Any way to add paddle shifters to a base modle G37 w/o harness inputs on the column?
Old Jul 8, 2021 | 06:38 PM
  #31
Oscar Zejdlik's Avatar
Oscar Zejdlik
Exclamation
Originally Posted by lechner80
Yes I have complete this mod. The wiring is easy. The install is very difficult if there is NO WIRING. I will be glad to help. Step One go to a junk yard to get the wiring. Get the plug with the wiring from M66 and the plugs with the wiring at the paddle shift. WHEN you have this let me know.
Can you send me a private message on how you did this?
Old Jul 9, 2021 | 12:06 AM
  #32
SkysG37's Avatar
SkysG37
'06 journey coupe here. No harness so I made my own harness.
At first was planning to splice off the hand shift switches.
But the paddle shifters I sourced were three wire.
Ended up tracing a stock wiring diagram and discovered they actually plug into the AC amplifier. (Located just above the radio/CD player unit). Stole the correct plugs (and wires/pins) from a junkyard dome light harness. (From a Murano I think)
Works a charm!
Old Apr 16, 2022 | 11:15 AM
  #33
Ospinca's Avatar
Ospinca
Trying to see or download this link.
Originally Posted by rmw00
YES, YES, YES... Finally figured out how to add paddle shifters to my 2008 G37 Journey Coupe. I'll post some pictures when I get time. You have to get a couple of connector contacts from your dealer. Insert them in connector M66 behind the dash and make your own harness. It does require soldering etc. Mine works great!
HELP PLEASE. I have G37 2009 convertible without NAV (no factory pre wire for paddles) that I am converting to a mix of IPL/Sport model. The only part I am missing is this pre wire diagram so can DYI.
I have a flicker account, but post can’t be found.
Please help!!!!!
Old Apr 16, 2022 | 11:52 AM
  #34
ILM-NC G37S's Avatar
ILM-NC G37S
Ospinca, I am so jealous....such a beauty....
Back to business.... check this thread and see if this is what you are looking for. If not, let me know what you need.
Old Apr 16, 2022 | 11:56 AM
  #35
Ospinca's Avatar
Ospinca
Awesome
Thanks for the link.
Ari Lau
44
Mar 14, 2025 11:55 AM
Atl3128
Feb 25, 2019 01:35 PM
silverbulletg37
Aug 23, 2011 03:19 PM
LightningG37
Nov 16, 2008 09:23 PM
cdebnil
Feb 28, 2008 07:48 PM
