DIY: G37 Automatic Transmission Fluid Change, Pan Drop/Clean
Next would be seal stress, either the front or rear seal will start having a tougher job due to not enough oil drainage.
A bit extra will be better than under at any moment, you can be easily under or over. I installed \a transmission that had oil in the pan but took a total of 10-11 quarts for full fill which mean it was almost completely dry.
Well, probably a bummer to have to say this being kind of an advocate of the improvements. I recently installed a flashed ECM and though my shifting pressures have increased and from the sporty aspect the car is a night and day difference, the drawback is that upon making more power you'll notice this issue a bit more.
To be precise it happens on D at it's highest gear, trying to drop a gear on pedal position alone it take an average of 2 seconds, doesn't seem like much but upon installing aftermarket components this initial delay will sound bad, like a kia/prius with a cold air. It feels like converter lags at disengaging and it needs to disengage prior to kick down.
The deepest part of the stock pan is only 1.75 inches tall (The section by the magnets) and at both the front and back of the pan that depth shrinks to 1.25 inches deep or shallower . The filter is submerged in fluid ...it needs to stay that way otherwise the pressure that builds when the mouth (The screen part) is not submerged or due to movement and a lower than recommended level was achieved when filled will cause the screen n at times to become not submerged, inhibiting steady flow of the Transmission fluid (Like sipping on a soda through a straw that is not submerged entirely the pressure needed to get fluid up the straw greatly increases)
16 oz short in the tranny at operating temperature can lower the fluid level by nearly a quarter inch below the pan gasket of the pan, the screen that sucks the fluid up does not extend into the pan all that much further. .
Bottom line...get it right or at worst error on the side of slightly over filled
I use a speech to text program that is not predictive and that is sound based, with a heavy NY accent... Quart is always interpreted as Court as is Sure as Shore . Sometimes I bother to check, on a message board mostly not.
Little thin skinned for a yorker much? Misinformation? Where? Perhaps you should read back in the thread...
Edit...so you used dictation? I call BS as you obviously are either a god among gods who can dictate dots (even misplaced periods), parenthese, and carriage returns with ease or you are trying your best to back out of the fact that you didn't have a clue difference between court and quart. It wouldn't be the first time I've seen someone use dictation as the excuse for not knowing eNgLisH. Did dictation "capitalize spelling" for you too? If I'm going to be called out for being a ****, perhaps I should be one. ;-) Look man, own it.
Last edited by m3clubracer; Apr 28, 2021 at 07:32 AM. Reason: thin skinned whiny *** got caught in a lie
I speak and write 3 languages, it's greatly appreciated when you can let that peeve slide and understand what they were trying to say. Be nice
Originally Posted by m3clubracer;
Guys...it doesn't matter that much. If the trans is +/- .5qt it won't matter.
All,
For reference below are the quantities and OEM part numbers for the replacement parts. My car is very rusty so I plan to buy most of the parts just in case. Although I will buy 12 transmission pan bolts instead of 24 as I'm sure at least half should be re-usable hopefully. It took me over an hour to find this information as the diagrams on the official Infiniti parts site was not clear:
1x Transmission Oil Pan Gasket: 31397-1XJ0A (31390)
1x Fill Plug: 31361-1XJ0A (31120A)
1x Drain Plug: 31377-31X06 (31390A)
1x Drain Plug Washer: 11026-JA00A (31394E) (Same one used for the oil drain plug)
24x Transmission Oil Pan Bolts: 31377-41X60 (31390AA)
Hopefully this is helpful for others.
Did anyone ever end up finding the transmission filter part number or did we agree to just leave it be?
All,
Since your car is rusted I would say a couple of days prior spray penetrant throughout this whole area. You'll be glad you did come D-day.
Thanks BULL, m3clubracer and KEVON1! I'll probably err on the side of more fluid when refilling. 120k, and I recently started noticing the transmission start slipping, so probably this was never done. I don't plan on dropping the pan as there might be rust induced complications. Will see how it goes after the fluid is changed out. Vavoline looks to still be the best choice; the Transmax Castro I was using for PS changes does not appear to be compatible.
This forum has been very informative and I'm grateful to have such a wealth of information available. Was recently dumping out my old waste PS fluid accumulated over the years and could see it go from dirty red/brown to clear red. Pumping from reservoir's an easy DIY.
