Stillen/GTM Supercharger Pros, Cons, and Questions
Old Jun 24, 2010 | 10:45 AM
  #106
Q8y_drifter's Avatar
Q8y_drifter
Originally Posted by Staples
This isn't a Honda
Just a little combo I'd love to try
Old Jun 24, 2010 | 10:48 AM
  #107
Ivoidwarranties's Avatar
Ivoidwarranties
That's right, let the hot coolant out of the engine sooner so the engine can run cooler. I've never seen the combo thing you're talking about.
After looking in the manual, these thermostats open at 170 degrees and close at 160. That's probably the lowerest I've ever seen from the factory for any car, ever. It is built into the water inlet pipe (what I would call the snout) all as one assembly. Does not look easy to change out.
Old Jun 24, 2010 | 10:50 AM
  #108
Q8y_drifter
Isn't it similar to what the DE had? The DE opens at 180F or maybe the Nismo version opened at 180. Anyhow, I thought the design was similar and therefore replaceable. I don't know though.
Old Jun 24, 2010 | 02:52 PM
  #109
Mike's Avatar
Mike
In theory, under heavy use, it's going to be open the whole time anyways; it wouldn't apply for track duty.
Think of it this way: dedicated track cars generally don't have cooling fans...
Old Jun 24, 2010 | 11:28 PM
  #110
dillyyo's Avatar
dillyyo
Originally Posted by Q8y_drifter
SC - cheaper, easier to install and maintain, increased reliability over turbo, better day to day usage, less heat issues (due to engine oil used by turbo)
TT - more power, easier to increase & decrease boost via EBC, better torque, more fun at the track and weekend driving, easier to gain more power out of the same turbo.
This is ofcourse more of a general view of both but yeah. Personally I'd go with a SC if my car is a DD (and it is). It's just much easier to live with and less stuff the worry about over a turbo system IMO. Plus our cars make excellent power with FI and are quite reliable with the right amount of boost. The nice thing is that the power difference between SC and TT is not that much especially if you're considering going with a basic stage 1 kit (TT or SC). They both make over 400whp easily at similar amounts of boost.
Yeah, with turbos you have to worry about coking and shortening the life span. SC not being exhaust driven is cooler and not a worry. THe worse thing is loss of that turbo pull. Even NA big blocks are fast, but do not have the classic turbo rush!
Old Jun 24, 2010 | 11:30 PM
  #111
dillyyo's Avatar
dillyyo
Originally Posted by da mayor
im torn... the s/c just gives constant pressure onto the motor while the turbo you need to be in the right RPM's to hit boost.
It's also depending on how much more power you're looking to gain.
Not if you get a smaller size turbo. my 530's were super responsive and the best for daily driving. Way more fun that the bigger dyno queen turbos. Fun for top end, but not as much for "city" driving
Old Jun 28, 2010 | 03:57 PM
  #112
Mike's Avatar
Mike
more links added to original post.
Old Jun 28, 2010 | 11:25 PM
  #113
Mike's Avatar
Mike
CARB link added to first post, due to questions asked. CARB status can be checked via the link.
As of this post, neither the GTM nor Stillen kit are CARB legal.
Old Jun 29, 2010 | 03:11 AM
  #114
2muchredbull's Avatar
2muchredbull
could someone explain the Stillen warrenty on the SC?
ty
Old Jun 29, 2010 | 04:07 PM
  #115
OMG37's Avatar
OMG37
ty
Has stillen even posted what the warranty is yet? Last I checked they were still "getting all the ducks in a row" with the company they are contracting with.
Old Aug 20, 2010 | 09:18 AM
  #116
njchen24's Avatar
njchen24
Forgive my ignorance, I often hear about turbo lag. Is there any lag in sc? How about a poll showing tt vs sc?
Old Aug 20, 2010 | 11:11 AM
  #117
Weiboy718's Avatar
Weiboy718
Superchargers are powered by your engines crank pulley and boost builds as your rpms rises. There shouldn't be any lag.
Old Aug 20, 2010 | 03:59 PM
  #118
whiddles's Avatar
whiddles
I still need to take some videos of my car. I will try tomorrow with my droid lol.
Old Aug 20, 2010 | 06:06 PM
  #119
Q8y_drifter
please do so
Old Aug 23, 2010 | 07:29 AM
  #120
njchen24's Avatar
njchen24
In other word, the sc will have a faster response than tt, especially when you floor to pass or to start from a stop point. Am I understand correctly?
