Help with flex disk driveshaft coupler guibo
Old Jun 3, 2018 | 12:01 PM
rctstdroid1's Avatar
rctstdroid1
Originally Posted by crookncastle
aluminum is softer than steel. if anything the stress from the drive line will wear away the all aluminum coupler disc. the rubber style flex discs take the place of u-joints on a driveshaft. i would not suggest using a solid piece like the one you have in the pic. i would just try and find a flex disc with the specs closet the original one that came off the car.
the problem is that no exist..
Old Jun 3, 2018 | 12:08 PM
Surfnazi's Avatar
Surfnazi
Without bushings it's going to vibrate alot mote
Old Jun 3, 2018 | 12:31 PM
rctstdroid1
well . if the product no exist in any place, the solution is contact to manufactory for make a lot of flex disk. i search in the alibaba and found a seller thats can do replicate with a measure . but the minimum is 100 units. what do think.
this a seller https://www.alibaba.com/product-deta...512295260.html
who here have a experience buying in alibaba?
Old Jun 3, 2018 | 01:07 PM
Bravo at's Avatar
Bravo at
Driveshaft coupler/flex disc
We need a good vendor to support this and maybe help the vendor with a group buy to build confidence that the vendor’s effort will payoff.
Looking for a part out to purchase, then grab several measurements for us to use.
Keep plugging away.
Old Jun 7, 2018 | 09:53 AM
rctstdroid1
Dear Sir,
Good day.
Thank you for your enquiry.
About your enquiry,I would like to ask how many pcs do you need?
Contact me ,if anything I can do. We are always here for your any question.
Looking forward your early reply.
Best regards
Melody
FORWARD AUTO PARTS CO., LTD
DOMINANT CO., LTD
ADD: BUILDING 1, HANGZHOU NET INVESTMENT CREATIVE CULTURE PARK, NANHUAN ROAD, BINJIANG DISTRICT, HANGZHOU, ZHEJIANG, CHINA
TEL: 0086-571-87752800
FAX:0086-571-87752800
SKYPE: sales01-fwd
Email: sales01@fwd-auto.com
Web:China OPEL,FORD,AUDI,OTHERS,VW,STEERING PARTS, Manufacturer - 2011 FORWARD AUTO PARTS CO.,LTD
www.dominant-auto.com
Hangzhou Dominant Auto Parts Co., Limited - OPEL/CHEVROLET PARTS,FORD PARTS
i wrote a a seller .. is posible make a guibo for g37
Old Jun 17, 2018 | 11:44 AM
rctstdroid1
replay from seller alibaba
sorry our factory is manufacturer ,so we do not sell one pcs
thanks
sifu
Dear Sir,
Good day.
Thank you for your reply.
It's regret to tell we are not retailer, we ask MOQ and 1pc is not available.
Pls kindly understand.
Best regards
no luck..
Old Jul 7, 2018 | 09:45 PM
rctstdroid1
Not luck for buy a new flex joint guibo.
the option was a buy used rear driveshaft for g37s with guibo. no was expensive. only 35$. thanks for all
Old Jul 7, 2018 | 11:53 PM
slartibartfast's Avatar
slartibartfast
Thank you for posting your solution. I am certain other G37 owners will find your information useful.
Send us a message once on awhile, you are our only member from Poland.
Old Jan 30, 2019 | 11:55 AM
Mr.J's Avatar
Mr.J
정확한 치수와 도면을 준다면 제작 해보겠습니다
이곳은 한국입니다 마찬가지로 카풀링이 따로
판매를 하지않아 제작 하여 사용을 많이합니다
사용 정확한 치수나 도면을 주세요
Old Jan 30, 2019 | 01:18 PM
slartibartfast
Per Google Translate:
This is Korea. Just like carpooling,
I do not sell, I use a lot of production
Please use exact dimensions or drawings
Do you manufacture these?
Old Jan 30, 2019 | 02:09 PM
Bravo at's Avatar
Bravo at
I want! So close...
Old Aug 16, 2019 | 10:56 AM
Bravo at's Avatar
Bravo at
Any updates from anyone on a solution for a driveshaft coupler?
Old Aug 21, 2019 | 01:39 AM
crookncastle's Avatar
crookncastle
i'm definitely interested in the above flex disc. unfortunately the ol'lady is currently out of town and won't be back till next month since she speaks and reads korean so i'm gonna need her help on this one.
Old Aug 21, 2019 | 09:11 AM
  #29
Bravo at's Avatar
Bravo at
Aluminum spacer
Could a 35mm spacer 6x114.3 be the trick?
Old Aug 21, 2019 | 03:05 PM
  #30
slartibartfast
The rubber guibo was put there to deal with driveline vibration. Whether it's actually objectionable is anyone's guess. I found the urethane trans mount disconcerting at first but don't notice it now. Didn't notice any change with the urethane diff bushing, either. You might not notice any extra vibration using a metal guibo replacement, but if you do, remove it immediately as those vibrations could eventually damage the transmission and/or diff.
