Help Car wont shift into gear
Old Jul 12, 2014 | 06:21 PM
smouth's Avatar
smouth
Hi guys,
I was trying to pull out my A/V unit and splice into the xm input, something went wrong along the way...it may have been because i tried starting it while in drive?
Anyways, the car starts, is in park but wont shift to any other gear, wont turn off with a single click of the push button-it requires a long hold, the gauges arent displaying anything, and the center console buttons arent working other than the emergency blinkers, although everything is properly connected.
I tried disconnecting the negative terminal of battery but that didnt help.
Any help would be appreciated
Old Jul 13, 2014 | 11:20 AM
telcoman's Avatar
telcoman
Originally Posted by smouth
Hi guys,
Not sure why you started another thread with the same question?
https://www.myg37.com/forums/g37-sed...into-gear.html
I take it you only tried disconnecting the negative battery cable after the problem occurred?
Cutting into wires without disconnecting the battery prior to doing any wiring cutting may have likely caused your problem.
Why did you attempt to start the car while in drive?
When an auto transmission vehicle is parked shouldn't the transmission be in Park?
You should have tried to obtain a plug and play adapter to adapt the existing wiring harness without having to cut any wires.
Crutchfield may have them?
Crutchfield: Car Stereo, Speakers, Home Theater, LED LCD TV, Cameras
http://www.crutchfield.com/p_975EPC5....html?tp=61674
Telcoman
Old Jul 13, 2014 | 02:13 PM
Corey Kunak's Avatar
Corey Kunak
Hi guys,
is the white box (ac regulator) above the radio plugged in or in correctly. these are all the signs of this unit not being plugged in.
Old Jul 13, 2014 | 04:03 PM
smouth's Avatar
smouth
Ya I didnt disconnect the battery before i began cutting.
The white box is properly connected I double checked.
I did find a blown fuse, "Elec Parts (ign)" . Upon replacing the fuse, double checking the connections, and reconnecting the battery, it blew again and the problems persisted.
Old Jul 13, 2014 | 04:29 PM
Corey Kunak
do you have nav or non nav?
have you re connected the cable that you spliced back to the way it was?
please take a pic of the connector you spliced and post it so i can see what you did excatly.
Old Jul 16, 2014 | 01:22 PM
smouth's Avatar
smouth
I figured out the problem, there was a short that was causing the "elec parts" fuse to blow which was causing all the problems.
Thanks for your help
Old Jul 16, 2014 | 01:30 PM
chilibowl's Avatar
chilibowl
How good does it feel to fix your own f*ckup and get your car back to normal working order....
I know I done f*cked up in my life before....and phew!
JoshB
Oct 15, 2015 03:08 PM
regimelife
Aug 18, 2015 04:46 PM
Thirty_Seven
12
Aug 16, 2015 01:48 PM
Sway_NV
Aug 15, 2015 09:36 PM
Corvalis
Aug 6, 2015 04:36 PM
