Stillen/GTM Supercharger Pros, Cons, and Questions
Old Jun 23, 2010 | 04:51 AM
  #91
Ivoidwarranties's Avatar
Ivoidwarranties
Originally Posted by Q8y_drifter
VHR bottom end with HR head.....
With a Stillen supercharger on top?
Old Jun 23, 2010 | 06:12 PM
  #92
G37Sam's Avatar
G37Sam
Originally Posted by Mike
Do Motorcycles with nearly 12:1 compression run too hot? Lets not forget they rev into the stratosphere.
Does the M3 with with a compression of 12:1 run too hot? It also revs higher.
What about diesels that typically run 18:1? They're usually turbocharged too, albiet with much lower redlines.
Ferrari? Lambo? Porsche?
Compression is simply a way to make power. The VQ35HR doesn't suffer from the catastrophic heat problems that the VQ37VHR suffers, and compression is nearly identical.
Remember, all those mid and rear engined cars you mentioned have ducts funneling air in to help cool things down. Just because they're temps don't go high doesn't mean they don't produce heat, they do.. but they're much better at cooling than our VQ37s.
Simple thermodynamics, there's no such thing as an adiabatic compression.. Anytime you compress a gas, it'll heat up whether you like it or not.. Throw some fuel with that and burn it and you're looking at a lot of heat generated! The challenge now is to throw this heat out of the engine bay
Old Jun 23, 2010 | 06:26 PM
  #93
Mike's Avatar
Mike
What about FF/FR cars?
I hate to do this but:
Celica (3SGE Beams, 11:1 compression, 1.8L making 200hp)
Civic SI (K20, 11:1 compression, 2.0L making 200hp)
S2000 (F20C/F22C 11:1 compression, 2.0/2.2L making 240hp)
These are all port injected cars; there's no fuel being injected after compression to absorb heat.
To put it in perspective, the N54 does have heat issues as well, but it was promptly addressed and fixed with an oil cooler. However, the Toyota 2GR-FSE is nearly 12:1, and doesn't suffer from cooling issues at all(and makes more torque than the VQ to boot).
So, the question is, how do we fix this?
We need a guinea pig for a frankenstein engine
Old Jun 23, 2010 | 07:13 PM
  #94
Ivoidwarranties
Sam, your theories are sound but compression ratio has very little if anything to do with how hot an engine runs.
Old Jun 23, 2010 | 08:00 PM
  #95
Q8y_drifter's Avatar
Q8y_drifter
N54's still have heat issues even with a factory cooler. Hell my friend has an AR Design Stage 2 cooler (that's two oil coolers total) and it still goes up to 250F with a single 60-130mph run.
Old Jun 23, 2010 | 08:48 PM
  #96
Staples's Avatar
Staples
This isn't a Honda
Old Jun 23, 2010 | 09:36 PM
  #97
G37Sam's Avatar
G37Sam
What in your opinion is the largest contributor then?
Old Jun 23, 2010 | 10:02 PM
  #98
Ivoidwarranties
Engine design. Simple as that. That is the number one contributor. You can break down every single element that causes heat in an engine but in the end it all comes down to how you handle that heat. You need to factor in how you're going to manage the heat, where it comes from, how you're going to move it, where it's going to go. I believe the design is not up to what it should have been. Maybe the cooling system isn't big enough. Maybe the radiator isn't getting enough air. Maybe they are using the wrong coolant, who knows. You may laugh at the last one but anyone who has been reading about the issues with the brakes knows that Nissan uses a crap brake fluid.
It's already been said, an oil cooler is a bandaid in this situation. It's a good idea in every car but the temps are just too damn high. Something isn't right.
I've been wondering why there isn't talk about running a lower coolant thermostat. Anyone know why that isn't a normal mod for these engines? It's common practice on most everything else.
Old Jun 23, 2010 | 10:06 PM
  #99
Mike's Avatar
Mike
Lower temp thermostat just turns the fans on earlier. Track speeds push more air through than having the fans on; in that environment, the car's ability to dissipate heat must be greater than the car's ability to generate it.
When you're standing still, the car can barely dissipate heat, so the fans turn on to assist; this is where the thermostat helps.
Old Jun 23, 2010 | 10:29 PM
  #100
G37Sam's Avatar
G37Sam
You must've missed my point, the higher compression ratio is what generates the extra heat. How you deal with that heat and send it out, is where engine design comes into play.
Old Jun 23, 2010 | 10:53 PM
  #101
Team STILLEN's Avatar
Team STILLEN
Don't forget about VVEL.. and all the fancy tomfoolery going on in the heads..
Old Jun 23, 2010 | 11:56 PM
  #102
Ivoidwarranties
I didn't miss your point. The higher compression is not the "contributor", it's the insufficient cooling or poor design. If you're looking at what causes the heat, it's just about every moving part in the engine. If you were to lower the compression ratio in this engine, you wouldn't be removing "extra heat" and solving any problem.
Old Jun 24, 2010 | 12:43 AM
  #103
Mike's Avatar
Mike
IMO, it's less engine design and more VVEL.
I can imagine what having to cool 6 electric motors can do to a cooling system...
Old Jun 24, 2010 | 01:34 AM
  #104
Ivoidwarranties
What????? Coolant thermostats turn on fans? Having control of the fans would also be a nice touch but how does the thermostat turn on the fans?
Old Jun 24, 2010 | 03:54 AM
  #105
Mike's Avatar
Mike
Oh, some come as a combo...
Otherwise, all it does it let coolant flow at a lower temp...
