Car wont shift into gear
Old Jul 12, 2014 | 06:22 PM
smouth's Avatar
smouth
Hi guys,
I was trying to pull out my A/V unit and splice into the xm input, something went wrong along the way...it may have been because i tried starting it while in drive?
Anyways, the car starts, is in park but wont shift to any other gear, wont turn off with a single click of the push button-it requires a long hold, the gauges arent displaying anything, and the center console buttons arent working other than the emergency blinkers, although everything is properly connected.
I tried disconnecting the negative terminal of battery but that didnt help.
Any help would be appreciated
Old Jul 12, 2014 | 06:51 PM
Twista's Avatar
Twista
I suggest putting everything back the way it was. You might have created a very big problem
Old Jul 12, 2014 | 07:04 PM
telcoman's Avatar
telcoman
Originally Posted by smouth
Hi guys,
I assume you did a search for the FSM for your vehicle and followed the electrical schematic wiring diagram prior to cutting into wires?
As Twista has suggested, put everything back the way it was.
Telcoman
Old Jul 12, 2014 | 07:15 PM
smouth's Avatar
smouth
I did follow a diagram and only spliced onto the LH-/LH+ and RH-/RH+ for the xm. I connected everything back like it was and I still have this problem, any other ideas?
Old Jul 13, 2014 | 02:14 PM
Corey Kunak's Avatar
Corey Kunak
Hi guys,
is the white box (ac regulator) above the radio plugged in or in correctly. these are all the signs of this unit not being plugged in.
Old Jul 16, 2014 | 02:39 PM
terrycs's Avatar
terrycs
It sounds like you probably missed a connection back there somewhere or a connector possibly not being fully engaged?
Old Jul 18, 2014 | 03:49 PM
-Red-'s Avatar
-Red-
Hi guys,
This may be a long shot, but I would check your fuses.
Specifically for this.. http://www.infinitig37.com/TSB/ITB10-063a.pdf
I tapped the Homelink wire to install my radar detector a while back and popped this fuse in the process. My symptoms werent quite as severe as yours, but worth a look.
Old Apr 8, 2017 | 09:40 AM
Jasonm817's Avatar
Jasonm817
Did you even figure out the problem my car is doing the same thing but I didn't mess with the radio?
Old Mar 15, 2021 | 09:53 PM
DTX.G37's Avatar
DTX.G37
Same problem
did you figure it out?
macdog1997
18
Mar 8, 2021 07:06 PM
smouth
Jul 16, 2014 01:30 PM
Manny22
Oct 30, 2011 10:07 PM
boarderman23
45
Feb 17, 2009 10:22 PM
rawr
Apr 18, 2008 12:02 PM
