on but the rubber around it makes it impossible to use a puller on as it just stretches rather than pull the bearing off. If anyone else has done this do you have any insight as to how to get this thing off?
thanks
Old Jan 25, 2016 | 07:21 PM
nogoer's Avatar
nogoer
solved it on my own
In case anyone else finds this. Turns out if you cut the outside metal rings off you can get your puller on harder material closer to the bearing and it will pull off. The outside rings are just held on by soft rubber easily cut and trimmed down to the core bearing.
Old Feb 19, 2016 | 11:47 AM
LonnieB's Avatar
LonnieB
good information
"Turns out if you cut the outside metal rings off you can get your puller on harder material closer to the bearing and it will pull off." 3
This is good information-thanks
Old Feb 19, 2016 | 02:32 PM
m3clubracer's Avatar
m3clubracer
thanks
Good to know. Can you describe the conditions that you were seeing/feeling?
jscho5
Dec 10, 2023 11:41 AM
g37tx
Jan 21, 2016 01:25 AM
nogoer
Jan 18, 2016 09:24 AM
Gearratio
Jan 6, 2016 06:31 PM
