DIY Coilover Install
I've searched high and low for DIY coilover install on here and haven't found one. Even searched google but still couldn't find anything. Does anyone have a link to a good DIY? I'm looking to DIY tanabe sustecs.
Youre not going to find a DIY specific to a single brand and model of coilovers. They are all very similar. This is a pretty good DIY:
http://www.nicoclub.com/archives/pro...n-part-ii.html
Infiniti G37 maintenance, repair, diagnostic and modification information
This guy has alot of DIYs on his website. Good pics too.
Project Infiniti G37 Coilover Installation Part II
good luck. The install isn't bad. I did the sustecs about a month ago. There is no DIY so you just have to go for it. The sustecs re-use the stock upper mount on the front so you will need a spring compressor. An impact gun helps with the process. If you dont have one make sure you atleast have a breaker bar. Those bolts on the front are a b!tch.
If you have any questions PM me or post them in here. Ill try to keep an eye on it.
Haha, I keep hearing that. I'm hoping the fact that my car is new that I'll be spared from the PITA. I'm going to take a breaker bar to it, hoping that will be enough
As was said, the rears are quite easy (only 2 bolts, 2 nuts that are easy to access) but unless you're one of these mechanical supermen that periodically post how this jobcan be done in an hour or less, allow most of a day just to be sure if it's your first time. A reasonable amount of time without air tools or a lift would be 2.5 to 5 hours dependent on a number of factors.
DIY: Coilover Install - G35Driver
http://www.bcracing-na.com/G37install.htm
Torque specs:
g Gallery | suspension
I don't say this to dampen your spirits, but your car being new doesn't make much of a difference. If you don't have air tools, use penetrating lube liberally on all the bolts and nuts and let it work in for at least a day if possible. It makes a big difference. I also suggest a breaker bar at least 24" or more and at least 1/2" size.
Here you go.
Torque specs:
Torque specs:
The upper mount is a metal plate that is sometimes reused when installing coilovers, it's the top plate that is bolted to te strut that compresses the spring.
Not really sure what you mean. Are you getting springs installed? If so, then yes he would have to reuse the front strut, but coilovers are a package deal and you wouldn't reuse the strut.
Sorry, yes the upper mount of the strut bar is what I mean. I am having the Tanabe coilovers installed. Is there really any repercussions if I reuse the uppermount? Is the uppermount known to go bad if reused? My mechanic is recommending me to buy a new uppermount for the fronts
